[PATCH rtems-docs v3] networking: Rename to legacy networking
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 30 01:41:06 UTC 2021
On Fri, Mar 26, 2021 at 5:26 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 26, 2021, 5:53 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> Hi Joel,
>> On Fri, Mar 26, 2021, 16:46 Joel Sherrill <joel.sherrill at gmail.com> wrote:
>>> I thought I said this looked good on the first round.
>> In this version of the patch I send networking to bottom of the index in coverpage.
> Sorry. That was a subtle change. Thanks for making it.
Ok to push?
>>> My only question was whether you want to update it the minimum to point to the legacy stack as a separate package. But that should be a follow up patch.
>> Yes, I'll add a note in the docs about the separate package and how to build it manually and with RSB. I'll send that as a separate patch as you mentioned.
> Good enough. Thanks to you the legacy network stack is not as dead as it could be. Since you did this fantastic piece of work to put it in a separate repository, we just want the documentation to reflect that.
>> Best regards,
>> Vijay
>>> --joel
>>> On Fri, Mar 26, 2021 at 3:48 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>>>> Ping :)
>>>> On Tue, Mar 23, 2021 at 2:04 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>>>> >  book/index_book.rst                                         | 2 +-
>>>> >  {networking => legacy-networking}/command.rst               | 0
>>>> >  {networking => legacy-networking}/conf.py                   | 6 +++---
>>>> >  {networking => legacy-networking}/dec_21140.rst             | 0
>>>> >  {networking => legacy-networking}/index.rst                 | 2 +-
>>>> >  {networking => legacy-networking}/network_servers.rst       | 0
>>>> >  .../network_task_structure.rst                              | 0
>>>> >  {networking => legacy-networking}/networking_driver.rst     | 0
>>>> >  {networking => legacy-networking}/preface.rst               | 0
>>>> >  {networking => legacy-networking}/testing_the_driver.rst    | 0
>>>> >  .../using_networking_rtems_app.rst                          | 0
>>>> >  {networking => legacy-networking}/wscript                   | 0
>>>> >  wscript                                                     | 4 ++--
>>>> >  13 files changed, 7 insertions(+), 7 deletions(-)
>>>> >  rename {networking => legacy-networking}/command.rst (100%)
>>>> >  rename {networking => legacy-networking}/conf.py (58%)
>>>> >  rename {networking => legacy-networking}/dec_21140.rst (100%)
>>>> >  rename {networking => legacy-networking}/index.rst (92%)
>>>> >  rename {networking => legacy-networking}/network_servers.rst (100%)
>>>> >  rename {networking => legacy-networking}/network_task_structure.rst (100%)
>>>> >  rename {networking => legacy-networking}/networking_driver.rst (100%)
>>>> >  rename {networking => legacy-networking}/preface.rst (100%)
>>>> >  rename {networking => legacy-networking}/testing_the_driver.rst (100%)
>>>> >  rename {networking => legacy-networking}/using_networking_rtems_app.rst (100%)
>>>> >  rename {networking => legacy-networking}/wscript (100%)
>>>> > diff --git a/book/index_book.rst b/book/index_book.rst
>>>> > index 8282006..afe15a1 100644
>>>> > --- a/book/index_book.rst
>>>> > +++ b/book/index_book.rst
>>>> > @@ -23,7 +23,7 @@ Table of Contents
>>>> >         cpu_supplement/index.rst
>>>> >         develenv/index.rst
>>>> >         filesystem/index.rst
>>>> > -       networking/index.rst
>>>> >         porting/index.rst
>>>> >         posix1003_1/index.rst
>>>> >         posix_users/index.rst
>>>> > +       legacy_networking/index.rst
