GSoC Project - Beagle BSP Projects
Christian Mauderer oss at c-mauderer.de
Sun May 2 12:01:53 UTC 2021
Hello Husni,
On 01/05/2021 23:38, Ahamed Husni wrote:
> Hi all,
> My project proposal
> https://docs.google.com/document/d/1CN3ri7g6NJeFPb5h8y4smr1aziGWyXbiiXUsFMhdUu4/edit?usp=sharing
> <https://docs.google.com/document/d/1CN3ri7g6NJeFPb5h8y4smr1aziGWyXbiiXUsFMhdUu4/edit?usp=sharing>
> I tried to set up the JTAG Environment for the Beaglebone Black.
> But I couldn't find the hardware anywhere in my country (Sri Lanka).
> I tried to,
>  1. Find TI XDS Debuggers
>  2. Find a TI Launchpad so we can isolate and use the debugger in it.
I assume you didn't find these?
>  3. Use RPi as a debugger using OpenOCD
I would have expect that one to work (like nearly any OpenOCD debugger).
What was the problem? Did OpenOCD detect the processor? What pins did
you connect? Please provide some more details so we might can help with
tips.
By the way: If you get it running it might would be a nice addition to
the user manual:
https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#debugging-beagle-bone-black-using-a-jtag-debugger-and-gdb
That's currently mostly about the gdb part. You maybe could add two or
three sentences and program calls how to start OpenOCD on a beagle and
what pins can be used for it.
> I looked for the debuggers in major electronic shops, embedded systems
> related companies,
> university labs and etc. But couldn't find them.
> Also these debuggers are expensive. When ordering online the shipping
> charges are also high.
I know from past GSoC that it can be difficult to get certain stuff in
some countries. That's OK and I'm sure we find some solution.
> So I can't guarantee that I can set up JTAG.
> Can we use RTEMS Libdebugger until we figure out the JTAG?
I did too few stuff with libdebugger. So I don't know it really well. I
_think_ that it needs a working network stack which would mean that you
can only use it _after_ libbsd is initialized.
Anyone: Please correct me if I'm wrong. If it would for example work
with a serial interface, it should be OK.
> Can we make a fallback plan for this project? If yes, what sorts of
> changes should be made?
I think the next best thing if you don't have a hardware debugger would
be the RTEMS event recording. You have to instrument code and the
processor has to be able to print an exception so you can get the data.
You can't check anything on a instruction level but it's a great tool if
you have to analyze the execution order of some problem cases. Most
likely that will work for a lot of problems in your project too. So I
would say that should be a fallback. Maybe you want to have a look at that:
https://docs.rtems.org/branches/master/user/tracing/eventrecording.html
Basically it's adding a few CONFIGURE_RECORD_... defines to your
application, receive events with rtems-record-lttng via network or from
a serial dump and then using Eclipse Trace Compass to analyze the trace.
Please speak up if you need help setting that up.
Best regards
Christian
> Best regards,
> Husni.
> On Fri, Apr 2, 2021 at 6:16 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     On 02/04/2021 08:36, Ahamed Husni wrote:
>      >         >     Yes, this seems like an area that can be chipped
>     away at, with a
>      >         >     strong plan of activities. My concern would be
>     whether it is about
>      >         >     writing code or not?
>      >         > After completing the above milestones, if we have more
>     time I can start
>      >         > to work on
>      >         > the Mass storage support.
>      >     I would suggest to put _more_ into the proposal and make it
>     clear that
>      >     the later points depend on whether there is enough time or not.
>      >     @Gedare: The time and effort for that project is really hard to
>      >     estimate
>      >     in my point of view. Do you have an idea how we could handle
>     that?
>      > So do I have to include mass storage support into the project
>     schedule or
>      > should I prepare the schedule for Ethernet, Serial and add the
>     list of
>      > possible advances and say that I'll work on them if there is
>     enough time?
>     I would suggest to include it. I'm quite sure that there is enough time.
>      >     Most likely we would have to put some further open points at
>     the end of
>      >     that because like I said: Depending on how well it works you
>     might need
>      >     anything between a day and three weeks to get CDC Ethernet
>     running.
>      >      From
>      >     my first guess, it's maybe a week.
>      >     Note that I would expect that you will need a debugger and
>     the RTEMS
>      >     event recording for this kind of project.
