[PATCH] covoar: Fix off-by-one in Coverage::finalizeSymbol()
Gedare Bloom
gedare at rtems.org
Wed Mar 31 16:59:49 UTC 2021
On Wed, Mar 31, 2021 at 10:42 AM Alex White <alex.white at oarcorp.com> wrote:
> On Wed, Mar 31, 2021 at 11:22 AM Gedare Bloom <gedare at rtems.org> wrote:
> > On Wed, Mar 31, 2021 at 10:05 AM Alex White <alex.white at oarcorp.com> wrote:
> > > The `rangeIndex` variable is 1 higher than the index at which the first
> > > instruction address was found. This fixes the lookup after the loop to
> > > account for that fact.
> > > tester/covoar/ObjdumpProcessor.cc | 2 +-
> > > 1 file changed, 1 insertion(+), 1 deletion(-)
> > > diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
> > > index 62a06c5..1cfa877 100644
> > > --- a/tester/covoar/ObjdumpProcessor.cc
> > > +++ b/tester/covoar/ObjdumpProcessor.cc
> > > @@ -60,7 +60,7 @@ namespace Coverage {
> > > lowAddress = coverageMap.getLowAddressOfRange(rangeIndex);
> > > - uint32_t sizeWithoutNops = coverageMap.getSizeOfRange(rangeIndex);
> > > + uint32_t sizeWithoutNops = coverageMap.getSizeOfRange(rangeIndex - 1);
> > I guess this is because of the for loop. Maybe, you should prefer to
> > exit the for loop with the proper index?
> That is what I had before this code was initially reviewed:
> for (rangeIndex = 0; ; rangeIndex++) {
> if (firstInstructionAddress == lowAddress) {
> break;
> The suggestion was made to move the condition into the loop rather than
> use `break`:
> firstInstructionAddress != lowAddress;
> rangeIndex++) {
> I did that without realizing it wasn't equivalent and didn't run enough
> tests to catch it.
> Am I missing something here? Could I go back to my first solution? Is
> there a more elegant way?
Yes, since the first iteration will always happen, and you want to end
with the 'right' value in the iterator, a do-while loop is more
appropriate.
> Your most tedious code reviewee,
> Alex
> > Fixing an off-by-1 bug by subtracting one from the point of
> > consumption is a good way to ensure the bug occurs again if anyone
> > reuses the rangeIndex variable later.
> That is true.
> > > uint32_t size = sizeWithoutNops;
> > > uint32_t highAddress = lowAddress + size - 1;
> > > uint32_t computedHighAddress = highAddress;
> > > 2.27.0
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
