[PATCH 2/2] rtems: Simplify rtems_semaphore_set_priority()
Sebastian Huber
Wed Mar 24 07:40:41 UTC 2021
Do not write to the object referenced by old_priority in error paths.
This is in line with other directives.
cpukit/rtems/src/semsetpriority.c | 47 +++++++++++++++----------------
1 file changed, 22 insertions(+), 25 deletions(-)
diff --git a/cpukit/rtems/src/semsetpriority.c b/cpukit/rtems/src/semsetpriority.c
index 119dd85d77..97e53c6584 100644
--- a/cpukit/rtems/src/semsetpriority.c
+++ b/cpukit/rtems/src/semsetpriority.c
@@ -29,20 +29,6 @@
-static rtems_status_code _Semaphore_Is_scheduler_valid(
- const CORE_ceiling_mutex_Control *the_mutex,
- const Scheduler_Control *scheduler
-#if defined(RTEMS_SMP)
- if ( scheduler != _CORE_ceiling_mutex_Get_scheduler( the_mutex ) ) {
- return RTEMS_NOT_DEFINED;
-#endif
- return RTEMS_SUCCESSFUL;
static rtems_status_code _Semaphore_Set_priority(
Semaphore_Control *the_semaphore,
const Scheduler_Control *scheduler,
@@ -51,7 +37,6 @@ static rtems_status_code _Semaphore_Set_priority(
Thread_queue_Context *queue_context
- rtems_status_code sc;
bool valid;
Priority_Control core_priority;
Priority_Control old_priority;
@@ -73,16 +58,26 @@ static rtems_status_code _Semaphore_Set_priority(
switch ( variant ) {
case SEMAPHORE_VARIANT_MUTEX_PRIORITY_CEILING:
- sc = _Semaphore_Is_scheduler_valid(
- &the_semaphore->Core_control.Mutex,
- scheduler
+#if defined(RTEMS_SMP)
+ if (
+ scheduler != _CORE_ceiling_mutex_Get_scheduler(
+ &the_semaphore->Core_control.Mutex
+ _Thread_queue_Release(
+ &the_semaphore->Core_control.Wait_queue,
+ queue_context
+ return RTEMS_NOT_DEFINED;
+#endif
old_priority = _CORE_ceiling_mutex_Get_priority(
- if ( sc == RTEMS_SUCCESSFUL && new_priority != RTEMS_CURRENT_PRIORITY ) {
+ if ( new_priority != RTEMS_CURRENT_PRIORITY ) {
_CORE_ceiling_mutex_Set_priority(
core_priority
@@ -105,7 +100,6 @@ static rtems_status_code _Semaphore_Set_priority(
- sc = RTEMS_SUCCESSFUL;
break;
#endif
default:
@@ -115,9 +109,12 @@ static rtems_status_code _Semaphore_Set_priority(
|| variant == SEMAPHORE_VARIANT_SIMPLE_BINARY
|| variant == SEMAPHORE_VARIANT_COUNTING
- old_priority = 0;
- sc = RTEMS_NOT_DEFINED;
- break;
+ queue_context
cpu_self = _Thread_queue_Dispatch_disable( queue_context );
@@ -129,7 +126,7 @@ static rtems_status_code _Semaphore_Set_priority(
_Thread_Dispatch_enable( cpu_self );
*old_priority_p = _RTEMS_Priority_From_core( scheduler, old_priority );
- return sc;
+ return RTEMS_SUCCESSFUL;
rtems_status_code rtems_semaphore_set_priority(
2.26.2
