[PATCH 5/5] shell: Add i2c and spi commands
Jan Sommer jan.sommer at dlr.de
Wed Mar 31 09:06:46 UTC 2021
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
This adds some commands that are usefull for debugging simple serial
interfaces.
Even if they are a complete re-implementation, the i2c* commands use a
simmilar call like the Linux i2c tools.
Closes #4371
 cpukit/Makefile.am                    |   4 +
 cpukit/include/rtems/shellconfig.h    |  28 +++++
 cpukit/libmisc/shell/main_i2cdetect.c | 107 ++++++++++++++++++
 cpukit/libmisc/shell/main_i2cget.c    | 145 ++++++++++++++++++++++++
 cpukit/libmisc/shell/main_i2cset.c    | 124 ++++++++++++++++++++
 cpukit/libmisc/shell/main_spi.c       | 157 ++++++++++++++++++++++++++
 6 files changed, 565 insertions(+)
 create mode 100644 cpukit/libmisc/shell/main_i2cdetect.c
 create mode 100644 cpukit/libmisc/shell/main_i2cget.c
 create mode 100644 cpukit/libmisc/shell/main_i2cset.c
 create mode 100644 cpukit/libmisc/shell/main_spi.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 51f38c84c7..18eda95543 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1483,6 +1483,10 @@ librtemscpu_a_SOURCES += libmisc/shell/login_prompt.c
 librtemscpu_a_SOURCES += libmisc/shell/login_check.c
 librtemscpu_a_SOURCES += libmisc/shell/fdisk.c
 librtemscpu_a_SOURCES += libmisc/shell/main_rtc.c
+librtemscpu_a_SOURCES += libmisc/shell/main_spi.c
+librtemscpu_a_SOURCES += libmisc/shell/main_i2cdetect.c
+librtemscpu_a_SOURCES += libmisc/shell/main_i2cset.c
+librtemscpu_a_SOURCES += libmisc/shell/main_i2cget.c
 librtemscpu_a_SOURCES += libmisc/shell/dd-args.c
 librtemscpu_a_SOURCES += libmisc/shell/main_dd.c
 librtemscpu_a_SOURCES += libmisc/shell/dd-conv.c
diff --git a/cpukit/include/rtems/shellconfig.h b/cpukit/include/rtems/shellconfig.h
index 3e87d472d6..c5fcf4a45e 100644
--- a/cpukit/include/rtems/shellconfig.h
+++ b/cpukit/include/rtems/shellconfig.h
@@ -78,6 +78,10 @@ extern rtems_shell_cmd_t rtems_shell_DF_Command;
 extern rtems_shell_cmd_t rtems_shell_MD5_Command;
 extern rtems_shell_cmd_t rtems_shell_RTC_Command;
+extern rtems_shell_cmd_t rtems_shell_SPI_Command;
+extern rtems_shell_cmd_t rtems_shell_I2CDETECT_Command;
+extern rtems_shell_cmd_t rtems_shell_I2CGET_Command;
+extern rtems_shell_cmd_t rtems_shell_I2CSET_Command;
 extern rtems_shell_cmd_t rtems_shell_SHUTDOWN_Command;
 extern rtems_shell_cmd_t rtems_shell_CPUINFO_Command;
@@ -521,6 +525,30 @@ extern rtems_shell_alias_t * const rtems_shell_Initial_aliases[];
       &rtems_shell_RTC_Command,
     #endif
+    #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
+          && !defined(CONFIGURE_SHELL_NO_COMMAND_SPI)) \
+        || defined(CONFIGURE_SHELL_COMMAND_SPI)
+      &rtems_shell_SPI_Command,
+    #endif
+          && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CDETECT)) \
+        || defined(CONFIGURE_SHELL_COMMAND_I2CDETECT)
+      &rtems_shell_I2CDETECT_Command,
+    #endif
+          && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CGET)) \
+        || defined(CONFIGURE_SHELL_COMMAND_I2CGET)
+      &rtems_shell_I2CGET_Command,
+    #endif
+          && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CSET)) \
+        || defined(CONFIGURE_SHELL_COMMAND_I2CSET)
+      &rtems_shell_I2CSET_Command,
+    #endif
      *  System related commands
diff --git a/cpukit/libmisc/shell/main_i2cdetect.c b/cpukit/libmisc/shell/main_i2cdetect.c
new file mode 100644
index 0000000000..e953b4eaef
--- /dev/null
+++ b/cpukit/libmisc/shell/main_i2cdetect.c
@@ -0,0 +1,107 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH.
