[PATCH] bsps/raspberrypi/console: Fix default console device
Niteesh G. S.
niteesh.gs at gmail.com
Sat May 1 16:17:24 UTC 2021
On Sat, May 1, 2021 at 8:31 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, May 1, 2021, 8:53 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> Just to provide more context,
>> When the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER option is used
>> and no --console option is provided, the console driver defaults to PL011.
>> In raspberry pi 3 and other models whose primary UART is not PL011, we
>> get no output.
>> This patch fixes that by linking the primary UART to the console device.
>> Thanks,
>> Niteesh
>> On Sat, May 1, 2021 at 7:05 PM G S Niteesh Babu <niteesh.gs at gmail.com>
>> wrote:
>>> When no console argument is given, the driver defaults to pl011
>>> this results in no output in case of Rpi3 whose primary uart is
>>> miniuart.
>>> This patch fixes that by defaulting to the primary uart when no
>>> console option is provided.
> Does the default need to vary by model?
Yes, the primary UART is different across models.
Rpi's have two UARTs PL011 and miniuart, on models which have Bluetooth
the PL011 is used to talk to the Bluetooth and miniuart acts as the primary
UART.
Now we can change this by adding miniuart-bt to config.txt but the miniuart
is
based on the VPU core and requires to add another option which sets the
core to
a fixed freq.
>>> bsps/arm/raspberrypi/console/console-config.c | 12 +++++++++---
>>> 1 file changed, 9 insertions(+), 3 deletions(-)
>>> diff --git a/bsps/arm/raspberrypi/console/console-config.c
>>> b/bsps/arm/raspberrypi/console/console-config.c
>>> index 6b8eb80aa4..bd3a8d34c2 100644
>>> --- a/bsps/arm/raspberrypi/console/console-config.c
>>> +++ b/bsps/arm/raspberrypi/console/console-config.c
>>> @@ -165,10 +165,16 @@ static void console_select( void )
>>> }else {
>>> - * If no command line option was given, default to PL011.
>>> + * If no console option was given we default to the primary uarts.
>>> + * The initialization of the uart's and BSP_output_char is already
>>> done
>>> + * in the uart_probe function called before this. So now we can
>>> safely
>>> + * compare BSP_output_char.
>>> - BSP_output_char = output_char_pl011;
>>> - link(PL011, CONSOLE_DEVICE_NAME);
>>> + if (BSP_output_char == output_char_pl011) {
>>> + link(PL011, CONSOLE_DEVICE_NAME);
>>> + }else {
>>> + link(MINIUART, CONSOLE_DEVICE_NAME);
>>> 2.17.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210501/1082691f/attachment.html>
