[PATCH] covoar: Add aarch64 target
    Gedare Bloom
    gedare at rtems.org
    Wed Mar 24 17:24:50 UTC 2021
On Wed, Mar 24, 2021 at 10:46 AM Alex White <alex.white at oarcorp.com> wrote:
>  tester/covoar/TargetFactory.cc  |   2 +
>  tester/covoar/Target_aarch64.cc | 100 ++++++++++++++++++++++++++++++++
>  tester/covoar/Target_aarch64.h  |  77 ++++++++++++++++++++++++
>  tester/covoar/wscript           |   1 +
>  4 files changed, 180 insertions(+)
>  create mode 100644 tester/covoar/Target_aarch64.cc
>  create mode 100644 tester/covoar/Target_aarch64.h
> diff --git a/tester/covoar/TargetFactory.cc b/tester/covoar/TargetFactory.cc
> index 12de94d..57ba686 100644
> --- a/tester/covoar/TargetFactory.cc
> +++ b/tester/covoar/TargetFactory.cc
> @@ -17,6 +17,7 @@
>  #include "TargetFactory.h"
> +#include "Target_aarch64.h"
>  #include "Target_arm.h"
>  #include "Target_i386.h"
>  #include "Target_m68k.h"
> @@ -51,6 +52,7 @@ namespace Target {
>    //! All must be derived from TargetBase.
>    static FactoryEntry_t FactoryTable[] = {
> +    { "aarch64", Target_aarch64_Constructor },
>      { "arm",     Target_arm_Constructor },
>      { "i386",    Target_i386_Constructor },
>      { "lm32",    Target_lm32_Constructor },
> diff --git a/tester/covoar/Target_aarch64.cc b/tester/covoar/Target_aarch64.cc
> new file mode 100644
> index 0000000..64472d6
> --- /dev/null
> +++ b/tester/covoar/Target_aarch64.cc
> @@ -0,0 +1,100 @@
> +/*! @file Target_aarch64.cc
> + *  @brief Target_aarch64 Implementation
> + *  This file contains the implementation of the base class for
> + *  functions supporting target unique functionallity.
only one l in functionality
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <string.h>
> +#include <unistd.h>
> +#include <rld.h>
> +namespace Target {
> +  Target_aarch64::Target_aarch64( std::string targetName ):
> +    TargetBase( targetName )
> +    conditionalBranchInstructions.push_back("cbnz");
> +    conditionalBranchInstructions.push_back("cbz");
> +    conditionalBranchInstructions.push_back("tbnz");
> +    conditionalBranchInstructions.push_back("tbz");
> +    conditionalBranchInstructions.push_back("b.eq");
> +    conditionalBranchInstructions.push_back("b.ne");
> +    conditionalBranchInstructions.push_back("b.cs");
> +    conditionalBranchInstructions.push_back("b.hs");
> +    conditionalBranchInstructions.push_back("b.cc");
> +    conditionalBranchInstructions.push_back("b.lo");
> +    conditionalBranchInstructions.push_back("b.mi");
> +    conditionalBranchInstructions.push_back("b.pl");
> +    conditionalBranchInstructions.push_back("b.vs");
> +    conditionalBranchInstructions.push_back("b.vc");
> +    conditionalBranchInstructions.push_back("b.hi");
> +    conditionalBranchInstructions.push_back("b.ls");
> +    conditionalBranchInstructions.push_back("b.ge");
> +    conditionalBranchInstructions.push_back("b.lt");
> +    conditionalBranchInstructions.push_back("b.gt");
> +    conditionalBranchInstructions.push_back("b.le");
> +    conditionalBranchInstructions.sort();
this is kind of lazy :) you could sort them as you push them.
> +  Target_aarch64::~Target_aarch64()
> +  bool Target_aarch64::isNopLine(
> +    const char* const line,
> +    int&              size
> +    if (!strcmp( &line[strlen(line)-3], "nop")) {
any reason this is strcmp but the others are strncmp?
> +      size = 4;
> +      return true;
I wonder if you guys want to take a stab at using C++ strings or not?
just a thought.