>      >     CDC Serial should be only a small step as soon as CDC Ethernet is
>      >     running.
>      > I don't have a JTAG debugger now. I'll get that set up asap.
>      >     >     USB OTG would be a nice area. But that will be less
>     writing a driver
>      >     >     for
>      >     >     Beagle but more finding out how that works with libbsd
>     and finding a
>      >     >     good way to configure it. I once put a few hours into
>     it didn't take
>      >     >     too
>      >     >     much time till a PC detected an USB device (see
>     https://gitlab.com/c-mauderer/rtems-libbsd/-/tree/20170707-cdce
>     <https://gitlab.com/c-mauderer/rtems-libbsd/-/tree/20170707-cdce>
>     <https://gitlab.com/c-mauderer/rtems-libbsd/-/tree/20170707-cdce>>
>     <https://gitlab.com/c-mauderer/rtems-libbsd/-/tree/20170707-cdce>>>).
>      >     >     Basically it's about importing the "usb_template" stuff
>     and finding a
>      >     >     way to configure it in libbsd.
>      > I'm trying to build and test this branch. I had trouble with
>     building
>      > the libbsd.
>     The branch is very old. Most likely it won't build with a current
>     toolchain and a current RTEMS. You might want to try to rebase the last
>     two patches onto an up to date libbsd.
>      > So I started to build the tools and kernel from scratch with the RSB
>      > master, using
>      > beaglebone black bset. It gives me the following error.
>      > Error log: https://pastebin.com/NYZRej1B
>     <https://pastebin.com/NYZRej1B> <https://pastebin.com/NYZRej1B
>     <https://pastebin.com/NYZRej1B>>
>      > Build command
>      >     ../source-builder/sb-set-builder --log=beagle.txt
>      >     --prefix=$BASE/rtems/6 bsps/beagleboneblack.bset
>     For development I would suggest to build only the toolchain using RSB.
>     After that you should build the BSP and libbsd manually. You will have
>     to recompile the BSP and libbsd quite often and it's a lot more
>     convenient to do that without touching RSB every time.
>     I would suggest to use some simple scripts or a Makefile for that.
>     Something like
>     https://gitlab.com/c-mauderer/rtems-bbb/-/blob/master/Makefile
>     <https://gitlab.com/c-mauderer/rtems-bbb/-/blob/master/Makefile>
>     Note that the repo containing that Makefile is no official one and
>     it is
>     unstable. Most of the time I use it for testing stuff.
>      > What would be the steps to configure the USB OTG driver from
>     libbsd to BBB.
>      > I would like to try it out. Please guide me on this.
>     I think that's most of the problem of the GSoC ;-)
>     Basically it's the following steps:
>     - Importing the relevant parts (should be the usb_template stuff) from
>     FreeBSD into libbsd. That's basically what the first commit on the
>     branch does. Take a look at the CONTRIBUTING.md file in libbsd for
>     details about the import process:
>     https://git.rtems.org/rtems-libbsd/tree/CONTRIBUTING.md#n158
>     <https://git.rtems.org/rtems-libbsd/tree/CONTRIBUTING.md#n158>
>     - Enable them for Beagle. That's the second commit on the branch.
>     - Somehow configure the USB OTG stuff. Like I said: That's the tricky
>     part. It has something to do with the usb_temp_init functions. But I
>     didn't manage to get it working in an hour or so and stopped trying
>     after that. So finding out how to configure and set up the stuff
>     will be
>     part of your Project.
>     Best regards
>     Christian
>      > Best regards,
>      > On Fri, Mar 26, 2021 at 8:17 PM Christian MAUDERER
>      > <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>      >     Hello Ahamed,
>      >     Am 26.03.21 um 15:31 schrieb Ahamed Husni:
>     writing a
>      >     driver
>      >      >     for
>      >      >     Beagle but more finding out how that works with libbsd and
>      >     finding a
>      >      >     good way to configure it. I once put a few hours into it
>      >     didn't take
>      >      >     too
>     stuff and
>      >     finding a
>      >      >     I think that topic would have to be a bit of an open
>     one: You
>      >     might
>      >      >     work
>      >      >     only a day on it and have a working CDC Ethernet
>     afterwards
>      >     or you can
>      >      >     need weeks for that. So you should add an open list of
>     possible
>      >      >     advanced
>      >      >     targets. An OTG device can be:
>      >      >     - Ethernet
>      >      >     - Serial port
>      >      >     - Mass storage
>      >      >     - Keyboard / Mouse
>      >      >     - Modem
>      >      >     - Audio
>      >      >     The simplest one will most likely be Ethernet followed
>     by serial
>      >      >     port. I
>      >      >     would add some of the others (like mass storage) as an
>      >     extended targets.
