[PATCH rtems-net-legacy 1/2] Remove RTEMS_NETWORKING checks
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 23 20:09:59 UTC 2021
* Remove nfsclient wscript and build from netlegacy.py
bsps/powerpc/mpc55xxevb/net/smsc9218i.c | 4 +--
libmisc/dummy-networking.c | 44 ++++++++++++-------------
netlegacy.py | 17 +++++++++-
nfsclient/wscript | 1 +
telnetd/telnetd.c | 4 ---
wscript | 2 +-
6 files changed, 41 insertions(+), 31 deletions(-)
diff --git a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
index d88aa8a..384f9cd 100644
--- a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
+++ b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
@@ -24,7 +24,7 @@
#include <mpc55xx/regs.h>
-#if defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU)
+#if defined(MPC55XX_HAS_SIU)
#include <machine/rtems-bsd-kernel-space.h>
@@ -2121,4 +2121,4 @@ int smsc9218i_attach_detach(
return 0;
-#endif /* defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU) */
+#endif /* defined(MPC55XX_HAS_SIU) */
diff --git a/libmisc/dummy-networking.c b/libmisc/dummy-networking.c
index 379e23e..b7f15c8 100644
--- a/libmisc/dummy-networking.c
+++ b/libmisc/dummy-networking.c
@@ -16,27 +16,25 @@
/* Loopback Network Configuration */
- #include <rtems/rtems_bsdnet.h>
- #include <sys/socket.h>
- #include <netinet/in.h>
+#include <rtems/rtems_bsdnet.h>
+#include <sys/socket.h>
+#include <netinet/in.h>
- struct rtems_bsdnet_config rtems_bsdnet_config = {
- NULL, /* Network interface */
- NULL, /* Use fixed network configuration */
- 0, /* Default network task priority */
- 0, /* Default mbuf capacity */
- 0, /* Default mbuf cluster capacity */
- "testSystem", /* Host name */
- "nowhere.com", /* Domain name */
- "127.0.0.1", /* Gateway */
- "127.0.0.1", /* Log host */
- {"127.0.0.1" }, /* Name server(s) */
- {"127.0.0.1" }, /* NTP server(s) */
- 1, /* sb_efficiency */
- 0, /* udp_tx_buf_size */
- 0, /* udp_rx_buf_size */
- 0, /* tcp_tx_buf_size */
- 0 /* tcp_rx_buf_size */
-#endif
+struct rtems_bsdnet_config rtems_bsdnet_config = {
+ NULL, /* Network interface */
+ NULL, /* Use fixed network configuration */
+ 0, /* Default network task priority */
+ 0, /* Default mbuf capacity */
+ 0, /* Default mbuf cluster capacity */
+ "testSystem", /* Host name */
+ "nowhere.com", /* Domain name */
+ "127.0.0.1", /* Gateway */
+ "127.0.0.1", /* Log host */
+ {"127.0.0.1" }, /* Name server(s) */
+ {"127.0.0.1" }, /* NTP server(s) */
+ 1, /* sb_efficiency */
+ 0, /* udp_tx_buf_size */
+ 0, /* udp_rx_buf_size */
+ 0, /* tcp_tx_buf_size */
+ 0 /* tcp_rx_buf_size */
diff --git a/netlegacy.py b/netlegacy.py
index 0889548..0e69076 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -54,6 +54,12 @@ def build(bld):
for s in os.listdir('./pppd') if s[-2:] == '.c']
telnetd_source = [os.path.join('./telnetd', s)
for s in os.listdir('telnetd') if s[-2:] == '.c']
+ nfs_source = []
+ for root, dirs, files in os.walk('./nfsclient'):
+ for name in files:
+ if name[-2:] == '.c':
+ src_root = root.split('/')[2]
+ nfs_source.append(os.path.join('./nfsclient', src_root, name))
bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
@@ -66,6 +72,7 @@ def build(bld):
'./bsps/include'])
arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
bld.env.RTEMS_ARCH_BSP)
+ lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
arch_lib_path)))
@@ -73,6 +80,8 @@ def build(bld):
'include')))
include_path.append('./bsps/include/libchip')
+ bld.read_stlib('rtemsbsp', paths=[lib_path])
if bsp in bsp_dirs:
include_path.extend(bsp_dirs[bsp])
@@ -107,8 +116,14 @@ def build(bld):
use='networking',
source=telnetd_source)
+ bld.stlib(target='nfs',
+ features='c',
+ includes=ip,
+ use=['rtemsbsp', 'networking'],
+ source=nfs_source)
bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
- ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
+ ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
'include', 'libchip'),
[os.path.join('./bsps/include/libchip/', f)
diff --git a/nfsclient/wscript b/nfsclient/wscript
index bc2f994..c0fe420 100644
--- a/nfsclient/wscript
+++ b/nfsclient/wscript
@@ -52,5 +52,6 @@ def build(bld):
features='c',
cflags=['-O2', '-g'],
includes=include_path,
+ use=['networking'],
source=source_files)
bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
diff --git a/telnetd/telnetd.c b/telnetd/telnetd.c
index b8adec2..3d401ff 100644
--- a/telnetd/telnetd.c
+++ b/telnetd/telnetd.c
@@ -58,9 +58,7 @@
#include <rtems/thread.h>
#include <rtems/userenv.h>
-#ifdef RTEMS_NETWORKING
-#endif
#define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
@@ -401,11 +399,9 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
LIST_INIT(&ctx->free_sessions);
/* Check priority */
if (ctx->config.priority == 0) {
ctx->config.priority = rtems_bsdnet_config.network_task_priority;
-#endif
ctx->config.priority = 100;
diff --git a/wscript b/wscript
index 07f774d..7af317d 100644
--- a/wscript
+++ b/wscript
@@ -33,7 +33,7 @@ import sys
top = '.'
rtems_version = "6"
-subdirs = ['nfsclient', 'testsuites']
+subdirs = ['testsuites']
try:
import rtems_waf.rtems as rtems
2.26.2
