[PATCH rtems-docs v2] networking: Rename to legacy networking
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 23 20:08:12 UTC 2021
Hi,
Thanks for the review.
On Tue, Mar 23, 2021 at 12:56 PM Joel Sherrill <joel at rtems.org> wrote:
> I'm OK with this.
> Does this move the manual to near the bottom of the manual list?
No, it doesn't. I just sent a v3 to add this. I have also sent a patch
to fix the docs build for python 3.5 and up.
> I suspect some content is needed somewhere in the Users Guide
> to point out how you have a choice of network stacks and building
> one of them. Beyond this patch but looking forward, we have some
> explaining to do.
Yes, I'm planning to write documentation about the different network
stack available in rtems and how would a user select between them.
This can be a section in the user manual.
Best regards,
Vijay
> --joel
> On Tue, Mar 23, 2021 at 1:48 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> Ping :)
>> On Tue, Mar 9, 2021 at 9:59 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> >  book/index_book.rst                                           | 2 +-
>> >  {networking => legacy-networking}/command.rst                 | 0
>> >  {networking => legacy-networking}/conf.py                     | 4 ++--
>> >  {networking => legacy-networking}/dec_21140.rst               | 0
>> >  {networking => legacy-networking}/index.rst                   | 2 +-
>> >  {networking => legacy-networking}/network_servers.rst         | 0
>> >  {networking => legacy-networking}/network_task_structure.rst  | 0
>> >  {networking => legacy-networking}/networking_driver.rst       | 0
>> >  {networking => legacy-networking}/preface.rst                 | 0
>> >  {networking => legacy-networking}/testing_the_driver.rst      | 0
>> >  .../using_networking_rtems_app.rst                            | 0
>> >  {networking => legacy-networking}/wscript                     | 0
>> >  wscript                                                       | 2 +-
>> >  13 files changed, 5 insertions(+), 5 deletions(-)
>> >  rename {networking => legacy-networking}/command.rst (100%)
>> >  rename {networking => legacy-networking}/conf.py (68%)
>> >  rename {networking => legacy-networking}/dec_21140.rst (100%)
>> >  rename {networking => legacy-networking}/index.rst (92%)
>> >  rename {networking => legacy-networking}/network_servers.rst (100%)
>> >  rename {networking => legacy-networking}/network_task_structure.rst (100%)
>> >  rename {networking => legacy-networking}/networking_driver.rst (100%)
>> >  rename {networking => legacy-networking}/preface.rst (100%)
>> >  rename {networking => legacy-networking}/testing_the_driver.rst (100%)
>> >  rename {networking => legacy-networking}/using_networking_rtems_app.rst (100%)
>> >  rename {networking => legacy-networking}/wscript (100%)
>> > diff --git a/book/index_book.rst b/book/index_book.rst
>> > index 8282006..3fc67d2 100644
>> > --- a/book/index_book.rst
>> > +++ b/book/index_book.rst
>> > @@ -23,7 +23,7 @@ Table of Contents
>> >         cpu_supplement/index.rst
>> >         develenv/index.rst
>> >         filesystem/index.rst
>> > -       networking/index.rst
>> > +       legacy_networking/index.rst
>> >         porting/index.rst
>> >         posix1003_1/index.rst
>> >         posix_users/index.rst
>> > diff --git a/networking/command.rst b/legacy-networking/command.rst
>> > similarity index 100%
>> > rename from networking/command.rst
>> > rename to legacy-networking/command.rst
>> > diff --git a/networking/conf.py b/legacy-networking/conf.py
>> > similarity index 68%
>> > rename from networking/conf.py
>> > rename to legacy-networking/conf.py
>> > index 1c129bc..6cc01bc 100644
>> > --- a/networking/conf.py
>> > +++ b/legacy-networking/conf.py
>> > @@ -3,12 +3,12 @@ sys.path.insert(0, os.path.abspath('../common/'))
>> >  from conf import *
>> > -project = "RTEMS Networking User Manual"
>> > +project = "RTEMS Legacy Networking User Manual"
>> >  latex_documents = [
>> >      ('index',
>> >       'networking.tex',
>> > -     u'RTEMS Networking User Manual',
>> > +     u'RTEMS Legacy Networking User Manual',
>> >       u'RTEMS Documentation Project',
>> >       'manual'),
>> > diff --git a/networking/dec_21140.rst b/legacy-networking/dec_21140.rst
>> > rename from networking/dec_21140.rst
>> > rename to legacy-networking/dec_21140.rst
>> > diff --git a/networking/index.rst b/legacy-networking/index.rst
>> > similarity index 92%
>> > rename from networking/index.rst
>> > rename to legacy-networking/index.rst
>> > index f56a60d..b85119d 100644
>> > --- a/networking/index.rst
>> > +++ b/legacy-networking/index.rst
>> > @@ -5,7 +5,7 @@
>> >  .. highlight:: c
>> > -RTEMS Network User Manual (|version|).
>> > +RTEMS Legacy Network User Manual (|version|).
>> >  .. topic:: Copyrights and License
>> > diff --git a/networking/network_servers.rst b/legacy-networking/network_servers.rst
>> > rename from networking/network_servers.rst
>> > rename to legacy-networking/network_servers.rst
>> > diff --git a/networking/network_task_structure.rst b/legacy-networking/network_task_structure.rst
>> > rename from networking/network_task_structure.rst
>> > rename to legacy-networking/network_task_structure.rst
>> > diff --git a/networking/networking_driver.rst b/legacy-networking/networking_driver.rst
>> > rename from networking/networking_driver.rst
>> > rename to legacy-networking/networking_driver.rst
>> > diff --git a/networking/preface.rst b/legacy-networking/preface.rst
>> > rename from networking/preface.rst
>> > rename to legacy-networking/preface.rst
>> > diff --git a/networking/testing_the_driver.rst b/legacy-networking/testing_the_driver.rst
>> > rename from networking/testing_the_driver.rst
>> > rename to legacy-networking/testing_the_driver.rst
>> > diff --git a/networking/using_networking_rtems_app.rst b/legacy-networking/using_networking_rtems_app.rst
>> > rename from networking/using_networking_rtems_app.rst
>> > rename to legacy-networking/using_networking_rtems_app.rst
>> > diff --git a/networking/wscript b/legacy-networking/wscript
>> > rename from networking/wscript
>> > rename to legacy-networking/wscript
>> > diff --git a/wscript b/wscript
>> > index ce644f8..92775ae 100644
>> > --- a/wscript
>> > +++ b/wscript
>> > @@ -32,7 +32,7 @@ build_all = ['user',
>> >               'posix-compliance',
>> >               'eng',
>> >               'filesystem',
>> > -             'networking',
>> > +             'legacy-networking',
>> >               'shell',
>> >               'cpu-supplement',
>> >               'develenv',
>> > 2.26.2
