[PATCH 2/3] misc/wscript: Specify C language version
Joel Sherrill
joel at rtems.org
Wed Mar 31 16:44:10 UTC 2021
On Wed, Mar 31, 2021 at 9:56 AM Gedare Bloom <gedare at rtems.org> wrote:
> Should we set the cstd version at the top-level?
That's not what was done for C++ when I looked for examples. I suppose this
lets the C++ version vary by tool or library. And we did import some
third-party
code.
--joel
> On Tue, Mar 30, 2021 at 3:16 PM Joel Sherrill <joel at rtems.org> wrote:
> > CentOS 7 has gcc 4.8 which defaults to C90 and this results in warnings
> > for code that is valid C99 but not C90.
> > misc/wscript | 3 ++-
> > 1 file changed, 2 insertions(+), 1 deletion(-)
> > diff --git a/misc/wscript b/misc/wscript
> > index 521eddf..21e7f75 100644
> > --- a/misc/wscript
> > +++ b/misc/wscript
> > @@ -51,7 +51,8 @@ def build(bld):
> > conf['warningflags'] = ['-Wall', '-Wextra', '-pedantic']
> > conf['optflags'] = bld.env.C_OPTS
> > - conf['cflags'] = ['-pipe', '-g'] + conf['optflags']
> > + cstd = '-std=c99'
> > + conf['cflags'] = [cstd] + ['-pipe', '-g'] + conf['optflags']
> > conf['linkflags'] = ['-g']
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210331/a3a028c5/attachment.html>
