[PATCH v5 1/2] covoar: Fix NOP execution marking
Thu Mar 25 19:38:00 UTC 2021
On Thu, Mar 25, 2021 at 10:05 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 25, 2021 at 10:42 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Mar 18, 2021 at 12:05 PM Alex White <alex.white at oarcorp.com> wrote:
>> > Some NOP instructions were not being marked as executed because they
>> > are located at the end of uncovered ranges. This has been fixed.
>> >  tester/covoar/CoverageMapBase.cc  |  10 +++
>> >  tester/covoar/CoverageMapBase.h   |   4 ++
>> >  tester/covoar/DesiredSymbols.cc   |  38 +++++++++--
>> >  tester/covoar/DesiredSymbols.h    |  11 ++-
>> >  tester/covoar/ExecutableInfo.cc   |   2 +-
>> >  tester/covoar/ExecutableInfo.h    |   4 ++
>> >  tester/covoar/ObjdumpProcessor.cc | 109 +++++++++++++++++++++++-------
>> >  7 files changed, 142 insertions(+), 36 deletions(-)
>> > diff --git a/tester/covoar/CoverageMapBase.cc b/tester/covoar/CoverageMapBase.cc
>> > index ad0080d..6ca5cf7 100644
>> > --- a/tester/covoar/CoverageMapBase.cc
>> > +++ b/tester/covoar/CoverageMapBase.cc
>> > @@ -142,6 +142,11 @@ namespace Coverage {
>> >      return size;
>> > +  uint32_t CoverageMapBase::getSizeOfRange( size_t index ) const
>> > +    return Ranges.at(index).size();
>> >    bool CoverageMapBase::getBeginningOfInstruction(
>> >      uint32_t  address,
>> >      uint32_t* beginning
>> > @@ -178,6 +183,11 @@ namespace Coverage {
>> >      return Ranges.front().lowAddress;
>> > +  uint32_t CoverageMapBase::getLowAddressOfRange( size_t index ) const
>> > +    return Ranges.at(index).lowAddress;
>> >    bool CoverageMapBase::getRange( uint32_t address, AddressRange& range ) const
>> >      for ( auto r : Ranges ) {
>> > diff --git a/tester/covoar/CoverageMapBase.h b/tester/covoar/CoverageMapBase.h
>> > index 6ad76d3..a58c696 100644
>> > --- a/tester/covoar/CoverageMapBase.h
>> > +++ b/tester/covoar/CoverageMapBase.h
>> > @@ -156,6 +156,8 @@ namespace Coverage {
>> >      int32_t getFirstLowAddress() const;
>> > +    uint32_t getLowAddressOfRange( size_t index ) const;
>> >       *  This method returns true and sets the address range if
>> >       *  the address falls with the bounds of an address range
>> > @@ -177,6 +179,8 @@ namespace Coverage {
>> >      uint32_t getSize() const;
>> > +    uint32_t getSizeOfRange( size_t index ) const;
>> >       *  This method returns the address of the beginning of the
>> >       *  instruction that contains the specified address.
>> > diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
>> > index b9a5bb7..c97b25c 100644
>> > --- a/tester/covoar/DesiredSymbols.cc
>> > +++ b/tester/covoar/DesiredSymbols.cc
>> > @@ -142,7 +142,7 @@ namespace Coverage {
>> >        CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
>> >        if (theCoverageMap)
>> > -        // Increment the total sizeInBytes byt the bytes in the symbol
>> > +        // Increment the total sizeInBytes by the bytes in the symbol
>> >          stats.sizeInBytes += s.second.stats.sizeInBytes;
>> >          // Now scan through the coverage map of this symbol.
>> > @@ -202,6 +202,26 @@ namespace Coverage {
>> >          uint32_t count;
>> >          // Mark NOPs as executed
>> > +        a = s.second.stats.sizeInBytes - 1;
>> > +        count = 0;
>> > +        while (a > 0) {
>> > +          if (theCoverageMap->isStartOfInstruction( a )) {
>> > +            break;
>> > +          count++;
>> > +          if (theCoverageMap->isNop( a )) {
>> > +            for (la = a; la < (a + count); la++) {
>> > +              theCoverageMap->setWasExecuted( la );
>> > +            count = 0;
>> > +          a--;
>> >          endAddress = s.second.stats.sizeInBytes - 1;
>> >          a = 0;
>> >          while (a < endAddress) {
>> > @@ -223,12 +243,13 @@ namespace Coverage {
>> >                ha++;
>> >                if ( ha >= endAddress )
>> >                  break;
>> > -            } while ( !theCoverageMap->isStartOfInstruction( ha ) );
>> > +            } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
>> > +                      theCoverageMap->isNop( ha ) );
>> >            a = ha;
>> > -        endAddress = s.second.stats.sizeInBytes - 1;
>> > +        endAddress = s.second.stats.sizeInBytesWithoutNops - 1;
>> >          a = 0;
>> >          while (a <= endAddress) {
>> >            // If an address was NOT executed, find consecutive unexecuted
>> > @@ -316,7 +337,8 @@ namespace Coverage {
>> >    void DesiredSymbols::createCoverageMap(
>> >      const std::string& exefileName,
>> >      const std::string& symbolName,
>> > -    uint32_t           size
>> > +    uint32_t           size,
>> > +    uint32_t           sizeWithoutNops
>> >      CoverageMapBase* aCoverageMap;
>> > @@ -354,9 +376,10 @@ namespace Coverage {
>> >                    << '/' << size << ')'
>> >                    << std::endl;
>> > -        if ( itr->second.stats.sizeInBytes < size )
>> > +        if ( itr->second.stats.sizeInBytes < size ) {
>> >            itr->second.stats.sizeInBytes = size;
>> > -        else
>> > +          itr->second.stats.sizeInBytesWithoutNops = sizeWithoutNops;
>> > +        } else
>> >            size = itr->second.stats.sizeInBytes;
>> > @@ -376,6 +399,7 @@ namespace Coverage {
>> >        itr->second.unifiedCoverageMap = aCoverageMap;
>> > @@ -479,7 +503,7 @@ namespace Coverage {
>> >      // are the same size.
