[PATCH RSB 5] gdb-9-1: Add patch for linker error
Vijay Kumar Banerjee vijay at rtems.org
Wed Mar 31 00:33:40 UTC 2021
On Tue, Mar 30, 2021 at 4:52 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 30, 2021, 5:23 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> On Tue, Mar 30, 2021 at 4:18 PM Joel Sherrill <joel at rtems.org> wrote:
>> > It is preferred not to add patches to our repos when you can reference the upstream to fetch it. You should be able to reference the URL where the "raw" view of the patch is.
>> Thanks for reviewing. The issue with that was that I was getting merge
>> conflicts from the ChangeLog file so this is a workaround to get the
>> changes in code. I can add the commit hash in the commit message and
>> add the original commit message to the diff.
> Hmmm.. attach your version of the patch to the RTEMS ticket and reference that
Thanks for the idea! I just sent the v2 of the patch.
>> > On Tue, Mar 30, 2021 at 4:56 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> >> Close #4366
>> >>  rtems/config/tools/rtems-gdb-9.1-1.cfg        |  3 +
>> >>  .../patches/gdb-9-1-linker-error-fix.diff     | 67 +++++++++++++++++++
>> >>  2 files changed, 70 insertions(+)
>> >>  create mode 100644 source-builder/patches/gdb-9-1-linker-error-fix.diff
>> >> diff --git a/rtems/config/tools/rtems-gdb-9.1-1.cfg b/rtems/config/tools/rtems-gdb-9.1-1.cfg
>> >> index 99e6571..3c398af 100644
>> >> --- a/rtems/config/tools/rtems-gdb-9.1-1.cfg
>> >> +++ b/rtems/config/tools/rtems-gdb-9.1-1.cfg
>> >> @@ -9,4 +9,7 @@
>> >>  %define gdb_src_ext xz
>> >>  %hash sha512 gdb-%{gdb_version}.tar.xz hM3UCNgKP8V3neRZxbJhVNMbMp695+OqeHmfseskXYtkuMjuckI4Kh29lbTm+dhP70HRKgZGqnXT3uRwnqH25w==
>> >> +%patch add gdb file://gdb-9-1-linker-error-fix.diff
>> >> +%hash sha512 gdb-9-1-linker-error-fix.diff QAtNCgJsDdfKno+IqHwqRGz1SR3YdTm34ERox2fqpgaGHI6H4GqNfmkJcJaIvSgzNxif24vqWO+bF/Djqa6wNg==
>> >>  %include %{_configdir}/gdb-common-1.cfg
>> >> diff --git a/source-builder/patches/gdb-9-1-linker-error-fix.diff b/source-builder/patches/gdb-9-1-linker-error-fix.diff
>> >> new file mode 100644
>> >> index 0000000..d9b57d3
>> >> --- /dev/null
>> >> +++ b/source-builder/patches/gdb-9-1-linker-error-fix.diff
>> >> @@ -0,0 +1,67 @@
>> >> +diff --git a/sim/ppc/ld-insn.c b/sim/ppc/ld-insn.c
>> >> +index e39131ca133..585071a861f 100644
>> >> +--- a/sim/ppc/ld-insn.c
>> >> ++++ b/sim/ppc/ld-insn.c
>> >> +@@ -28,6 +28,24 @@
>> >> + #include "igen.h"
>> >> ++static model *last_model;
>> >> ++static insn *last_model_macro;
>> >> ++static insn *last_model_function;
>> >> ++static insn *last_model_internal;
>> >> ++static insn *last_model_static;
>> >> ++static insn *last_model_data;
>> >> ++model *models;
>> >> ++insn *model_macros;
>> >> ++insn *model_functions;
>> >> ++insn *model_internal;
>> >> ++insn *model_static;
>> >> ++insn *model_data;
>> >> ++int max_model_fields_len;
>> >> + static void
>> >> + update_depth(insn_table *entry,
>> >> +            lf *file,
>> >> +diff --git a/sim/ppc/ld-insn.h b/sim/ppc/ld-insn.h
>> >> +index 88318ffa2b3..52baeaa2d84 100644
>> >> +--- a/sim/ppc/ld-insn.h
>> >> ++++ b/sim/ppc/ld-insn.h
>> >> +@@ -200,25 +200,15 @@ extern insn_table *load_insn_table
>> >> +  table_include *includes,
>> >> +  cache_table **cache_rules);
>> >> +-model *models;
>> >> +-model *last_model;
>> >> ++extern model *models;
>> >> +-insn *model_macros;
>> >> +-insn *last_model_macro;
>> >> ++extern insn *model_macros;
>> >> ++extern insn *model_functions;
>> >> ++extern insn *model_internal;
>> >> ++extern insn *model_static;
>> >> ++extern insn *model_data;
>> >> +-insn *model_functions;
>> >> +-insn *last_model_function;
>> >> +-insn *model_internal;
>> >> +-insn *last_model_internal;
>> >> +-insn *model_static;
>> >> +-insn *last_model_static;
>> >> +-insn *model_data;
>> >> +-insn *last_model_data;
>> >> +-int max_model_fields_len;
>> >> ++extern int max_model_fields_len;
>> >> + extern void insn_table_insert_insn
>> >> + (insn_table *table,
>> >> 2.26.2
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