>      >      >     Best regards
>      >      >     Christian
>      >      > USB OTG would allow more extended capabilities for the
>     beagle board.
>      >      > To work on the USB OTG devices, what would be the best way?
>      >      > What I understood from what Christian says is,
>      >      >  1. Finding out how USB OTG works with libbsd and finding a
>      >      >       way to configure it for the beagle.
>      >      >  2. Work on CDC Ethernet
>      >      >  3. CDC Ethernet - Example application & Documentation
>      >      >  4. Work on Serial over USB
>      >      >  5. Serial over USB - Example application & Documentation
>      >      > Am I right?
>     the end of
>     might need
>     running.
>      >      From
>     the RTEMS
>      >     running.
>      >     Mass storage depends on the current implementation for that
>     in FreeBSD.
>      >     It might could be an interesting part.
>      >      > Would implementing Ethernet and Serial solve the problem
>     of using
>      >     TTL
>      >      > converters
>      >      > when working on RTEMS in Beagle for the developers?
>      >     Depends on the application. For those who want to write an
>     application,
>      >     a CDC Serial device would be a nice alternative. For those
>     who want to
>      >     develop drivers or RTEMS itself: Very unlikely that CDC Serial is
>      >     enough
>      >     for that.
>      >      >     Yes, this seems like an area that can be chipped away
>     at, with a
>      >      >     strong plan of activities. My concern would be whether
>     it is
>      >     about
>     time I can
>      >     start
>      >      > to work on
>     clear that
>      >     estimate
>     that?
>      >      >     Hi,
>      >      >     Regarding the PRU.
>      >      >     I was able to load code to the PRU.
>      >      >     However I wasn't able to map IRQ interrupts to the
>     PRU, thus
>      >     unable
>      >      >     to communicate with it in a meaningful way.
>      >      >     Also I don't think that this project should be continued
>      >     without a
>      >      >     full DEBUGGING Setup.
>      >      >     Best,
>      >      >     Nils
>      >      >     +1, without a proper debugging setup I found it hard
>     to precisely
>      >      >     pin point the problem when I initially took up this task.
>      >      > What is the full DEBUGGING setup needed to work on the PRU?
>      >     I expect a JTAG-Debugger. I had good experience with the
>     Segger J-Link
>      >     EDU for GSoC projects with BBB. Alternatively there are
>     OpenOCD based
>      >     ones out there too that are said do work well. Note that you
>     have to
>      >     solder a debug connector to the Beagle for that.
>      >     Best regards
>      >     Christian
>      >      > Regards,
>      >      > Husni.
>      >      > On Tue, Mar 23, 2021 at 10:25 PM Utkarsh Rai
>      >     <utkarsh.rai60 at gmail.com <mailto:utkarsh.rai60 at gmail.com>
>     <mailto:utkarsh.rai60 at gmail.com <mailto:utkarsh.rai60 at gmail.com>>
>      >      > <mailto:utkarsh.rai60 at gmail.com
>     <mailto:utkarsh.rai60 at gmail.com>>>> wrote:
>      >      >     On Tue, Mar 23, 2021 at 9:36 PM Nils Hölscher
>      >     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
>      >      >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>> wrote:
>      >      >         Hi,
>     PRU, thus
>      >      >         unable to communicate with it in a meaningful way
>      >      >     Just a small addition, AFAIK the issue with this was
>     the fact
>      >     that
>      >      >     mmap() would always fail.
>     continued
>      >     without
>      >      >         a full DEBUGGING Setup.
