[PATCH v1 0/5] Add nanosecond support patch
Ryan Long ryan.long at oarcorp.com
Mon May 3 13:40:22 UTC 2021
Hi,
For this series of patches, I
- Created the futimens() and utimensat() functions
- Reimplemented utime() and utimes() using utimensat()
- Added onto the test cases for utime() and utimes()
- Made tests for utimensat() and futimens()
- Changed the utime_h handler to utimens_h()
I still have to change the handler itself. The main change that was made
in that patch was changing the arguments from an access and modifcation
time to a timespec array. The names of the functions were changed, and a
couple of files were renamed as well.
Thanks,
Ryan
Ryan Long (5):
  libcsupport: Added futimens() and utimensat()
  libcsupport: Implement utime() in terms of utimensat()
  libcsupport: Implement utimes() in terms of utimensat()
  psx13: Added tests for utimensat() and futimens()
  Change filesystem utime_h handler to utimens_h
 bsps/arm/csb337/umon/tfsDriver.c            |   2 +-
 cpukit/Makefile.am                          |   6 +-
 cpukit/include/rtems/confdefs/libio.h       |   4 +-
 cpukit/include/rtems/imfs.h                 |   7 +-
 cpukit/include/rtems/libio.h                |  21 +-
 cpukit/include/rtems/libio_.h               |  61 +++-
 cpukit/libcsupport/src/__usrenv.c           |   9 +-
 cpukit/libcsupport/src/futimens.c           |  91 ++++++
 cpukit/libcsupport/src/utime.c              |  74 +++--
 cpukit/libcsupport/src/utimensat.c          | 229 +++++++++++++
 cpukit/libcsupport/src/utimes.c             |  54 +++-
 cpukit/libfs/src/defaults/default_ops.c     |   2 +-
 cpukit/libfs/src/defaults/default_utime.c   |  32 --
 cpukit/libfs/src/defaults/default_utimens.c |  33 ++
 cpukit/libfs/src/dosfs/msdos_init.c         |  11 +-
 cpukit/libfs/src/ftpfs/ftpfs.c              |   2 +-
 cpukit/libfs/src/ftpfs/tftpDriver.c         |   2 +-
 cpukit/libfs/src/imfs/imfs_init.c           |   4 +-
 cpukit/libfs/src/imfs/imfs_utime.c          |  41 ---
 cpukit/libfs/src/imfs/imfs_utimens.c        |  42 +++
 cpukit/libfs/src/jffs2/src/fs-rtems.c       |  11 +-
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c      |  16 +-
 spec/build/cpukit/librtemscpu.yml           |   6 +-
 testsuites/psxtests/psx13/main.c            |   2 -
 testsuites/psxtests/psx13/test.c            | 484 +++++++++++++++++++++++++++-
 25 files changed, 1056 insertions(+), 190 deletions(-)
 create mode 100644 cpukit/libcsupport/src/futimens.c
 create mode 100644 cpukit/libcsupport/src/utimensat.c
 delete mode 100644 cpukit/libfs/src/defaults/default_utime.c
 create mode 100644 cpukit/libfs/src/defaults/default_utimens.c
 delete mode 100644 cpukit/libfs/src/imfs/imfs_utime.c
 create mode 100644 cpukit/libfs/src/imfs/imfs_utimens.c
1.8.3.1
