[PATCH rtems-docs v3] networking: Rename to legacy networking
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 15:29:36 UTC 2021
On Tue, Mar 30, 2021 at 7:43 AM Gedare Bloom <gedare at rtems.org> wrote:
> Yes, go ahead with this doco patch.
Thanks. Pushed.
> On Mon, Mar 29, 2021 at 7:41 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > On Fri, Mar 26, 2021 at 5:26 PM Joel Sherrill <joel at rtems.org> wrote:
> > > On Fri, Mar 26, 2021, 5:53 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >> Hi Joel,
> > >> On Fri, Mar 26, 2021, 16:46 Joel Sherrill <joel.sherrill at gmail.com> wrote:
> > >>> I thought I said this looked good on the first round.
> > >> In this version of the patch I send networking to bottom of the index in coverpage.
> > > Sorry. That was a subtle change. Thanks for making it.
> > Ok to push?
> > >>> My only question was whether you want to update it the minimum to point to the legacy stack as a separate package. But that should be a follow up patch.
> > >> Yes, I'll add a note in the docs about the separate package and how to build it manually and with RSB. I'll send that as a separate patch as you mentioned.
> > > Good enough. Thanks to you the legacy network stack is not as dead as it could be. Since you did this fantastic piece of work to put it in a separate repository, we just want the documentation to reflect that.
> > >> Best regards,
> > >> Vijay
> > >>> --joel
> > >>> On Fri, Mar 26, 2021 at 3:48 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >>>> Ping :)
> > >>>> On Tue, Mar 23, 2021 at 2:04 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >>>> > book/index_book.rst | 2 +-
> > >>>> > {networking => legacy-networking}/command.rst | 0
> > >>>> > {networking => legacy-networking}/conf.py | 6 +++---
> > >>>> > {networking => legacy-networking}/dec_21140.rst | 0
> > >>>> > {networking => legacy-networking}/index.rst | 2 +-
> > >>>> > {networking => legacy-networking}/network_servers.rst | 0
> > >>>> > .../network_task_structure.rst | 0
> > >>>> > {networking => legacy-networking}/networking_driver.rst | 0
> > >>>> > {networking => legacy-networking}/preface.rst | 0
> > >>>> > {networking => legacy-networking}/testing_the_driver.rst | 0
> > >>>> > .../using_networking_rtems_app.rst | 0
> > >>>> > {networking => legacy-networking}/wscript | 0
> > >>>> > wscript | 4 ++--
> > >>>> > 13 files changed, 7 insertions(+), 7 deletions(-)
> > >>>> > rename {networking => legacy-networking}/command.rst (100%)
> > >>>> > rename {networking => legacy-networking}/conf.py (58%)
> > >>>> > rename {networking => legacy-networking}/dec_21140.rst (100%)
> > >>>> > rename {networking => legacy-networking}/index.rst (92%)
> > >>>> > rename {networking => legacy-networking}/network_servers.rst (100%)
> > >>>> > rename {networking => legacy-networking}/network_task_structure.rst (100%)
> > >>>> > rename {networking => legacy-networking}/networking_driver.rst (100%)
> > >>>> > rename {networking => legacy-networking}/preface.rst (100%)
> > >>>> > rename {networking => legacy-networking}/testing_the_driver.rst (100%)
> > >>>> > rename {networking => legacy-networking}/using_networking_rtems_app.rst (100%)
> > >>>> > rename {networking => legacy-networking}/wscript (100%)
> > >>>> > diff --git a/book/index_book.rst b/book/index_book.rst
> > >>>> > index 8282006..afe15a1 100644
> > >>>> > --- a/book/index_book.rst
> > >>>> > +++ b/book/index_book.rst
> > >>>> > @@ -23,7 +23,7 @@ Table of Contents
> > >>>> > cpu_supplement/index.rst
> > >>>> > develenv/index.rst
> > >>>> > filesystem/index.rst
> > >>>> > - networking/index.rst
> > >>>> > porting/index.rst
> > >>>> > posix1003_1/index.rst
> > >>>> > posix_users/index.rst
> > >>>> > + legacy_networking/index.rst
> > >>>> > diff --git a/networking/command.rst b/legacy-networking/command.rst