This stuff how it is being done is very fickle with these constant
numbers, but I guess the interface shouldn't change too much since it
derives from the ISA. It just isn't clear at all how this stuff works
by casual observation.
> +    if (!strncmp( &line[strlen(line)-6], "udf", 3)) {
> +      size = 4;
> +      return true;
> +    // On ARM, there are literal tables at the end of methods.
> +    // We need to avoid them.
> +    if (!strncmp( &line[strlen(line)-10], ".byte", 5)) {
> +      size = 1;
> +      return true;
> +    if (!strncmp( &line[strlen(line)-13], ".short", 6)) {
> +      size = 2;
> +      return true;
> +    if (!strncmp( &line[strlen(line)-16], ".word", 5)) {
> +      size = 4;
> +      return true;
> +    return false;
> +  bool Target_aarch64::isBranch(
> +      const char* instruction
> +    throw rld::error(
> +      "DETERMINE BRANCH INSTRUCTIONS FOR THIS ARCHITECTURE! -- fix me",
Seems like this could be a better message. Is this the "standard"
error message being used in covoar for this condition?
> +      "Target_aarch64::isBranch"
> +  TargetBase *Target_aarch64_Constructor(
> +    std::string          targetName
> +    return new Target_aarch64( targetName );
> diff --git a/tester/covoar/Target_aarch64.h b/tester/covoar/Target_aarch64.h
> index 0000000..8c15daa
> --- /dev/null
> +++ b/tester/covoar/Target_aarch64.h
> @@ -0,0 +1,77 @@
> +/*! @file Target_aarch64.h
> + *  @brief Target_aarch64 Specification
> + *  This file contains the specification of the Target_aarch64 class.
> +#ifndef __TARGET_AARCH64_H__
> +#define __TARGET_AARCH64_H__
> +#include <list>
> +#include <string>
> +#include "TargetBase.h"
> +namespace Target {
> +  /*! @class Target_aarch64
> +   *  This class is the Target class for the aarch64 processor.
> +  class Target_aarch64: public TargetBase {
> +  public:
> +     *  This method constructs an Target_aarch64 instance.
> +    Target_aarch64( std::string targetName );
> +     *  This method destructs an Target_aarch64 instance.
> +    virtual ~Target_aarch64();
> +     *  This method determines whether the specified line from a
> +     *  objdump file is a nop instruction.
> +     *  @param[in] line contains the object dump line to check
> +     *  @param[out] size is set to the size in bytes of the nop
> +     *  @return Returns TRUE if the instruction is a nop, FALSE otherwise.
> +    bool isNopLine(
> +      int&              size
> +     *  This method determines if the specified line from an
> +     *  objdump file is a branch instruction.
> +    bool isBranch(
> +      const char* const instruction
i'm surprised these aren't part of the TargetBase interface. since
they are not, why they should be public?
I still struggle reviewing this codebase, in part because it is C+C++
(TM) and in part because I'm not so proficient in C++ to make concrete
recommendations how to write this better. I think, if the goal is
eventually to make this more C++ like code, then new code coming in
should aim to move the needle in that direction rather than continue
to propagate the old ways of doing.
> +  private:
> +  //! @brief Constructor Helper
> +  //! This is a constructor helper for this class which can be used in support
> +  //! of factories.
> +  //! @param [in] Targetname is the name of the Target being constructed.
> +  //! @return This method constructs a new instance of the Target and returns
> +  //!         that to the caller.
> +#endif
> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> index 165a1b8..82599b0 100644
> --- a/tester/covoar/wscript
> +++ b/tester/covoar/wscript
> @@ -106,6 +106,7 @@ def build(bld):
>                          'ReportsText.cc',
>                          'ReportsHtml.cc',
>                          'SymbolTable.cc',
> +                        'Target_aarch64.cc',
>                          'Target_arm.cc',
>                          'TargetBase.cc',
>                          'TargetFactory.cc',
> 2.27.0
> devel mailing list
> devel at rtems.org
