[PATCH] libtest: Fix use of flexible array member
Sun May 2 19:24:20 UTC 2021
On Sun, May 2, 2021, 2:01 PM Sebastian Huber <
> Flexible array members must not appear in the middle of a structure.
Any idea why this doesn't generate a warning? I thought this restriction is
well known.
>  cpukit/include/rtems/test.h           | 18 +++++++++-------
>  cpukit/libtest/t-test-thread-switch.c | 24 ++++++++++-----------
>  testsuites/libtests/ttest02/init.c    | 30 +++++++++++++--------------
>  3 files changed, 37 insertions(+), 35 deletions(-)
> diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
> index 10ff665107..f95433bc7c 100644
> --- a/cpukit/include/rtems/test.h
> +++ b/cpukit/include/rtems/test.h
> @@ -89,10 +89,8 @@ typedef struct T_fixture_node {
>  #if defined(__GNUC__) || __STDC_VERSION__ >= 199409L
>  #define T_ZERO_LENGTH_ARRAY
> -#define T_ZERO_LENGTH_ARRAY_EXTENSION(n) (n)
>  #else
>  #define T_ZERO_LENGTH_ARRAY 1
> -#define T_ZERO_LENGTH_ARRAY_EXTENSION(n) ((n) - 1)
>  #endif
> @@ -2434,22 +2432,26 @@ typedef struct {
>         size_t recorded;
>         size_t capacity;
>         uint64_t switches;
> +} T_thread_switch_header;
> +typedef struct {
> +       T_thread_switch_header header;
>         T_thread_switch_event events[T_ZERO_LENGTH_ARRAY];
>  } T_thread_switch_log;
>  typedef struct {
> -       T_thread_switch_log log;
> -       T_thread_switch_event events[T_ZERO_LENGTH_ARRAY_EXTENSION(2)];
> +       T_thread_switch_event events[2];
>  } T_thread_switch_log_2;
>  typedef struct {
> -       T_thread_switch_event events[T_ZERO_LENGTH_ARRAY_EXTENSION(4)];
> +       T_thread_switch_event events[4];
>  } T_thread_switch_log_4;
>  typedef struct {
> -       T_thread_switch_event events[T_ZERO_LENGTH_ARRAY_EXTENSION(10)];
> +       T_thread_switch_event events[10];
>  } T_thread_switch_log_10;
>  T_thread_switch_log *T_thread_switch_record(T_thread_switch_log *);
> diff --git a/cpukit/libtest/t-test-thread-switch.c
> b/cpukit/libtest/t-test-thread-switch.c
> index 87ad4651fc..60179aaa40 100644
> --- a/cpukit/libtest/t-test-thread-switch.c
> +++ b/cpukit/libtest/t-test-thread-switch.c
> @@ -96,11 +96,11 @@ T_thread_switch_recorder(Thread_Control *executing,
> Thread_Control *heir)
>         if (log != NULL) {
>                 size_t recorded;
> -               ++log->switches;
> -               recorded = log->recorded;
> +               ++log->header.switches;
> +               recorded = log->header.recorded;
> -               if (recorded < log->capacity) {
> -                       log->recorded = recorded + 1;
> +               if (recorded < log->header.capacity) {
> +                       log->header.recorded = recorded + 1;
>                         log->events[recorded].executing =
> executing->Object.id;
>                         log->events[recorded].heir = heir->Object.id;
>                         log->events[recorded].cpu =
> @@ -127,8 +127,8 @@ T_thread_switch_record(T_thread_switch_log *log)
>         if (log != NULL) {
> -               log->recorded = 0;
> -               log->switches = 0;
> +               log->header.recorded = 0;
> +               log->header.switches = 0;
>         rtems_interrupt_lock_acquire(&ctx->lock, &lock_context);
> @@ -142,20 +142,20 @@ T_thread_switch_record(T_thread_switch_log *log)
>  T_thread_switch_record_2(T_thread_switch_log_2 *log)
> -       log->log.capacity = 2;
> -       return T_thread_switch_record(&log->log);
> +       log->header.capacity = T_ARRAY_SIZE(log->events);
> +       return T_thread_switch_record((T_thread_switch_log *)log);
>  T_thread_switch_record_4(T_thread_switch_log_4 *log)
> -       log->log.capacity = 4;
>  T_thread_switch_record_10(T_thread_switch_log_10 *log)
> -       log->log.capacity = 10;
> diff --git a/testsuites/libtests/ttest02/init.c
> b/testsuites/libtests/ttest02/init.c
> index 7f972aec7e..4d540c9a86 100644
> --- a/testsuites/libtests/ttest02/init.c
> +++ b/testsuites/libtests/ttest02/init.c
> @@ -222,23 +222,23 @@ T_TEST_CASE(TestThreadSwitch)
>         memset(&log_2, 0xff, sizeof(log_2));
>         log = T_thread_switch_record_2(&log_2);
>         T_null(log);
> -       T_eq_sz(log_2.log.recorded, 0);
> -       T_eq_sz(log_2.log.capacity, 2);
> -       T_eq_u64(log_2.log.switches, 0);
> +       T_eq_sz(log_2.header.recorded, 0);
> +       T_eq_sz(log_2.header.capacity, 2);
> +       T_eq_u64(log_2.header.switches, 0);
>         memset(&log_4, 0xff, sizeof(log_4));
>         log = T_thread_switch_record_4(&log_4);
> -       T_eq_ptr(log, &log_2.log);
> -       T_eq_sz(log_4.log.recorded, 0);
> -       T_eq_sz(log_4.log.capacity, 4);
> -       T_eq_u64(log_4.log.switches, 0);
> +       T_eq_ptr(&log->header, &log_2.header);
> +       T_eq_sz(log_4.header.recorded, 0);
> +       T_eq_sz(log_4.header.capacity, 4);
> +       T_eq_u64(log_4.header.switches, 0);
>         memset(&log_10, 0xff, sizeof(log_10));
>         log = T_thread_switch_record_10(&log_10);
> -       T_eq_ptr(log, &log_4.log);
> -       T_eq_sz(log_10.log.recorded, 0);
> -       T_eq_sz(log_10.log.capacity, 10);
> -       T_eq_u64(log_10.log.switches, 0);
> +       T_eq_ptr(&log->header, &log_4.header);
> +       T_eq_sz(log_10.header.recorded, 0);
> +       T_eq_sz(log_10.header.capacity, 10);
> +       T_eq_u64(log_10.header.switches, 0);
>         for (i = 0; i < 6; ++i) {
>                 rtems_status_code sc;
> @@ -248,10 +248,10 @@ T_TEST_CASE(TestThreadSwitch)
>         log = T_thread_switch_record(NULL);
> -       T_eq_ptr(log, &log_10.log);
> -       T_eq_sz(log->recorded, 10);
> -       T_eq_sz(log->capacity, 10);
> -       T_eq_u64(log->switches, 12);
> +       T_eq_ptr(&log->header, &log_10.header);
> +       T_eq_sz(log->header.recorded, 10);
> +       T_eq_sz(log->header.capacity, 10);
> +       T_eq_u64(log->header.switches, 12);
>         executing = rtems_task_self();
>         T_eq_u32(log->events[0].executing, executing);
>         T_ne_u32(log->events[0].heir, 0);
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210502/5ada960e/attachment-0001.html>
