Ticket#3889 updated
Gedare Bloom
gedare at rtems.org
Tue Mar 30 21:02:55 UTC 2021
On Tue, Mar 30, 2021 at 2:41 PM zack_on_the_speed_chanel
<zack_on_the_speed_chanel at protonmail.ch> wrote:
> I have both of the options and i tried to built it with BUILD_TESTS and PSXTESTS and the test didn't build. Is there anything else that could alter how rtems is built?
After you set them to True, did you re-run waf configure before waf build?
> Sent with ProtonMail Secure Email.
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Tuesday, March 30, 2021 3:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
> > BUILD_TESTS and BUILD_PSXTESTS are two options that
> > if either is True it should build psxclock02.
> > On Tue, Mar 30, 2021 at 9:20 AM zack_on_the_speed_chanel
> > zack_on_the_speed_chanel at protonmail.ch wrote:
> > > I did build the leon3 bsp and I still don't see the psxtimer02 as an executable. Is there a way build a test from source? I have the sources for psxtest02. Also i'm thinking that it could be due to the fact that i don't have posix tests enabled. Is there a way
> > > that to enable posix?
> > > Thanks
> > > Zack
> > > On Monday, March 29, 2021 8:11 PM, zack_on_the_speed_chanel zack_on_the_speed_chanel at protonmail.ch wrote:
> > > > Sorry that assumption was very native of me that i didn't have a working baseline. Joel said that the erc32 was similar to the leon bsp
> > > > The ERC32 what's the first space hardened sparc processor. The leon3 is a
> > > > later processor in the same family. Both use the same build of GCC and are
> > > > just different bsps. In fact both run on the same sis simulator. "
> > > > I also though that the bsps were the same and I can work on the issue with only the erc32 BSP. I have one more question: when i run the hello world test. All the test files are within one specific directory and I don't see the executables for specific bsps that's why i thought all tests would be built (there would not be any specific considerations for bsps) .
> > > > On Monday, March 29, 2021 2:45 PM, Gedare Bloom gedare at rtems.org wrote:
> > > > > On Sun, Mar 28, 2021 at 1:26 PM zack_on_the_speed_chanel
> > > > > > Hello all,
> > > > > > I'm updating on what' i've found out with the issue (forgot to reply all) . Joel recommended me check the coverage for the leon BSP( to check if it's supported) and i found that the branch with CLOCK_MONOTONIC was not reached I think now that it's supported (because the annotated assembly is in the sparc instruction set). I also found out that the test would be similar to Psxclock02 and it runs the same tests on a different clock. Then I tried to build the psxclock02 test , change the create_clock to have the clock_monotonic argument and i didn't see the executable or any change in the ./waf build. Then I was suggested that you have to enable all tests some how? How do i enable all tests?
> > > > > Do you use something like: ./waf bsp_defaults ---rtems-bsp=leon3 > config.ini
> > > > > Then, take a look, BUILD_TESTS and BUILD_PSXTESTS are two options that
> > > > > When you write code, you should first make sure you can build the code
> > > > > as it exists if it is supposed to work, and run it to see that it
> > > > > works. Then you should make changes from a working baseline. Otherwise
> > > > > when you get a problem, how do you know if the problem is your
> > > > > problem, or it already existed?
> > > > > > Thanks
> > > > > > Zack
> > > > > > devel mailing list
> > > > > > devel at rtems.org
> > > > > > http://lists.rtems.org/mailman/listinfo/devel
