[PATCH] riscv/start: Startup sequence update.
Mon May 3 11:31:50 UTC 2021
On 03/05/2021 13:25, somesh deshmukh wrote:
> I tried this patch with the master branch and the build is failing
> after applying the patch.
> The error message includes:
> /home/somesh/Documents/rtems-temp/rtems/6/lib/gcc/riscv-rtems6/10.2.1/../../../../riscv-rtems6/bin/ld:
> /home/somesh/work/rtems-master/rtems/build/riscv/rv64imafdc_medany/testsuites/samples/hello.exe
> section `.unexpected_sections' will not fit in region
> `UNEXPECTED_SECTIONS'
> region `UNEXPECTED_SECTIONS' overflowed by 65537 bytes
> collect2: error: ld returned 1 exit status
> The overflowed size is equal to the size allocated for bsp_fdt_blob in
> the bss section.  From example .lst file ' .bss 0000000000010000
> bsp_fdt_blob'
> I found this in the riscv linkcmds.base.in <http://linkcmds.base.in> file:
You probably have to run ./waf configure again to regenerate the linker
command file.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
