[PATCH v1 4/5] psx13: Added tests for utimensat() and futimens()
Ryan Long
ryan.long at oarcorp.com
Mon May 3 13:40:26 UTC 2021
Improved tests for utime() and utimes().
Close #4399
testsuites/psxtests/psx13/main.c | 2 -
testsuites/psxtests/psx13/test.c | 484 +++++++++++++++++++++++++++++++++++++--
2 files changed, 471 insertions(+), 15 deletions(-)
diff --git a/testsuites/psxtests/psx13/main.c b/testsuites/psxtests/psx13/main.c
index f9e7907..44267bd 100644
--- a/testsuites/psxtests/psx13/main.c
+++ b/testsuites/psxtests/psx13/main.c
@@ -1,5 +1,3 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
* @file
diff --git a/testsuites/psxtests/psx13/test.c b/testsuites/psxtests/psx13/test.c
index e98b03a..bb7a201 100644
--- a/testsuites/psxtests/psx13/test.c
+++ b/testsuites/psxtests/psx13/test.c
@@ -1,5 +1,3 @@
* @file
@@ -17,6 +15,8 @@
* - umask()
* - utime()
* - utimes()
+ * - utimensat()
+ * - futimens()
* - sync()
@@ -210,8 +210,7 @@ static void Dup2Test( void )
- * @brief Exercises fdatasync(). Does NOT test the functionality of the
- * underlying fdatasync entry in the IMFS op table.
+ * @brief Exercises fdatasync().
static void FDataSyncTest( void )
@@ -259,13 +258,13 @@ static void UMaskTest( void )
- * @brief Exercises utime(). Does not test the functionality of the
- * underlying utime entry in the IMFS op table.
+ * @brief Exercises utime().
static void UTimeTest( void )
int rv;
struct utimbuf time;
+ struct timespec current_time;
struct stat fstat;
/* First, an invalid filename. */
@@ -273,6 +272,57 @@ static void UTimeTest( void )
rtems_test_assert( rv == -1 );
rtems_test_assert( errno == ENOENT );
+ rv = stat( "testfile1.tst", &fstat );
+ rtems_test_assert( rv == 0 );
+ /* Change the owner of the file temporarily */
+ rv = chown( "testfile1.tst", 123, fstat.st_gid );
+ rv = utime( "testfile1.tst", &time );
+ rtems_test_assert( rv == -1 );
+ rtems_test_assert( errno == EACCES );
+ rv = chown( "testfile1.tst", fstat.st_uid, fstat.st_gid );
+ /* Change file to be read-only */
+ rv = chmod( "testfile1.tst", 06444 );
+ rv = chmod( "testfile1.tst", fstat.st_mode );
+ /* Test without times argument */
+ clock_gettime( CLOCK_REALTIME, ¤t_time );
+ rv = utime( "testfile1.tst", NULL );
+ rtems_test_assert( current_time.tv_sec <= fstat.st_atim.tv_sec );
+ rtems_test_assert( current_time.tv_sec <= fstat.st_mtim.tv_sec );
+ /* Pass invalid values */
+ time.actime = -1;
+ time.modtime = 54321;
+ rtems_test_assert( errno == EINVAL );
+ time.actime = 12345;
+ time.modtime = -1;
/* Now, the success test. */
@@ -280,24 +330,22 @@ static void UTimeTest( void )
- /* But, did it set the time? */
+ /* Check that it actually changed the time */
rtems_test_assert( fstat.st_atime == 12345 );
rtems_test_assert( fstat.st_mtime == 54321 );
- rv = utime( "testfile1.tst", NULL );
- rtems_test_assert( rv == 0 );
- * @brief Exercises utimes(). Does NOT test the functionality of the
+ * @brief Exercises utimes().
static void UTimesTest( void )
int rv;
struct timeval time[2];
struct stat fstat;
@@ -305,14 +353,422 @@ static void UTimesTest( void )
+ rv = utimes( "testfile1.tst", time );
+ rv = utimes( "testfile1.tst", NULL );
+ /* Negative second tests */
+ time[0].tv_sec = -1;
+ time[0].tv_usec = 12345;
+ time[1].tv_sec = 54321;
+ time[1].tv_usec = 54321;
+ time[0].tv_sec = 12345;
+ time[1].tv_sec = -1;
+ /* Negative microsecond tests */
+ time[0].tv_usec = -1;
+ time[1].tv_usec = -1;
+ /* Testing max range */
+ time[0].tv_usec = 1000000000;
+ time[1].tv_usec = 1000000000;
+ rtems_test_assert( fstat.st_atime == 12345 );
+ rtems_test_assert( fstat.st_mtime == 54321 );
+ * @brief Exercises utimensat().
+static void UTimensatTest( void )
+ int rv;
+ struct timespec time[2];
+ struct stat fstat;
+ /* Pass an unsupported file descriptor */
+ rv = utimensat(
+ 0,
+ "!This is an =invalid p at thname!!! : )",
+ NULL,
+ 0
+ rtems_test_assert( errno == ENOSYS );
+ /* Pass unsupported flag */
+ rv = utimensat(
+ AT_FDCWD,
+ NULL,
+ 1
+ /* Use an invalid filename. */
+ rv = utimensat(
+ AT_FDCWD,
+ NULL,
+ 0
+ rtems_test_assert( errno == ENOENT );
+ rv = utimensat( AT_FDCWD, "testfile1.tst", time, 0 );
+ rv = utimensat( AT_FDCWD, "testfile1.tst", NULL, 0 );
+ time[0].tv_sec = -12345;
+ time[0].tv_nsec = 12345;
+ time[1].tv_nsec = 54321;
+ time[1].tv_sec = -54321;
+ time[0].tv_nsec = -12345;
+ time[1].tv_nsec = -54321;
+ time[0].tv_nsec = 1000000000;
+ time[1].tv_nsec = 1000000000;
+ /* Now, the successful test cases. */
+ /* Running with access time nanosecond field equal to UTIME_NOW */
+ time[0].tv_nsec = UTIME_NOW;
+ /* Running with modified time nanosecond field equal to UTIME_NOW */
+ time[1].tv_nsec = UTIME_NOW;
+ /* Normal run */
+ * @brief Exercises futimens().
+static void FutimensTest( void )
+ int rv;
+ int fd;
+ /* Pass an invalid file descriptor */
+ rv = futimens( -1, time );
+ rtems_test_assert( errno == EBADF );
+ fd = open( "testfile1.tst", O_RDWR );
+ rtems_test_assert( fd != -1 );
+ rv = futimens( fd, time );
+ rv = futimens( fd, NULL );
+ /* Normal run */
- rv = utimes( "testfile1.tst", (struct timeval *)&time );
@@ -443,6 +899,8 @@ int test_main( void )
UMaskTest();
UTimeTest();
UTimesTest();
+ UTimensatTest();
+ FutimensTest();
FSyncTest();
PathConfTest();
FPathConfTest();
1.8.3.1