>> >      // Changed from ERROR msg to INFO, because size mismatch is not
>> >      // treated as error anymore. 2015-07-20
>> > -    uint32_t dMapSize = sinfo.stats.sizeInBytes;
>> > +    uint32_t dMapSize = sinfo.stats.sizeInBytesWithoutNops;
>> >      uint32_t sBaseAddress = sourceCoverageMap->getFirstLowAddress();
>> >      uint32_t sMapSize = sourceCoverageMap->getSize();
>> >      if (dMapSize != 0 && dMapSize != sMapSize) {
>> > diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
>> > index 5c45af8..367ca95 100644
>> > --- a/tester/covoar/DesiredSymbols.h
>> > +++ b/tester/covoar/DesiredSymbols.h
>> > @@ -57,7 +57,12 @@ namespace Coverage {
>> >      uint32_t sizeInBytes;
>> > -     *  This member contains the size in Bytes.
>> > +     *  This member contains the size in Bytes not accounting for NOPs.
>> > +    uint32_t sizeInBytesWithoutNops;
>> > +     *  This member contains the size in instructions.
>> >      uint32_t sizeInInstructions;
>> > @@ -100,6 +105,7 @@ namespace Coverage {
>> >         branchesNeverTaken(0),
>> >         branchesNotExecuted(0),
>> >         sizeInBytes(0),
>> > +       sizeInBytesWithoutNops(0),
>> >         sizeInInstructions(0),
>> >         uncoveredBytes(0),
>> >         uncoveredInstructions(0),
>> > @@ -227,7 +233,8 @@ namespace Coverage {
>> >      void createCoverageMap(
>> > -      uint32_t           size
>> > +      uint32_t           size,
>> > diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
>> > index c593e1d..ddd2987 100644
>> > --- a/tester/covoar/ExecutableInfo.cc
>> > +++ b/tester/covoar/ExecutableInfo.cc
>> > @@ -127,7 +127,7 @@ namespace Coverage {
>> >      CoverageMaps::iterator cmi = coverageMaps.find( symbolName );
>> >      if ( cmi == coverageMaps.end() )
>> > -      throw rld::error (symbolName, "ExecutableInfo::findCoverageMap");
>> > +      throw CoverageMapNotFoundError(symbolName);
>> >      return *(cmi->second);
>> > diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
>> > index dcb4dcb..ab74b7f 100644
>> > --- a/tester/covoar/ExecutableInfo.h
>> > +++ b/tester/covoar/ExecutableInfo.h
>> > @@ -29,6 +29,10 @@ namespace Coverage {
>> >    public:
>> > +    class CoverageMapNotFoundError : public std::runtime_error {
>> > +      using std::runtime_error::runtime_error;
>> >       *  This method constructs an ExecutableInfo instance.
>> > diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
>> > index 56ee219..0647ff9 100644
>> > --- a/tester/covoar/ObjdumpProcessor.cc
>> > +++ b/tester/covoar/ObjdumpProcessor.cc
>> > @@ -32,35 +32,92 @@ namespace Coverage {
>> >      ObjdumpProcessor::objdumpLines_t instructions
>> >      // Find the symbol's coverage map.
>> > -    CoverageMapBase& coverageMap = executableInfo->findCoverageMap( symbolName );
>> > -    uint32_t lowAddress = coverageMap.getFirstLowAddress();
>> > -    uint32_t size = coverageMap.getSize();
>> > -    uint32_t highAddress = lowAddress + size - 1;
>> > -    // If there are NOT already saved instructions, save them.
>> > -    SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
>> > -    if (symbolInfo->instructions.empty()) {
>> > -      symbolInfo->sourceFile = executableInfo;
>> > -      symbolInfo->baseAddress = lowAddress;
>> > -      symbolInfo->instructions = instructions;
>> > +    try {
>> > +      CoverageMapBase& coverageMap = executableInfo->findCoverageMap(symbolName);
>> > -    // Add the symbol to this executable's symbol table.
