[Beagle BSP] How to run all tests on a Beaglebone Black in an automated way
Ahamed Husni
ahamedhusni73 at gmail.com
Sat Mar 27 19:16:25 UTC 2021
Hi,
I ran the hello program on the BBB using a bootable SD card. The SD card
has two partitions.
1. BOOT - primary, bootable, FAT32
2. ROOT - primary, ext4
The BOOT partition has the following files.
1. uEnv.txt
2. rtems-app.img
3. Device Tree Blob (am335x-boneblack.dtb)
I want to run all the tests on the BBB. Is there any other way to do this?
You have to get the BBB to fetch exes from a ftftp server (provided inside
> rtems-test) and provide some automated power control to the board.
> - Dr. Joel (in Discord)
Best regards,
Husni.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210328/009b42bb/attachment.html>
