[PATCH v7 0/2] Fix NOP recognition
Alex White
alex.white at oarcorp.com
Fri Mar 26 16:40:10 UTC 2021
v7:
- Add comment clarifying `using` declaration in CoverageMapNotFoundError class
v6:
- Consolidate loop conditionals in Coverage::finalizeSymbol()
v5:
- Fix missing std::dec at the end of error message printing in
v4:
- Add specialized CoverageMapNotFoundError exception class to ExecutableInfo
- Catch ExecutableInfo::CoverageMapNotFoundError in Coverage::finalizeSymbol()
v3:
- Fix double increment of rangeIndex in Coverage::finalizeSymbol()
v2:
- Fix leftover debugging code in Coverage::finalizeSymbol()
This patch set fixes a couple cases where NOP instructions were showing up as unexecuted in coverage reports.
Alex White (2):
covoar: Fix NOP execution marking
covoar/Target_i386: Add NOP patterns
tester/covoar/CoverageMapBase.cc | 10 +++
tester/covoar/CoverageMapBase.h | 4 ++
tester/covoar/DesiredSymbols.cc | 38 +++++++++--
tester/covoar/DesiredSymbols.h | 11 +++-
tester/covoar/ExecutableInfo.cc | 2 +-
tester/covoar/ExecutableInfo.h | 5 ++
tester/covoar/ObjdumpProcessor.cc | 105 ++++++++++++++++++++++--------
tester/covoar/Target_i386.cc | 9 +++
8 files changed, 148 insertions(+), 36 deletions(-)
2.27.0
