[PATCH rtems 04/18] removed direct access to ring-size / ring-available from BSD driver
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:36 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Update #4344
bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 6 +++---
.../beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 14 +++++++++-----
2 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
index 9d23d22898..1d920df342 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -108,10 +108,10 @@
/* Compile-time debugging features */
/* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing */
-#define MVETH_TESTING
+#undef MVETH_TESTING
/* Enable debugging messages and some support routines (dump rings etc.) */
-#define MVETH_DEBUG
+#undef MVETH_DEBUG
/* Ring sizes */
@@ -1726,7 +1726,7 @@ register MvEthTxDesc d;
mp->d_tx_t = d;
mp->avail += rval;
- return rval;
+ return mp->avail;
int
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
index 3f85e2c78a..e8819be6bf 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
@@ -135,6 +135,7 @@
/* Enable Hardware Snooping; if this is disabled (undefined),
* cache coherency is maintained by software.
+#undef ENABLE_HW_SNOOPING
@@ -543,6 +544,8 @@ typedef uint32_t Dma_addr_t;
/* stuff needed for bsdnet support */
struct mveth_bsdsupp {
int oif_flags; /* old / cached if_flags */
+ int tx_ring_size;
+ int rx_ring_size;
struct mveth_softc {
@@ -665,6 +668,9 @@ struct mveth_private *mp;
+ theMvEths[unit-1].bsd.tx_ring_size = tx_ring_size;
+ theMvEths[unit-1].bsd.rx_ring_size = rx_ring_size;
/* mark as used */
ifp->if_init = (void*)(-1);
@@ -1172,6 +1178,7 @@ static void mveth_daemon(void *arg)
struct mveth_softc *sc;
struct ifnet *ifp;
rtems_event_set evs;
+int avail;
for (;;) {
rtems_bsdnet_event_receive( 7, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
evs &= 7;
@@ -1211,13 +1218,10 @@ rtems_event_set evs;
/* free tx chain */
- if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && BSP_mve_swipe_tx(sc->pvt) ) {
+ if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && (avail = BSP_mve_swipe_tx(sc->pvt)) > 0 ) {
ifp->if_flags &= ~IFF_OACTIVE;
-#warning FIXME
-#ifdef BSDBSD
- if ( TX_AVAILABLE_RING_SIZE(sc->pvt) == sc->pvt->avail )
+ if ( sc->bsd.tx_ring_size == avail )
ifp->if_timer = 0;
-#endif
mveth_start(ifp);
if ( (MV643XX_ETH_IRQ_RX_DONE & x) )
2.26.2
