[PATCH rtems-net-legacy 1/2] Remove RTEMS_NETWORKING checks
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 30 01:41:47 UTC 2021
ping :)
On Tue, Mar 23, 2021 at 2:10 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> * Remove nfsclient wscript and build from netlegacy.py
>  bsps/powerpc/mpc55xxevb/net/smsc9218i.c |  4 +--
>  libmisc/dummy-networking.c              | 44 ++++++++++++-------------
>  netlegacy.py                            | 17 +++++++++-
>  nfsclient/wscript                       |  1 +
>  telnetd/telnetd.c                       |  4 ---
>  wscript                                 |  2 +-
>  6 files changed, 41 insertions(+), 31 deletions(-)
> diff --git a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> index d88aa8a..384f9cd 100644
> --- a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> +++ b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> @@ -24,7 +24,7 @@
>  #include <mpc55xx/regs.h>
> -#if defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU)
> +#if defined(MPC55XX_HAS_SIU)
>  #include <machine/rtems-bsd-kernel-space.h>
> @@ -2121,4 +2121,4 @@ int smsc9218i_attach_detach(
>    return 0;
> -#endif /* defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU) */
> +#endif /* defined(MPC55XX_HAS_SIU) */
> diff --git a/libmisc/dummy-networking.c b/libmisc/dummy-networking.c
> index 379e23e..b7f15c8 100644
> --- a/libmisc/dummy-networking.c
> +++ b/libmisc/dummy-networking.c
> @@ -16,27 +16,25 @@
>  #include <rtems.h>
>  /* Loopback Network Configuration */
> -  #include <rtems/rtems_bsdnet.h>
> -  #include <sys/socket.h>
> -  #include <netinet/in.h>
> +#include <rtems/rtems_bsdnet.h>
> +#include <sys/socket.h>
> +#include <netinet/in.h>
> -  struct rtems_bsdnet_config rtems_bsdnet_config = {
> -      NULL,                   /* Network interface */
> -      NULL,                   /* Use fixed network configuration */
> -      0,                      /* Default network task priority */
> -      0,                      /* Default mbuf capacity */
> -      0,                      /* Default mbuf cluster capacity */
> -      "testSystem",           /* Host name */
> -      "nowhere.com",          /* Domain name */
> -      "127.0.0.1",            /* Gateway */
> -      "127.0.0.1",            /* Log host */
> -      {"127.0.0.1" },         /* Name server(s) */
> -      {"127.0.0.1" },         /* NTP server(s) */
> -      1,                      /* sb_efficiency */
> -      0,                      /* udp_tx_buf_size */
> -      0,                      /* udp_rx_buf_size */
> -      0,                      /* tcp_tx_buf_size */
> -      0                       /* tcp_rx_buf_size */
> -#endif
> +struct rtems_bsdnet_config rtems_bsdnet_config = {
> +    NULL,                   /* Network interface */
> +    NULL,                   /* Use fixed network configuration */
> +    0,                      /* Default network task priority */
> +    0,                      /* Default mbuf capacity */
> +    0,                      /* Default mbuf cluster capacity */
> +    "testSystem",           /* Host name */
> +    "nowhere.com",          /* Domain name */
> +    "127.0.0.1",            /* Gateway */
> +    "127.0.0.1",            /* Log host */
> +    {"127.0.0.1" },         /* Name server(s) */
> +    {"127.0.0.1" },         /* NTP server(s) */
> +    1,                      /* sb_efficiency */
> +    0,                      /* udp_tx_buf_size */
> +    0,                      /* udp_rx_buf_size */
> +    0,                      /* tcp_tx_buf_size */
> +    0                       /* tcp_rx_buf_size */
> diff --git a/netlegacy.py b/netlegacy.py
> index 0889548..0e69076 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -54,6 +54,12 @@ def build(bld):
>                     for s in os.listdir('./pppd') if s[-2:] == '.c']
>      telnetd_source = [os.path.join('./telnetd', s)
>                        for s in os.listdir('telnetd') if s[-2:] == '.c']
> +    nfs_source = []
> +    for root, dirs, files in os.walk('./nfsclient'):
> +        for name in files:
> +            if name[-2:] == '.c':
> +                src_root = root.split('/')[2]
> +                nfs_source.append(os.path.join('./nfsclient', src_root, name))
>      bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> @@ -66,6 +72,7 @@ def build(bld):
>                           './bsps/include'])
>      arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
>                                              bld.env.RTEMS_ARCH_BSP)
> +    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
>      include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
>                                                       arch_lib_path)))
> @@ -73,6 +80,8 @@ def build(bld):
>                                                       'include')))
>      include_path.append('./bsps/include/libchip')
> +    bld.read_stlib('rtemsbsp', paths=[lib_path])
>      if bsp in bsp_dirs:
>          include_path.extend(bsp_dirs[bsp])
> @@ -107,8 +116,14 @@ def build(bld):
>                use='networking',
>                source=telnetd_source)
> +    bld.stlib(target='nfs',
> +              features='c',
> +              includes=ip,
> +              use=['rtemsbsp', 'networking'],
> +              source=nfs_source)
>      bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> +                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
>      bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
>                                     'include', 'libchip'),
>                        [os.path.join('./bsps/include/libchip/', f)
> diff --git a/nfsclient/wscript b/nfsclient/wscript
> index bc2f994..c0fe420 100644
> --- a/nfsclient/wscript
> +++ b/nfsclient/wscript
> @@ -52,5 +52,6 @@ def build(bld):
>                features='c',
>                cflags=['-O2', '-g'],
>                includes=include_path,
> +              use=['networking'],
>                source=source_files)
>      bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
> diff --git a/telnetd/telnetd.c b/telnetd/telnetd.c
> index b8adec2..3d401ff 100644
> --- a/telnetd/telnetd.c
> +++ b/telnetd/telnetd.c
> @@ -58,9 +58,7 @@
>  #include <rtems/thread.h>
>  #include <rtems/userenv.h>
> -#ifdef RTEMS_NETWORKING
> -#endif
>  #define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
> @@ -401,11 +399,9 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
>    LIST_INIT(&ctx->free_sessions);
>    /* Check priority */
>    if (ctx->config.priority == 0) {
>      ctx->config.priority = rtems_bsdnet_config.network_task_priority;
> -#endif
>      ctx->config.priority = 100;
> diff --git a/wscript b/wscript
> index 07f774d..7af317d 100644
> --- a/wscript
> +++ b/wscript
> @@ -33,7 +33,7 @@ import sys
>  top = '.'
>  rtems_version = "6"
> -subdirs = ['nfsclient', 'testsuites']
> +subdirs = ['testsuites']
>  try:
>      import rtems_waf.rtems as rtems
> 2.26.2
