[PATCH] rtems: Use allocator mutex for timer server
Sebastian Huber
Mon May 3 04:59:55 UTC 2021
The allocator mutex is recursive and already used for the task creation
in rtems_timer_initiate_server(). Just use this mutex instead of the
once mutex to serialize the initialization. This avoids a dependency on
condition variables which are not used here.
cpukit/rtems/src/timerserver.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/cpukit/rtems/src/timerserver.c b/cpukit/rtems/src/timerserver.c
index 3c994933cd..28b77e5635 100644
--- a/cpukit/rtems/src/timerserver.c
+++ b/cpukit/rtems/src/timerserver.c
@@ -24,7 +24,6 @@
#include <rtems/rtems/timerimpl.h>
-#include <rtems/score/onceimpl.h>
static Timer_server_Control _Timer_server_Default;
@@ -225,11 +224,10 @@ rtems_status_code rtems_timer_initiate_server(
rtems_status_code status;
- Thread_Life_state thread_life_state;
- thread_life_state = _Once_Lock();
+ _Objects_Allocator_lock();
status = _Timer_server_Initiate( priority, stack_size, attribute_set );
- _Once_Unlock( thread_life_state );
+ _Objects_Allocator_unlock();
return status;
2.26.2
