[PATCH 3/3] covoar: Fix overflow of high PC address
Gedare Bloom
gedare at rtems.org
Tue Mar 30 15:09:26 UTC 2021
looks ok. what happens if the high_pc is 1? Just wondering.
On Tue, Mar 30, 2021 at 8:45 AM Alex White <alex.white at oarcorp.com> wrote:
> ping
> On Fri, Mar 12, 2021 at 11:14 AM Alex White <alex.white at oarcorp.com> wrote:
> > This fixes an integer overflow that would occur if a function's high PC
> > address were zero in the DWARF info.
> > tester/covoar/ExecutableInfo.cc | 5 +++++
> > 1 file changed, 5 insertions(+)
> > diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
> > index 30828a6..7f33f20 100644
> > --- a/tester/covoar/ExecutableInfo.cc
> > +++ b/tester/covoar/ExecutableInfo.cc
> > @@ -71,6 +71,11 @@ namespace Coverage {
> > + // We can't process a zero size function.
> > + if (func.pc_high() == 0) {
> > + continue;
> > createCoverageMap (cu.name(), func.name(),
> > func.pc_low(), func.pc_high() - 1);
> > 2.27.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