+ * are met:
+ * The command implemented here has a similar interface like the one from Linux
+ * i2c tools. Think of it as a heavily simplified version of them. Instead of
+ * the bus number they expect a bus path.
+#include <dev/i2c/i2c.h>
+#include <fcntl.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <rtems/shell.h>
+static const char rtems_i2cdetect_shell_usage [] =
+  "i2cdetect <I2C_BUS>\n"
+  "\ttry to detect i2c devices on the given bus\n";
+static int rtems_i2cdetect_shell_main(int argc, char *argv[])
+  int fd;
+  int rv;
+  const char *bus;
+  const uint16_t first = 1;
+  const uint16_t last = 0x7f;
+  uint16_t current;
+  if (argc != 2 || strcmp(argv[1], "-h") == 0) {
+    printf(rtems_i2cdetect_shell_usage);
+    return 1;
+  bus = argv[1];
+  fd = open(bus, O_RDWR);
+  if (fd < 0) {
+    perror("Couldn't open bus");
+    return 1;
+  printf("    x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xA xB xC xD xE xF\n"
+         "0x    ");
+  for (current = first; current <= last; ++current) {
+    i2c_msg msg = {
+      .addr = current,
+      .flags = 0,
+      .len = 0,
+      .buf = NULL,
+    struct i2c_rdwr_ioctl_data payload = {
+      .msgs = &msg,
+      .nmsgs = 1,
+    if ((current & 0x0F) == 0) {
+      printf("\n%1xx ", current >> 4);
+    rv = ioctl(fd, I2C_RDWR, &payload);
+    if (rv < 0) {
+      if (errno != EIO) {
+        perror("ioctl failed");
+      printf(" --");
+    } else {
+      printf(" %02x", current);
+  printf("\n");
+  close(fd);
+  return 0;
+rtems_shell_cmd_t rtems_shell_I2CDETECT_Command = {
+  .name = "i2cdetect",
+  .usage = rtems_i2cdetect_shell_usage,
+  .topic = "misc",
+  .command = rtems_i2cdetect_shell_main,
diff --git a/cpukit/libmisc/shell/main_i2cget.c b/cpukit/libmisc/shell/main_i2cget.c
index 0000000000..ffa551308b
--- /dev/null
+++ b/cpukit/libmisc/shell/main_i2cget.c
@@ -0,0 +1,145 @@
+ * are met:
+ * Additionally the i2cget has a continuous read mode that isn't available on
+ * Linux but does something similar to i2cdump.