>     to precisely
>      >      >         Best,
>      >      >         Nils
>      >      >         On Tue, 23 Mar 2021 at 17:00, Christian MAUDERER
>      >      >         <christian.mauderer at embedded-brains.de
>      >      >         <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
>      >      >             Hello Gedare,
>      >      >             Am 23.03.21 um 16:48 schrieb Gedare Bloom:
>      >      >              > CC: Nils, Utkarsh
>      >      >              > On Tue, Mar 23, 2021 at 9:17 AM Christian
>     MAUDERER
>      >      >              > <christian.mauderer at embedded-brains.de
>      >      >              >> Hello Ahamed,
>      >      >              >> Am 23.03.21 um 11:24 schrieb Ahamed Husni:
>      >      >              >>> Hi everyone,
>      >      >              >>> I'm really interested to work on the
>     *Beagle BSP
>      >      >             Projects* [#2891
>      >      >              >>> <https://devel.rtems.org/ticket/2891
>     <https://devel.rtems.org/ticket/2891>
>     <https://devel.rtems.org/ticket/2891>>
>     <https://devel.rtems.org/ticket/2891>>>>]. *
>      >      >              >>> *Adding PRU Support* [#3730
>      >      >             <https://devel.rtems.org/ticket/3730
>     <https://devel.rtems.org/ticket/3730>
>     <https://devel.rtems.org/ticket/3730>>
>     <https://devel.rtems.org/ticket/3730>>>>]
>      >      >              >>> project seems really interesting to me.
>      >      >              >>> This project is partially done during
>     GSoC 2019
>      >      >              >>> <https://devel.rtems.org/wiki/GSoC/2019
>     <https://devel.rtems.org/wiki/GSoC/2019>
>     <https://devel.rtems.org/wiki/GSoC/2019>>
>     <https://devel.rtems.org/wiki/GSoC/2019>>>>by Nils Hölscher .
>      >      >              >>> Is this a good project for the GSoC?
>      >      >              >>> Up to now I have,
>      >      >              >>>   1. Completed the GSoC prerequisite task
>      >      >              >>>   2. Got the required hardware and tested it.
>      >      >             (Beagleboard Black, USB to
>      >      >              >>>      TTL Converter)
>      >      >              >>>   3. Installed RTEMS on the Beagleboard
>     and tested.
>      >      >             (Screenshot attached
>      >      >              >>>      below)
>      >      >              >>> I need guidance to define the scope of
>     the project.
>      >      >              >>> I'm currently thinking of ,
>      >      >              >>>   1. First finish the remaining work from
>     GSoC
>      >     2019 on
>      >      >             the PRU.
>      >      >              >>>      (What is the status of current
>      >     implementation of
>      >      >             the PRU?)
>      >      >              >> I'm really not sure what the state of the
>     PRU is. I
>      >      >             didn't follow that
>      >      >              >> project closely. Maybe one of the mentors
>     of that
>      >      >             project can say
>      >      >              >> anything regarding that.
>      >      >              > Some more background:
>     https://lists.rtems.org/pipermail/devel/2019-December/056478.html
>     <https://lists.rtems.org/pipermail/devel/2019-December/056478.html>
>     <https://lists.rtems.org/pipermail/devel/2019-December/056478.html>>
>     <https://lists.rtems.org/pipermail/devel/2019-December/056478.html>>>
>     https://lists.rtems.org/pipermail/devel/2020-January/056958.html
>     <https://lists.rtems.org/pipermail/devel/2020-January/056958.html>
>     <https://lists.rtems.org/pipermail/devel/2020-January/056958.html>>
>     <https://lists.rtems.org/pipermail/devel/2020-January/056958.html>>>
>      >      >              > Maybe Utkarsh or Nils have more to say.
>      >      >              >>>   2. Implement additional peripheral support.
>      >      >              >>>      What would be most useful?
>      >      >              >>>      (USB OTG, CAN, ...).
>      >      >              >> I think CAN is a bit hard without some CAN
>     analyzer
>      >      >             hardware as a peer.
>      >      >              >> USB OTG would be a nice area. But that
>     will be less
>      >      >             writing a driver for
>      >      >              >> Beagle but more finding out how that works
>     with
>      >     libbsd
>      >      >             and finding a
>      >      >              >> good way to configure it. I once put a few
>     hours
>      >     into it
>      >      >             didn't take too
>      >      >              >> much time till a PC detected an USB device
>     (see
>      >      >              >> Basically it's about importing the
>     "usb_template"
>      >     stuff
>      >      >             and finding a
>      >      >              >> way to configure it in libbsd.