>> > -    SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
>> > -    theSymbolTable->addSymbol(
>> > -      symbolName, lowAddress, highAddress - lowAddress + 1
>> > +      uint32_t firstInstructionAddress = UINT32_MAX;
>> > -    // Mark the start of each instruction in the coverage map.
>> > -    for (auto& instruction : instructions) {
>> > -      coverageMap.setIsStartOfInstruction( instruction.address );
>> > +      // Find the address of the first instruction.
>> > +      for (auto& line : instructions) {
>> > +        if (!line.isInstruction) {
>> > +          continue;
>> > +        firstInstructionAddress = line.address;
>> > +        break;
>> This is a poorly written loop. Anytime you use continue/break to
>> control the loop iteration, something is going awry. You can write
>> this code equivalently without any continue or break.
> This loop is very deliberately constructed not to be a for loop because
> you need the ability to break at different points to debug issues. Alex
> and I spent hours in this loop debugging which I think would have
> been more difficult to debug if all the conditions were in a for loop.
> This loop was written to explicitly have breakpoints for various
> conditions.
> There have been multiple issues with the information reported with
> size/length being at the top of that list. Before Alex found the source
> of that (not covoar), it resulted in an infinite loop.
> I suppose it can be changed to a for loop as purer academically but
> it loses significantly on ability to set breakpoints and debug if there
> ever is an issue again.
> Are you willing to make that trade?
You know that what we debug is often much uglier than what we publish.
At least, simplify the logic to let the loop work for you.
  if ( line.isInstruction ) {
    break;
Using continue/break to control loops is antithetical to using loops,
and probably doesn't do the compiler any good.
>> > +          continue;
>> > +        break;
>> > +      if (firstInstructionAddress == UINT32_MAX) {
>> > +        std::ostringstream what;
>> > +        what << "Could not find first instruction address for symbol "
>> > +          << symbolName << " in " << executableInfo->getFileName();
>> > +        throw rld::error( what, "Coverage::finalizeSymbol" );
>> > +      int rangeIndex;
>> > +      uint32_t lowAddress = UINT32_MAX;
>> > +      for (rangeIndex = 0; ; rangeIndex++) {
>> > +        lowAddress = coverageMap.getLowAddressOfRange(rangeIndex);
>> > +        if (firstInstructionAddress == lowAddress) {
>> > +          break;
>> ditto... if you're goin to break the loop on this condition, why not
>> use this in your for loop?
>> for (rangeIndex = 0; firstInstructionAddress != lowAddress ; rangeIndex++) {
>> > -    // Create a unified coverage map for the symbol.
>> > -    SymbolsToAnalyze->createCoverageMap(
>> > -      executableInfo->getFileName().c_str(), symbolName, size
>> > +      uint32_t sizeWithoutNops = coverageMap.getSizeOfRange(rangeIndex);
>> > +      uint32_t size = sizeWithoutNops;
>> > +      uint32_t highAddress = lowAddress + size - 1;
>> > +      uint32_t computedHighAddress = highAddress;
>> > +      // Find the high address as reported by the address of the last NOP
>> > +      // instruction. This ensures that NOPs get marked as executed later.
>> > +      for (auto instruction = instructions.rbegin();
>> > +          instruction != instructions.rend();
>> > +          instruction++) {
>> > +        if (instruction->isInstruction) {
>> > +          if (instruction->isNop) {
>> > +            computedHighAddress = instruction->address + instruction->nopSize;
>> > +          break;
>> Here too.
>> > +      if (highAddress != computedHighAddress) {
>> > +        std::cerr << "Function's high address differs between DWARF and objdump: "
>> > +          << symbolName << " (0x" << std::hex << highAddress << " and 0x"
>> > +          << computedHighAddress - 1 << ")" << std::dec << std::endl;
>> > +        size = computedHighAddress - lowAddress;
>> > +      // If there are NOT already saved instructions, save them.
>> > +      SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
>> > +      if (symbolInfo->instructions.empty()) {
>> > +        symbolInfo->sourceFile = executableInfo;
>> > +        symbolInfo->baseAddress = lowAddress;
>> > +        symbolInfo->instructions = instructions;
>> > +      // Add the symbol to this executable's symbol table.
>> > +      SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
>> > +      theSymbolTable->addSymbol(
>> > +        symbolName, lowAddress, highAddress - lowAddress + 1
>> > +      // Mark the start of each instruction in the coverage map.
>> > +      for (auto& instruction : instructions) {
>> > +        coverageMap.setIsStartOfInstruction( instruction.address );
>> > +      // Create a unified coverage map for the symbol.
>> > +      SymbolsToAnalyze->createCoverageMap(
>> > +        executableInfo->getFileName().c_str(), symbolName, size, sizeWithoutNops
>> > +    } catch (const ExecutableInfo::CoverageMapNotFoundError& e) {
>> > +      // Allow execution to continue even if a coverage map could not be
>> > +      // found.
>> > +      std::cerr << "Coverage map not found for symbol " << e.what()
>> > +        << std::endl;
>> >    ObjdumpProcessor::ObjdumpProcessor()
>> > 2.27.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