+#include <fcntl.h>
+#include <stdio.h>
+static const char rtems_i2cget_shell_usage [] =
+  "i2cget <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> [<NR-BYTES>]\n"
+  "\tGet one or more bytes from an EEPROM like i2c device.\n"
+  "\tNote that multiple bytes will be read in continuous mode.\n";
+static int read_bytes(
+  int fd,
+  uint16_t i2c_address,
+  uint8_t data_address,
+  uint16_t nr_bytes
+  int rv;
+  uint8_t value[nr_bytes];
+  i2c_msg msgs[] = {{
+    .addr = i2c_address,
+    .flags = 0,
+    .buf = &data_address,
+    .len = 1,
+    .flags = I2C_M_RD,
+    .buf = value,
+    .len = nr_bytes,
+    .msgs = msgs,
+    .nmsgs = sizeof(msgs)/sizeof(msgs[0]),
+  uint16_t i;
+  if (rv < 0) {
+  } else {
+    for (i = 0; i < nr_bytes; ++i) {
+      printf("0x%02x ", value[i]);
+    printf("\n");
+  return rv;
+static int rtems_i2cget_shell_main(int argc, char *argv[])
+  int fd;
+  int rv;
+  const char *bus;
+  uint16_t chip_address;
+  uint8_t data_address;
+  uint16_t nr_bytes;
+  if (argc < 4 || argc > 5) {
+    printf(rtems_i2cget_shell_usage);
+    return 1;
+  errno = 0;
+  chip_address = (uint16_t) strtoul(argv[2], NULL, 0);
+  if (errno != 0) {
+    perror("Couldn't read chip address");
+    return 1;
+  errno = 0;
+  data_address = (uint8_t) strtoul(argv[3], NULL, 0);
+  if (errno != 0) {
+    perror("Couldn't read data address");
+    return 1;
+  nr_bytes = 1;
+  if (argc == 5) {
+    errno = 0;
+    nr_bytes = (uint16_t) strtoul(argv[4], NULL, 0);
+    if (errno != 0) {
+      perror("Couldn't read number of bytes");
+      return 1;
+  bus = argv[1];
+  if (fd < 0) {
+    return 1;
+  rv = read_bytes(fd, chip_address, data_address, nr_bytes);
+  close(fd);
+  return rv;
+rtems_shell_cmd_t rtems_shell_I2CGET_Command = {
+  .name = "i2cget",
+  .usage = rtems_i2cget_shell_usage,
+  .topic = "misc",
+  .command = rtems_i2cget_shell_main,
diff --git a/cpukit/libmisc/shell/main_i2cset.c b/cpukit/libmisc/shell/main_i2cset.c
index 0000000000..d9025b3b28
--- /dev/null
+++ b/cpukit/libmisc/shell/main_i2cset.c
@@ -0,0 +1,124 @@
+ * are met:
+ * Additionally it is possible to write multiple values as a continuous write.
+#include <fcntl.h>
+#include <stdio.h>
+static const char rtems_i2cset_shell_usage [] =
+  "i2cset <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> <VALUE> [<VALUE> [...]]\n"
+  "\tset one byte of an EEPROM like i2c device\n";
+static int
+rtems_i2cset_shell_main(int argc, char *argv[])
+  int fd;
+  int rv;
+  const char *bus;
+  /* Necessary: data-address and values. This will be a bit more. */
+  uint8_t writebuff[argc];
+  size_t len;
+  size_t i;
+    .flags = 0,
+    .buf = writebuff,
+    .len = 0,
+    .msgs = msgs,
+  if (argc < 5) {
+    printf(rtems_i2cset_shell_usage);
+    return 1;
+  errno = 0;
+  if (errno != 0) {
+    perror("Couldn't read CHIP_ADDRESS");
+    return 1;
+  msgs[0].addr = chip_address;
+  errno = 0;
+  writebuff[0] = (uint8_t) strtoul(argv[3], NULL, 0);
+  if (errno != 0) {
+    perror("Couldn't read DATA_ADDRESS");
+    return 1;
+  /* Read values starting from the fifth argument (index 4) */
+  i = 4;
+  len = 0;
+  while (i < argc) {
+    errno = 0;
+    writebuff[len + 1] = (uint8_t) strtoul(argv[i], NULL, 0);
+    if (errno != 0) {
+      perror("Couldn't read VALUE");
+      return 1;
+    ++i;
+    ++len;
+  msgs[0].len = len + 1; /* Don't forget address */