>      >      >              >> I think that topic would have to be a bit
>     of an open
>      >      >             one: You might work
>      >      >              >> only a day on it and have a working CDC
>     Ethernet
>      >      >             afterwards or you can
>      >      >              >> need weeks for that. So you should add an open
>      >     list of
>      >      >             possible advanced
>      >      >              >> targets. An OTG device can be:
>      >      >              >> - Ethernet
>      >      >              >> - Serial port
>      >      >              >> - Mass storage
>      >      >              >> - Keyboard / Mouse
>      >      >              >> - Modem
>      >      >              >> - Audio
>      >      >              >> The simplest one will most likely be Ethernet
>      >     followed
>      >      >             by serial port. I
>      >      >              >> would add some of the others (like mass
>     storage)
>      >     as an
>      >      >             extended targets.
>      >      >              > Yes, this seems like an area that can be
>     chipped
>      >     away at,
>      >      >             with a
>      >      >              > strong plan of activities. My concern would be
>      >     whether it
>      >      >             is about
>      >      >              > writing code or not?
>      >      >             It won't produce a lot of code. But it will
>     produce
>      >     relevant
>      >      >             one:
>      >      >             1. Interface for configuration (if necessary)
>      >      >             2. Example application
>      >      >             3. Documentation
>      >      >             For Ethernet and serial port that's most
>     likely it.
>      >     For Mass
>      >      >             storage
>      >      >             there might be some more code. Without a too
>     detailed
>      >     look:
>      >      >             I would
>      >      >             expect that the mass storage either implements
>     some
>      >     access
>      >      >             to a raw
>      >      >             block device - in which case it would be
>     necessary to add
>      >      >             the access to
>      >      >             block devices. Or it implements something like the
>      >     PTP stuff
>      >      >             used on
>      >      >             smartphones in which case there will be most
>     likely some
>      >      >             code that
>      >      >             accesses the file system using POSIX functions
>     instead of
>      >      >             FreeBSD kernel
>      >      >             functions.
>      >      >             Best regards
>      >      >             Christian
>      >      >              >> Best regards
>      >      >              >> Christian
>      >      >              >>>      The builtin USB is NOT functional other
>      >     than for
>      >      >             power under RTEMS.
>      >      >              >>>      (USB OTG would have to be implemented in
>      >     RTEMS to
>      >      >             get rid of USB to
>      >      >              >>>      TTL Converter.)
>      >      >              >>>      - Ben Gras
>       <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html> <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html>>
>       <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html> <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html>>>>
>      >      >              >>>      (Blog post)
>      >      >              >>> Thanks,
>      >      >              >>> Husni Faiz.
>     _______________________________________________
>      >      >              >>> devel mailing list
>      >      >              >>> devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
>     <http://lists.rtems.org/mailman/listinfo/devel>>
>      >      >             <http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>>>
>      >      >              >> embedded brains GmbH
>      >      >              >> Herr Christian MAUDERER
>      >      >              >> Dornierstr. 4
>      >      >              >> 82178 Puchheim
>      >      >              >> Germany
>      >      >              >> email:
>      >      >              >> phone: +49-89-18 94 741 - 18
>      >      >              >> fax:   +49-89-18 94 741 - 08
>      >      >              >> Registergericht: Amtsgericht München
>      >      >              >> Registernummer: HRB 157899
>      >      >              >> Vertretungsberechtigte Geschäftsführer: Peter
>      >     Rasmussen,
>      >      >             Thomas Dörfler
>      >      >              >> Unsere Datenschutzerklärung finden Sie hier:
>     https://embedded-brains.de/datenschutzerklaerung/
>     <https://embedded-brains.de/datenschutzerklaerung/>
>     <https://embedded-brains.de/datenschutzerklaerung/>>
>     <https://embedded-brains.de/datenschutzerklaerung/>>>
>      >      >              >> devel mailing list
>      >      >              >> devel at rtems.org <mailto:devel at rtems.org>
>      >      >             Dornierstr. 4
>      >      >             82178 Puchheim
>      >      >             Germany
>      >      >             email: christian.mauderer at embedded-brains.de
>     Rasmussen,
>      >      >             Thomas Dörfler
>      >      > https://embedded-brains.de/datenschutzerklaerung/
>      >     Dornierstr. 4
>      >     82178 Puchheim
>      >     Germany
>      >     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen,
>     Thomas Dörfler
>      > Husni
>      > devel mailing list
