[rtems commit] gen_uuid.c: Fix two Unchecked return value from library errors
Joel Sherrill
joel at rtems.org
Wed Mar 24 13:02:47 UTC 2021
I'm reverting this.
I think this is in a batch that did not get tested before I worked
with Ryan to correct his procedure.to ensure more testing with
debug enabled.
On most he has filed issues with the upstream, but as you note,
this isn't the right solution so that doesn't matter here. Probably
best to ifndef rtems around the unsupported features.
I'm about to push a revert and reopen the ticket.
--joel
On Wed, Mar 24, 2021 at 2:31 AM Sebastian Huber <
> On 08/03/2021 21:56, Joel Sherrill wrote:
> > Module: rtems
> > Branch: master
> > Commit: 597e4f476568a225d14dfaff02074cf269ad62ac
> > Changeset:
> http://git.rtems.org/rtems/commit/?id=597e4f476568a225d14dfaff02074cf269ad62ac
> > Author: Ryan Long<ryan.long at oarcorp.com>
> > Date: Tue Mar 2 11:08:28 2021 -0500
> > CID 1049146: Unchecked return value from library in get_clock().
> > CID 1049147: Unchecked return value from library in get_random_fd().
> > Closes #4280
> > cpukit/libmisc/uuid/gen_uuid.c | 11 ++++++++---
> > 1 file changed, 8 insertions(+), 3 deletions(-)
> > diff --git a/cpukit/libmisc/uuid/gen_uuid.c
> b/cpukit/libmisc/uuid/gen_uuid.c
> > index 3ca75a0..5bb34c0 100644
> > --- a/cpukit/libmisc/uuid/gen_uuid.c
> > +++ b/cpukit/libmisc/uuid/gen_uuid.c
> > @@ -155,6 +155,7 @@ static int get_random_fd(void)
> > struct timeval tv;
> > static int fd = -2;
> > int i;
> > + int sc;
> > if (fd == -2) {
> > gettimeofday(&tv, 0);
> > @@ -164,8 +165,10 @@ static int get_random_fd(void)
> > fd = open("/dev/random", O_RDONLY | O_NONBLOCK);
> > if (fd >= 0) {
> > i = fcntl(fd, F_GETFD);
> > - if (i >= 0)
> > - fcntl(fd, F_SETFD, i | FD_CLOEXEC);
> > + if (i >= 0) {
> > + sc = fcntl(fd, F_SETFD, i | FD_CLOEXEC);
> > + _Assert_Unused_variable_unequal(sc, -1);
> FD_CLOEXEC is not supported by RTEMS. Do we even have these device files
> in RTEMS? This is 3rd-party code, what about upstream changes?
> > #endif
> > srand((getpid() << ((sizeof(pid_t)*CHAR_BIT)>>1)) ^
> getuid() ^ tv.tv_sec ^ tv.tv_usec);
> > @@ -334,6 +337,7 @@ static int get_clock(uint32_t *clock_high, uint32_t
> *clock_low,
> > uint64_t clock_reg;
> > mode_t save_umask;
> > int len;
> > + int sc;
> > if (state_fd == -2) {
> > save_umask = umask(0);
> > @@ -426,7 +430,8 @@ try_again:
> > rewind(state_f);
> > fl.l_type = F_UNLCK;
> > - fcntl(state_fd, F_SETLK, &fl);
> > + sc = fcntl(state_fd, F_SETLK, &fl);
> F_SETLK is not supported by RTEMS.
> > *clock_high = clock_reg >> 32;
> The patch produces warnings like this:
> ../../../cpukit/libmisc/uuid/gen_uuid.c: In function 'get_clock':
> ../../../cpukit/libmisc/uuid/gen_uuid.c:434:3: warning: implicit
> declaration of function '_Assert_Unused_variable_unequal'
> [-Wimplicit-function-declaration]
> 434 | _Assert_Unused_variable_unequal(sc, -1);
> ../../../cpukit/libmisc/uuid/gen_uuid.c:434:3: warning: nested extern
> declaration of '_Assert_Unused_variable_unequal' [-Wnested-externs]
> In total, how was this patch tested?
> If you add _Assert() stuff, please build with RTEMS_DEBUG enabled and
> run the tests.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210324/8a939b05/attachment.html>
