[PATCH rtems-libbsd 5/5] mv643xx_nexus.c: more use of if_xxx() access functions
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:30:15 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
avoid using struct members directly.
Update #4345
rtemsbsd/sys/dev/mve/mv643xx_nexus.c | 27 ++++++++++++++-------------
1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
index ef84200d..44a22197 100644
--- a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
+++ b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
@@ -346,7 +346,7 @@ mve_stop(struct mve_enet_softc *sc)
static void
mve_set_filters(struct ifnet *ifp)
-struct mve_enet_softc *sc = (struct mve_enet_softc*)ifp->if_softc;
+struct mve_enet_softc *sc = (struct mve_enet_softc*) if_getsoftc( ifp );
int iff = if_getflags(ifp);
struct ifmultiaddr *ifma;
unsigned char *lladdr;
@@ -625,7 +625,7 @@ int promisc;
static void
mve_start(struct ifnet *ifp)
mve_lock( sc, "mve_start" );
if_setdrvflagbits(ifp, IFF_DRV_OACTIVE, 0);
mve_unlock( sc, "mve_start" );
@@ -635,7 +635,7 @@ struct mve_enet_softc *sc = (struct mve_enet_softc*)ifp->if_softc;
static int
mve_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
struct ifreq *ifr = (struct ifreq *)data;
int err = 0;
int f, df;
@@ -744,7 +744,7 @@ int lowLevelMediaStatus;
static int
mve_media_change(struct ifnet *ifp)
-struct mve_enet_softc *sc = (struct mve_enet_softc *)ifp->if_softc;
struct mii_data *mii = sc->mii_softc;
int err;
@@ -764,7 +764,7 @@ int err;
static void
mve_media_status(struct ifnet *ifp, struct ifmediareq *ifmr)
#ifdef MVETH_DEBUG
@@ -803,14 +803,15 @@ int tx_q_size = MV643XX_TX_QUEUE_SIZE;
mtx_init( &sc->mtx, device_get_nameunit( sc->dev ), MTX_NETWORK_LOCK, MTX_RECURSE );
callout_init_mtx( &sc->wdCallout, &sc->mtx, 0 );
- ifp->if_softc = sc;
- if_initname(ifp, device_get_name(dev), unit);
- ifp->if_init = mve_init;
- ifp->if_ioctl = mve_ioctl;
- ifp->if_start = mve_start;
- if_setflags(ifp, (IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX) );
- sc->oif_flags = if_getflags(ifp);
- if_setsendqlen( ifp, tx_q_size );
+ if_setsoftc ( ifp, sc );
+ if_initname ( ifp, device_get_name(dev), unit);
+ if_setinitfn ( ifp, mve_init );
+ if_setioctlfn ( ifp, mve_ioctl );
+ if_setstartfn ( ifp, mve_start );
+ if_setflags ( ifp, (IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX) );
+ sc->oif_flags = if_getflags( ifp );
+ if_setsendqlen ( ifp, tx_q_size );
if_setsendqready( ifp );
mp = BSP_mve_create(
2.26.2
