[PATCH rtems 2/2] stm32h7: Add init for sdmmc pins.
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Mar 25 08:34:38 UTC 2021
bsps/arm/stm32h7/hal/stm32h7xx_hal_sd.c | 2 +
bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c | 88 ++++++++++++++++++++++
spec/build/bsps/arm/stm32h7/bspstm32h7.yml | 1 +
3 files changed, 91 insertions(+)
create mode 100644 bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c
diff --git a/bsps/arm/stm32h7/hal/stm32h7xx_hal_sd.c b/bsps/arm/stm32h7/hal/stm32h7xx_hal_sd.c
index edafb06def..eb8dbe71f1 100644
--- a/bsps/arm/stm32h7/hal/stm32h7xx_hal_sd.c
+++ b/bsps/arm/stm32h7/hal/stm32h7xx_hal_sd.c
@@ -594,6 +594,7 @@ HAL_StatusTypeDef HAL_SD_DeInit(SD_HandleTypeDef *hsd)
+#ifndef __rtems__
* @brief Initializes the SD MSP.
* @param hsd: Pointer to SD handle
@@ -608,6 +609,7 @@ __weak void HAL_SD_MspInit(SD_HandleTypeDef *hsd)
the HAL_SD_MspInit could be implemented in the user file
+#endif /* __rtems__ */
* @brief De-Initialize SD MSP.
diff --git a/bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c b/bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c
new file mode 100644
index 0000000000..2bbc4ff953
--- /dev/null
+++ b/bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c
@@ -0,0 +1,88 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stm32h7/hal.h>
+static const stm32h7_gpio_config gpiob = {
+ .regs = GPIOB,
+ .config = {
+ .Pin = GPIO_PIN_8 | GPIO_PIN_9,
+ .Mode = GPIO_MODE_AF_PP,
+ .Pull = GPIO_NOPULL,
+ .Speed = GPIO_SPEED_FREQ_VERY_HIGH,
+ .Alternate = GPIO_AF7_SDMMC1
+static const stm32h7_gpio_config gpioc_af12 = {
+ .regs = GPIOC,
+ .config = {
+ .Pin = GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12,
+ .Alternate = GPIO_AF12_SDMMC1
+static const stm32h7_gpio_config gpioc_af8 = {
+ .regs = GPIOC,
+ .config = {
+ .Pin = GPIO_PIN_6 | GPIO_PIN_7,
+ .Alternate = GPIO_AF8_SDMMC1
+static const stm32h7_gpio_config gpiod = {
+ .regs = GPIOD,
+ .config = {
+ .Pin = GPIO_PIN_2,
+void
+HAL_SD_MspInit(SD_HandleTypeDef *hsd)
+ stm32h7_clk_enable(STM32H7_MODULE_SDMMC1);
+ stm32h7_gpio_init(&gpiob);
+ stm32h7_gpio_init(&gpioc_af12);
+ stm32h7_gpio_init(&gpioc_af8);
+ stm32h7_gpio_init(&gpiod);
+ __HAL_RCC_SDMMC1_FORCE_RESET();
+ __HAL_RCC_SDMMC1_RELEASE_RESET();
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
index 80e13472c8..5b3ecc6a89 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
@@ -417,6 +417,7 @@ source:
- bsps/arm/stm32h7/start/stm32h7-config-per.c
- bsps/arm/stm32h7/start/stm32h7-config-pwr.c
- bsps/arm/stm32h7/start/stm32h7-hal-eth.c
+- bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c
- bsps/arm/stm32h7/start/stm32h7-hal-uart.c
- bsps/arm/stm32h7/start/stm32h7-hal.c
- bsps/arm/stm32h7/start/system_stm32h7xx.c
2.26.2
