[rtems5 PATCH 0/5] Backport zynq SPI drivers to rtems5
Jan Sommer
jan.sommer at dlr.de
Wed Mar 31 09:06:41 UTC 2021
This patchset backports:
- The cadence SPI driver (see: https://devel.rtems.org/ticket/4369)
- The xilinx axi SPI driver (see: https://devel.rtems.org/ticket/4370)
- The i2c and spi shell commands (see: https://devel.rtems.org/ticket/4371)
For the SPI drivers I didn't change any code (except the include paths)
I put them in bsps/arm/shared instead of bsps/shared, since rtems5 has
no aarch64 BSPs which could use them.
>From Christian's commit I only stripped the part for the waf build
system. I found the commands quite handy during driver development and
testing.
Best regards,
Jan
Christian Mauderer (1):
shell: Add i2c and spi commands
Jan Sommer (4):
bsps/xilinx_zynq: Add SPI driver for cadence-spi
bsps/xilinx_zynq: Add cadence SPI driver to build system
bsps/xilinx_zynq: Add SPI driver for xilinx-axi-spi
bsps/xilinx_zynq: Add Xilinx AXI SPI driver to build
bsps/arm/headers.am | 4 +
bsps/arm/include/bsp/cadence-spi-regs.h | 84 ++++
bsps/arm/include/bsp/cadence-spi.h | 63 +++
bsps/arm/include/bsp/xilinx-axi-spi-regs.h | 88 ++++
bsps/arm/include/bsp/xilinx-axi-spi.h | 67 +++
bsps/arm/shared/spi/cadence-spi.c | 444 ++++++++++++++++++
bsps/arm/shared/spi/xilinx-axi-spi.c | 402 ++++++++++++++++
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 4 +
.../lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 4 +
cpukit/Makefile.am | 4 +
cpukit/include/rtems/shellconfig.h | 28 ++
cpukit/libmisc/shell/main_i2cdetect.c | 107 +++++
cpukit/libmisc/shell/main_i2cget.c | 145 ++++++
cpukit/libmisc/shell/main_i2cset.c | 124 +++++
cpukit/libmisc/shell/main_spi.c | 157 +++++++
15 files changed, 1725 insertions(+)
create mode 100644 bsps/arm/include/bsp/cadence-spi-regs.h
create mode 100644 bsps/arm/include/bsp/cadence-spi.h
create mode 100644 bsps/arm/include/bsp/xilinx-axi-spi-regs.h
create mode 100644 bsps/arm/include/bsp/xilinx-axi-spi.h
create mode 100644 bsps/arm/shared/spi/cadence-spi.c
create mode 100644 bsps/arm/shared/spi/xilinx-axi-spi.c
create mode 100644 cpukit/libmisc/shell/main_i2cdetect.c
create mode 100644 cpukit/libmisc/shell/main_i2cget.c
create mode 100644 cpukit/libmisc/shell/main_i2cset.c
create mode 100644 cpukit/libmisc/shell/main_spi.c
2.17.1