> > >>>> > similarity index 100%
> > >>>> > rename from networking/command.rst
> > >>>> > rename to legacy-networking/command.rst
> > >>>> > diff --git a/networking/conf.py b/legacy-networking/conf.py
> > >>>> > similarity index 58%
> > >>>> > rename from networking/conf.py
> > >>>> > rename to legacy-networking/conf.py
> > >>>> > index 1c129bc..98a06b6 100644
> > >>>> > --- a/networking/conf.py
> > >>>> > +++ b/legacy-networking/conf.py
> > >>>> > @@ -3,12 +3,12 @@ sys.path.insert(0, os.path.abspath('../common/'))
> > >>>> > from conf import *
> > >>>> > -project = "RTEMS Networking User Manual"
> > >>>> > +project = "RTEMS Legacy Networking User Manual"
> > >>>> > latex_documents = [
> > >>>> > ('index',
> > >>>> > - 'networking.tex',
> > >>>> > - u'RTEMS Networking User Manual',
> > >>>> > + 'legacy-networking.tex',
> > >>>> > + u'RTEMS Legacy Networking User Manual',
> > >>>> > u'RTEMS Documentation Project',
> > >>>> > 'manual'),
> > >>>> > diff --git a/networking/dec_21140.rst b/legacy-networking/dec_21140.rst
> > >>>> > rename from networking/dec_21140.rst
> > >>>> > rename to legacy-networking/dec_21140.rst
> > >>>> > diff --git a/networking/index.rst b/legacy-networking/index.rst
> > >>>> > similarity index 92%
> > >>>> > rename from networking/index.rst
> > >>>> > rename to legacy-networking/index.rst
> > >>>> > index f56a60d..b85119d 100644
> > >>>> > --- a/networking/index.rst
> > >>>> > +++ b/legacy-networking/index.rst
> > >>>> > @@ -5,7 +5,7 @@
> > >>>> > .. highlight:: c
> > >>>> > -RTEMS Network User Manual (|version|).
> > >>>> > +RTEMS Legacy Network User Manual (|version|).
> > >>>> > .. topic:: Copyrights and License
> > >>>> > diff --git a/networking/network_servers.rst b/legacy-networking/network_servers.rst
> > >>>> > rename from networking/network_servers.rst
> > >>>> > rename to legacy-networking/network_servers.rst
> > >>>> > diff --git a/networking/network_task_structure.rst b/legacy-networking/network_task_structure.rst
> > >>>> > rename from networking/network_task_structure.rst
> > >>>> > rename to legacy-networking/network_task_structure.rst
> > >>>> > diff --git a/networking/networking_driver.rst b/legacy-networking/networking_driver.rst
> > >>>> > rename from networking/networking_driver.rst
> > >>>> > rename to legacy-networking/networking_driver.rst
> > >>>> > diff --git a/networking/preface.rst b/legacy-networking/preface.rst
> > >>>> > rename from networking/preface.rst
> > >>>> > rename to legacy-networking/preface.rst
> > >>>> > diff --git a/networking/testing_the_driver.rst b/legacy-networking/testing_the_driver.rst
> > >>>> > rename from networking/testing_the_driver.rst
> > >>>> > rename to legacy-networking/testing_the_driver.rst
> > >>>> > diff --git a/networking/using_networking_rtems_app.rst b/legacy-networking/using_networking_rtems_app.rst
> > >>>> > rename from networking/using_networking_rtems_app.rst
> > >>>> > rename to legacy-networking/using_networking_rtems_app.rst
> > >>>> > diff --git a/networking/wscript b/legacy-networking/wscript
> > >>>> > rename from networking/wscript
> > >>>> > rename to legacy-networking/wscript
> > >>>> > diff --git a/wscript b/wscript
> > >>>> > index ce644f8..0b1c368 100644
> > >>>> > --- a/wscript
> > >>>> > +++ b/wscript
> > >>>> > @@ -32,11 +32,11 @@ build_all = ['user',
> > >>>> > 'posix-compliance',
> > >>>> > 'eng',
> > >>>> > 'filesystem',
> > >>>> > - 'networking',
> > >>>> > 'shell',
> > >>>> > 'cpu-supplement',
> > >>>> > 'develenv',
> > >>>> > - 'eclipse']
> > >>>> > + 'eclipse',
> > >>>> > + 'legacy-networking']
> > >>>> > building = build_all
> > >>>> > 2.26.2
> > >>>> _______________________________________________
> > >>>> devel mailing list
> > >>>> devel at rtems.org
> > >>>> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
