[PATCH] coverage/symbol-sets.ini : Add libtrace
Gedare Bloom
gedare at rtems.org
Sat Mar 27 14:46:34 UTC 2021
On Fri, Mar 12, 2021 at 10:17 AM Alex White <alex.white at oarcorp.com> wrote:
> tester/rtems/testing/coverage/symbol-sets.ini | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
> index 9617dd8..52e25ff 100644
> --- a/tester/rtems/testing/coverage/symbol-sets.ini
> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> @@ -29,7 +29,7 @@
> [symbol-sets]
> -sets = score,rtems,sapi,posix,librfs,libpipe,libdosfs,libimfs,libjffs2,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libuntar,libblock,libcrypt,libmd,libstdthreads
> +sets = score,rtems,sapi,posix,librfs,libpipe,libdosfs,libimfs,libjffs2,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libuntar,libblock,libcrypt,libmd,libstdthreads,libtrace
ok, but this is really ugly. is the comma-separated list with no
whitespace mandatory, or can it be reformatted in a follow-up patch?
> [libraries]
> score = @BUILD-TARGET@/@BSP@/cpukit/score/src
> @@ -76,4 +76,5 @@ libblock = @BUILD-TARGET@/@BSP@/cpukit/libblock/src
> libcrypt = @BUILD-TARGET@/@BSP@/cpukit/libcrypt
> libmd = @BUILD-TARGET@/@BSP@/cpukit/libmd
> libstdthreads = @BUILD-TARGET@/@BSP@/cpukit/libstdthreads
> +libtrace = @BUILD-TARGET@/@BSP@/cpukit/libtrace/record
> #zlib = @BUILD-TARGET@/@BSP@/cpukit/zlib
> 2.27.0
> devel mailing list
> devel at rtems.org
