Issues with rtems_waf on Windows 10 with gccdeps module
Vijay Kumar Banerjee vijay at rtems.org
Mon May 3 17:27:48 UTC 2021
Hi Robin,
On Mon, May 3, 2021 at 6:37 AM Robin Müller <robin.mueller.m at gmail.com>
wrote:
> I also tried bld.path.find_or_declare('rtems.h') like in the supplied
example, but that did not work for me either.
That worked for me in multiple places before. not sure what's happening
there.
> Kind Regards
> Robin
> On Mon, 3 May 2021 at 14:31, Robin Müller <robin.mueller.m at gmail.com>
wrote:
>> Hello Vijay,
>> I tried bld.find_or_declare('rtems.h') but that did not work for me.
>> Just out of curiosity, why was the patch not accepted? I did not find
anything in the waf gitlab.
I couldn't find the gitlab link where Chris raised this issue in waf, but I
found the devel discussion after which I came up with the find_or_declare
solution. Maybe you could find something helpful from the discussion as
well:
<goog_871882406>
https://lists.rtems.org/pipermail/devel/2020-April/059468.html
Best regards,
Vijay
>> Kind Regards
>> Robin
>> On Sat, 1 May 2021 at 20:29, Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
>>> Hi Robin,
>>> On Fri, Apr 30, 2021 at 2:36 AM Robin Müller <robin.mueller.m at gmail.com>
wrote:
>>> > Issue can be reproduced by doing the quickstart application build on
Windows 10. The issue are backslashes in the absolute paths of the
dependency paths
>>> > which were not stripped from dependency paths on Windows,
>>> > causing waf to not recognize them as valid absolute paths. More
specifically, I printed the resulting dependency paths after stripping
C\:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/sparc-rtems6/erc32/lib/include/rtems/userenv.h
>>> > The backslash at the start causes the issue.
>>> > I was able to fix this with the following adaptations (gccdeps.py
starting line 108)
>>> As I mentioned earlier, this patch will probably not be accepted in
>>> upstream waf and it might not be a great idea to change it in the
>>> RTEMS version of waf, since it'll cause issues in the future when we
>>> try to sync up with the waf updates from upstream.
>>> Please try bld.find_or_declare from your wscript and see if that fixes
>>> the header file not found issue. That is probably a cleaner solution
>>> for now.
>>> > # Now join all the lines together
>>> > txt = txt.replace('\\\n', '')
>>> > val = txt.strip()
>>> > val = [x.replace('\\ ', ' ') for x in re_splitter.split(val) if x]
>>> > # This was added to replace backslashes which can cause issues on
Windows
>>> > if os.name == 'nt':
>>> >      val = [x.replace('C:\\', 'C:') for x in re_splitter.split(val)
if x]
>>> > print(val)
>>> > nodes = []
>>> > bld = self.generator.bld
>>> > I don't know whether this can have other evil side effects, but the
waf build works after that..
>>> The possible evil side effects could be the issue with "\", as you
>>> mentioned here. So better to avoid hacking it. :)
>>> Best regards,
>>> Vijay
>>> > Kind Regards
>>> > Robin
>>> > On Fri, 30 Apr 2021 at 00:30, Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
>>> >> Hi all,
>>> >> On Thu, Apr 29, 2021 at 3:01 PM Chris Johns <chrisj at rtems.org> wrote:
>>> >> > On 30/4/21 5:01 am, Robin Müller wrote:
>>> >> > > Yes that is the prefix. The rtems.h file is definitely located
at the location
>>> >> > > in the warning and it works on older commit of rtems_waf (where
gccdeps.py is
>>> >> > > not used).
>>> >> > > I briefly looked through the gccdeps.py file and it is doing
some string
>>> >> > > stripping operations.
>>> >> > > Maybe that is the issue but I am not sure.
>>> >> > Thank you for debugging this and I agree it look like something is
a little off
>>> >> > in gccdeps.
>>> >> Yes, I had a patch for that but I think there was a discussion
>>> >> upstream between ita1024 and Chris and the conclusion was that the
>>> >> patch won't be accepted. I can't find it right now but I could fix
>>> >> this problem by using find_or_declare.
>>> >> @Robin: Please try to use the find function and see if it fixes.
>>> >> Here's an example that worked quite nicely in rtems-examples:
https://git.rtems.org/rtems-examples/tree/filesystem/fat_ramdisk/wscript#n34
>>> >> Best regards,
>>> >> Vijay
>>> >> > I will need to try and reproduce this to have a chance of finding
it. What
>>> >> > happens if you remove gccdeps.py? Will that you get past this
point?
>>> >> > Chris
>>> >> > _______________________________________________
>>> >> > devel mailing list
>>> >> > devel at rtems.org
>>> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210503/d22e0d30/attachment-0001.html>
