Ticket#3889 updated
zack_on_the_speed_chanel zack_on_the_speed_chanel at protonmail.ch
Tue Mar 30 20:40:41 UTC 2021
I have both of the options and i tried to built it with BUILD_TESTS and PSXTESTS and the test didn't  build. Is there anything else that could alter how rtems is built?
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, March 30, 2021 3:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
> BUILD_TESTS and BUILD_PSXTESTS are two options that
> if either is True it should build psxclock02.
> On Tue, Mar 30, 2021 at 9:20 AM zack_on_the_speed_chanel
> zack_on_the_speed_chanel at protonmail.ch wrote:
> > I did build the leon3 bsp and I still don't see the psxtimer02 as an executable. Is there a way build a test from source? I have the sources for psxtest02. Also i'm thinking that it could be due to the fact that i don't have posix tests enabled. Is there a way
> > that to enable posix?
> > Thanks
> > Zack
> > On Monday, March 29, 2021 8:11 PM, zack_on_the_speed_chanel zack_on_the_speed_chanel at protonmail.ch wrote:
> > > Sorry that assumption was very native of me that i didn't have a working baseline. Joel said that the erc32 was similar to the leon bsp
> > > The ERC32 what's the first space hardened sparc processor. The leon3 is a
> > > later processor in the same family. Both use the same build of GCC and are
> > > just different bsps. In fact both run on the same sis simulator. "
> > > I also though that the bsps were the same and I can work on the issue with only the erc32 BSP. I have one more question: when i run the hello world test. All the test files are within one specific directory and I don't see the executables for specific bsps that's why i thought all tests would be built (there would not be any specific considerations for bsps) .
> > > On Monday, March 29, 2021 2:45 PM, Gedare Bloom gedare at rtems.org wrote:
> > > > On Sun, Mar 28, 2021 at 1:26 PM zack_on_the_speed_chanel
> > > > > Hello all,
> > > > > I'm updating on what' i've found out with the issue (forgot to reply all) . Joel recommended me check the coverage for the leon BSP( to check if it's supported) and i found that the branch with CLOCK_MONOTONIC was not reached I think now that it's supported (because the annotated assembly is in the sparc instruction set). I also found out that the test would be similar to Psxclock02 and it runs the same tests on a different clock. Then I tried to build the psxclock02 test , change the create_clock to have the clock_monotonic argument and i didn't see the executable or any change in the ./waf build. Then I was suggested that you have to enable all tests some how? How do i enable all tests?
> > > > Do you use something like: ./waf bsp_defaults ---rtems-bsp=leon3 > config.ini
> > > > Then, take a look, BUILD_TESTS and BUILD_PSXTESTS are two options that
> > > > When you write code, you should first make sure you can build the code
> > > > as it exists if it is supposed to work, and run it to see that it
> > > > works. Then you should make changes from a working baseline. Otherwise
> > > > when you get a problem, how do you know if the problem is your
> > > > problem, or it already existed?
> > > > > Thanks
> > > > > Zack
> > > > > devel mailing list
> > > > > devel at rtems.org
> > > > > http://lists.rtems.org/mailman/listinfo/devel