+  bus = argv[1];
+  if (fd < 0) {
+    return 1;
+  if (rv < 0) {
+  close(fd);
+  return rv;
+rtems_shell_cmd_t rtems_shell_I2CSET_Command = {
+  .name = "i2cset",
+  .usage = rtems_i2cset_shell_usage,
+  .topic = "misc",
+  .command = rtems_i2cset_shell_main,
diff --git a/cpukit/libmisc/shell/main_spi.c b/cpukit/libmisc/shell/main_spi.c
index 0000000000..487a22fc6c
--- /dev/null
+++ b/cpukit/libmisc/shell/main_spi.c
@@ -0,0 +1,157 @@
+ * are met:
+#include <dev/spi/spi.h>
+#include <fcntl.h>
+#include <stdio.h>
+static const char rtems_spi_shell_usage [] =
+  "simple SPI read / write\n"
+  "\n"
+  "spi [-loh] [-c <cs>] [-s <speed>] [-m <mode>] <SPI_BUS> xx [xx [..]]\n"
+  "    <SPI_BUS>  Bus device to use\n"
+  "    xx         Hex value of a byte to send\n"
+  "    -c <cs>    Use chip select <cs> (default: None)\n"
+  "    -m <mode>  Use SPI mode <mode> (default: 0)\n"
+  "    -l         Send LSB first\n"
+  "    -o         Use loopback mode\n"
+  "    -s <speed> Bus speed in hz\n"
+  "    -h         Print this help\n";
+static int rtems_spi_shell_main(int argc, char *argv[])
+  uint8_t buffer[argc - 1];
+  size_t len = 0;
+  int i;
+  size_t j;
+  int rv;
+  int fd;
+  char *bus = NULL;
+  unsigned long mode;
+  spi_ioc_transfer msg = {
+    .len = 0,
+    .rx_buf = buffer,
+    .tx_buf = buffer,
+    .speed_hz = 100000,
+    .bits_per_word = 8,
+    .cs_change = true,
+    .mode = SPI_MODE_0 | SPI_NO_CS,
+  for (i = 1; i < argc; ++i) {
+    if (argv[i][0] == '-') {
+      switch (argv[i][1]) {
+      case ('c'):
+        errno = 0;
+        msg.mode &= ~SPI_NO_CS;
+        msg.cs = (uint8_t) strtoul(argv[i+1], NULL, 0);
+        ++i;
+        if (errno != 0) {
+          printf("Couldn't process chip select\n");
+          return 1;
+        break;
+      case ('m'):
+        errno = 0;
+        mode = strtoul(argv[i+1], NULL, 0);
+        ++i;
+        if (errno != 0 || mode > 3) {
+          printf("Couldn't process mode\n");
+          return 1;
+        msg.mode &= ~(SPI_CPOL | SPI_CPHA);
+        msg.mode |= mode;
+        break;
+      case ('s'):
+        errno = 0;
+        msg.speed_hz = (uint32_t) strtoul(argv[i+1], NULL, 0);
+        ++i;
+        if (errno != 0) {
+          printf("Couldn't process speed\n");
+          return 1;
+        break;
+      case ('l'):
+        msg.mode |= SPI_LSB_FIRST;
+        break;
+      case ('o'):
+        msg.mode |= SPI_LOOP;
+        break;
+      case ('h'):
+        /* fallthrough */
+      default:
+        printf(rtems_spi_shell_usage);
+        return 1;
+    } else if (bus == NULL) {
+      bus = argv[i];
+    } else {
+      errno = 0;
+      buffer[len] = (uint8_t) strtol(argv[i], NULL, 16);
+      if (errno != 0) {
+        printf("Couldn't process '%s'\n", argv[i]);
+        return 1;
+      ++len;
+  if (len == 0) {
+    printf("Nothing to do\n");
+    return 0;
+  if (fd < 0) {
+    return 1;
+  msg.len = len;
+  rv = ioctl(fd, SPI_IOC_MESSAGE(1), &msg);
+  if (rv == -1) {
+    perror("Couldn't send the message");
+  } else {
+    printf("received:");
+    for (j = 0; j < len; ++j) {
+      printf(" %02x", buffer[j]);
+    printf("\n");
+  close(fd);
+  return 0;
+rtems_shell_cmd_t rtems_shell_SPI_Command = {
+  .name = "spi",
+  .usage = rtems_spi_shell_usage,
+  .topic = "misc",
+  .command = rtems_spi_shell_main,
2.17.1
