[PATCH RSB 5 v2] gdb-9-1: Add patch to fix linker error with gcc10
Vijay Kumar Banerjee vijay at rtems.org
Wed Mar 31 04:29:10 UTC 2021
Hi Chris,
On Tue, Mar 30, 2021 at 10:24 PM Chris Johns <chrisj at rtems.org> wrote:
> OK for 5 the branch.
Thanks. will it be ok for master as well? I have created a cloned
ticket for master: #4367.
> It was a really great piece of work by everyone to sort this out. I have
> recently been hit by 4 separate cases of this change in gcc10 effecting code.
Thanks,
Vijay
> Thanks
> Chris
> On 31/3/21 11:19 am, Vijay Kumar Banerjee wrote:
> > Close #4366
> >  rtems/config/tools/rtems-gdb-9.1-1.cfg | 3 +++
> >  1 file changed, 3 insertions(+)
> > diff --git a/rtems/config/tools/rtems-gdb-9.1-1.cfg b/rtems/config/tools/rtems-gdb-9.1-1.cfg
> > index 99e6571..1d14a20 100644
> > --- a/rtems/config/tools/rtems-gdb-9.1-1.cfg
> > +++ b/rtems/config/tools/rtems-gdb-9.1-1.cfg
> > @@ -9,4 +9,7 @@
> >  %define gdb_src_ext xz
> >  %hash sha512 gdb-%{gdb_version}.tar.xz hM3UCNgKP8V3neRZxbJhVNMbMp695+OqeHmfseskXYtkuMjuckI4Kh29lbTm+dhP70HRKgZGqnXT3uRwnqH25w==
> > +%patch add gdb https://devel.rtems.org/raw-attachment/ticket/4366/gdb-9-1-linker-error-fix.diff
> > +%hash sha512 gdb-9-1-linker-error-fix.diff QAtNCgJsDdfKno+IqHwqRGz1SR3YdTm34ERox2fqpgaGHI6H4GqNfmkJcJaIvSgzNxif24vqWO+bF/Djqa6wNg==
> >  %include %{_configdir}/gdb-common-1.cfg