>>>> > diff --git a/networking/command.rst b/legacy-networking/command.rst
>>>> > similarity index 100%
>>>> > rename from networking/command.rst
>>>> > rename to legacy-networking/command.rst
>>>> > diff --git a/networking/conf.py b/legacy-networking/conf.py
>>>> > similarity index 58%
>>>> > rename from networking/conf.py
>>>> > rename to legacy-networking/conf.py
>>>> > index 1c129bc..98a06b6 100644
>>>> > --- a/networking/conf.py
>>>> > +++ b/legacy-networking/conf.py
>>>> > @@ -3,12 +3,12 @@ sys.path.insert(0, os.path.abspath('../common/'))
>>>> >  from conf import *
>>>> > -project = "RTEMS Networking User Manual"
>>>> > +project = "RTEMS Legacy Networking User Manual"
>>>> >  latex_documents = [
>>>> >      ('index',
>>>> > -     'networking.tex',
>>>> > -     u'RTEMS Networking User Manual',
>>>> > +     'legacy-networking.tex',
>>>> > +     u'RTEMS Legacy Networking User Manual',
>>>> >       u'RTEMS Documentation Project',
>>>> >       'manual'),
>>>> > diff --git a/networking/dec_21140.rst b/legacy-networking/dec_21140.rst
>>>> > rename from networking/dec_21140.rst
>>>> > rename to legacy-networking/dec_21140.rst
>>>> > diff --git a/networking/index.rst b/legacy-networking/index.rst
>>>> > similarity index 92%
>>>> > rename from networking/index.rst
>>>> > rename to legacy-networking/index.rst
>>>> > index f56a60d..b85119d 100644
>>>> > --- a/networking/index.rst
>>>> > +++ b/legacy-networking/index.rst
>>>> > @@ -5,7 +5,7 @@
>>>> >  .. highlight:: c
>>>> > -RTEMS Network User Manual (|version|).
>>>> > +RTEMS Legacy Network User Manual (|version|).
>>>> >  .. topic:: Copyrights and License
>>>> > diff --git a/networking/network_servers.rst b/legacy-networking/network_servers.rst
>>>> > rename from networking/network_servers.rst
>>>> > rename to legacy-networking/network_servers.rst
>>>> > diff --git a/networking/network_task_structure.rst b/legacy-networking/network_task_structure.rst
>>>> > rename from networking/network_task_structure.rst
>>>> > rename to legacy-networking/network_task_structure.rst
>>>> > diff --git a/networking/networking_driver.rst b/legacy-networking/networking_driver.rst
>>>> > rename from networking/networking_driver.rst
>>>> > rename to legacy-networking/networking_driver.rst
>>>> > diff --git a/networking/preface.rst b/legacy-networking/preface.rst
>>>> > rename from networking/preface.rst
>>>> > rename to legacy-networking/preface.rst
>>>> > diff --git a/networking/testing_the_driver.rst b/legacy-networking/testing_the_driver.rst
>>>> > rename from networking/testing_the_driver.rst
>>>> > rename to legacy-networking/testing_the_driver.rst
>>>> > diff --git a/networking/using_networking_rtems_app.rst b/legacy-networking/using_networking_rtems_app.rst
>>>> > rename from networking/using_networking_rtems_app.rst
>>>> > rename to legacy-networking/using_networking_rtems_app.rst
>>>> > diff --git a/networking/wscript b/legacy-networking/wscript
>>>> > rename from networking/wscript
>>>> > rename to legacy-networking/wscript
>>>> > diff --git a/wscript b/wscript
>>>> > index ce644f8..0b1c368 100644
>>>> > --- a/wscript
>>>> > +++ b/wscript
>>>> > @@ -32,11 +32,11 @@ build_all = ['user',
>>>> >               'posix-compliance',
>>>> >               'eng',
>>>> >               'filesystem',
>>>> > -             'networking',
>>>> >               'shell',
>>>> >               'cpu-supplement',
>>>> >               'develenv',
>>>> > -             'eclipse']
>>>> > +             'eclipse',
>>>> > +             'legacy-networking']
>>>> >  building = build_all
>>>> > 2.26.2
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
