[PATCH] riscv/start: Startup sequence update.
Sun May 2 18:48:47 UTC 2021
On 30/04/2021 15:34, Sebastian Huber wrote:
> On 30/04/2021 15:32, Hesham Almatary wrote:
>>     The noinit attributes is a bit broken in GCC:
>> I guess we can go for a separate custom section then? Or we can just
>> assign it a magic value so that it doesn’t go into BSS.
> I propose to add something like this:
> +/* Generated from spec:/rtems/basedefs/if/noinit */
> + * @ingroup RTEMSAPIBaseDefs
> + * @brief Instructs the compiler to place the variable in a section
> which is
> + *   not initialized.
> +#define RTEMS_NOINIT RTEMS_SECTION( ".noinit" )
> I work currently on a support for this in the linker command files.
I checked in the .noinit support. Could you please check if this patch
fixes the problem:
https://lists.rtems.org/pipermail/devel/2021-May/067005.html
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
