[PATCH v1 1/5] libcsupport: Added futimens() and utimensat()
Tue May 4 05:03:36 UTC 2021
On 03/05/2021 15:40, Ryan Long wrote:
> Created futimens.c and utimensat.c to add support for the POSIX
> methods futimens() and utimensat().
> utime() and utimes() are considered obsolote by POSIX, but RTEMS
> will continue to support them.
> Closes #4396
>   cpukit/Makefile.am                 |   2 +
>   cpukit/include/rtems/libio_.h      |  61 +++++++++-
>   cpukit/libcsupport/src/futimens.c  |  91 +++++++++++++++
>   cpukit/libcsupport/src/utimensat.c | 229 +++++++++++++++++++++++++++++++++++++
>   spec/build/cpukit/librtemscpu.yml  |   2 +
>   5 files changed, 384 insertions(+), 1 deletion(-)
>   create mode 100644 cpukit/libcsupport/src/futimens.c
>   create mode 100644 cpukit/libcsupport/src/utimensat.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index b0df610..29b4207 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -262,6 +262,8 @@ librtemscpu_a_SOURCES += libcsupport/src/unmount.c
>   librtemscpu_a_SOURCES += libcsupport/src/__usrenv.c
>   librtemscpu_a_SOURCES += libcsupport/src/utime.c
>   librtemscpu_a_SOURCES += libcsupport/src/utimes.c
> +librtemscpu_a_SOURCES += libcsupport/src/futimens.c
> +librtemscpu_a_SOURCES += libcsupport/src/utimensat.c
>   librtemscpu_a_SOURCES += libcsupport/src/utsname.c
>   librtemscpu_a_SOURCES += libcsupport/src/vprintk.c
>   librtemscpu_a_SOURCES += libcsupport/src/write.c
> diff --git a/cpukit/include/rtems/libio_.h b/cpukit/include/rtems/libio_.h
> index e9eb462..fc7a1e4 100644
> --- a/cpukit/include/rtems/libio_.h
> +++ b/cpukit/include/rtems/libio_.h
> @@ -7,7 +7,7 @@
> - *  COPYRIGHT (c) 1989-2011.
> + *  COPYRIGHT (c) 1989-2011, 2021.
>    *  On-Line Applications Research Corporation (OAR).
>    *  Modifications to support reference counting in the file system are
> @@ -357,6 +357,65 @@ static inline void rtems_filesystem_instance_unlock(
>     (*mt_entry->ops->unlock_h)( mt_entry );
> +/* Prototypes for functions used between utimensat() and futimens() */
> + * @brief Checks the tv_sec member of a timespec struct
> + * @param[in] time The timespec struct to be validated
> + * Ensures that the value in the tv_sec member is non-negative.
> + * @retval true If the tv_sec member is a valid value
> + * @retval false If the tv_sec member is not a valid value
> +bool rtems_filesystem_utime_tv_sec_valid( struct timespec time );
> + * @brief Checks the tv_nsec member of a timespec struct
> + * Ensures that the value in the tv_nsec member is equal to either
> + * UTIME_NOW, UTIME_OMIT, or a value greater-than or equal to zero
> + * and less than a billion.
> + * @retval true If the tv_nsec member is a valid value
> + * @retval false If the tv_nsec member is not a valid value
> +bool rtems_filesystem_utime_tv_nsec_valid( struct timespec time );
Are these two functions ever used individually? Do they modify the time?
Maybe we should add a standard phase for boolean type returns:
@return Returns true, if the X is valid, otherwise false.
> + * @brief Determines if the process has write permissions to a file
> + * Checks that the process has the same userID as the file and whether the
> + * file has write permissions.
> + * @param[in] currentloc The current location to a file
> + * @param[in] fstat_h The file handler of @currentloc
Why is this an extra parameter?
> + * @retval 0 If the process has write permissions
> + * @retval -1 If the process does not have write permissions
Why 0 and -1, what about errno? Is it set by the function or not?
> +int rtems_filesystem_utime_check_permissions(
> +  const rtems_filesystem_location_info_t *currentloc,
> +  rtems_filesystem_fstat_t fstat_h
> + * @brief Checks @times and updates @new_times
> + * @param[in] times The timespec struct to be checked
> + * @param[in,out] new_times The timespec struct to contain the updated time
> + * @retval 0 If the time was able to be updated
> + * @retval -1 If the time was not able to be updated
> +int rtems_filesystem_utime_check_times(
> +  const struct timespec times[2],
> +  struct timespec new_times[2]
>    *  File Descriptor Routine Prototypes
> diff --git a/cpukit/libcsupport/src/futimens.c b/cpukit/libcsupport/src/futimens.c
> new file mode 100644
> index 0000000..33ae469
> --- /dev/null
> +++ b/cpukit/libcsupport/src/futimens.c
> @@ -0,0 +1,91 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + *  @file
> + *  @ingroup libcsupport
> + *  @brief Set file access and modification times based on file descriptor in
> + *  nanoseconds.
> + *  COPYRIGHT (c) 1989-2009, 2021.
> + *  On-Line Applications Research Corporation (OAR).
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <sys/stat.h>
> +#include <rtems/libio_.h>
> +#include <fcntl.h>
> +#include <stdlib.h>
> +#include <string.h>
> + *  https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/functions/futimens.html
> + *  Set file access and modification times
> +int futimens(
> +  int                    fd,
> +  int rv;
> +  rtems_libio_t *iop;
> +  struct timespec new_times[2];
> +  const rtems_filesystem_location_info_t *currentloc = NULL;
> +  LIBIO_GET_IOP_WITH_ACCESS( fd, iop, LIBIO_FLAGS_READ, EBADF );
> +  currentloc = &iop->pathinfo;
> +  rv = rtems_filesystem_utime_check_permissions(
> +    currentloc,
> +    (*currentloc->handlers->fstat_h)
> +  if( rv == -1 ) {
Which coding style should this file and the other new files have?
> +/* Determine whether the access and modified timestamps can be updated */
> +  const rtems_filesystem_location_info_t * currentloc,
> +  struct stat st;
> +  volatile int rv;
volatile?
> +  bool write_access;
> +  memset( &st, 0, sizeof(st) );
> +  rv = (*fstat_h)( currentloc, &st );
> +  if( rv != 0 ) {
> +    rtems_set_errno_and_return_minus_one( ENOENT );
> +   * Check that the user ID and the user ID of the file match
> +  if( geteuid() != st.st_uid ) {
> +    rtems_set_errno_and_return_minus_one( EACCES );
Is this really what POSIX specified?
> +  write_access = rtems_filesystem_check_access(
> +    RTEMS_FS_PERMS_WRITE,
> +    st.st_mode,
> +    st.st_uid,
> +    st.st_gid
> +  if( !write_access ) {
> +  return 0;
> +int utimensat(
> +  int                    fd,
> +  const char            *path,
> +  int                    flag
> +  int rv = 0;
> +  rtems_filesystem_eval_path_context_t ctx;
> +  int eval_flags = RTEMS_FS_FOLLOW_LINK;
> +   * RTEMS does not currently support operating on a real file descriptor
> +  if( fd != AT_FDCWD ) {
> +    rtems_set_errno_and_return_minus_one( ENOSYS );
> +   * RTEMS does not currently support AT_SYMLINK_NOFOLLOW
> +  if( flag != 0 ) {
> +  currentloc = rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
> +    currentloc,
> +  if( rv == -1 ) {
Better use the success code, for example rv != 0.
> +    rtems_filesystem_eval_path_cleanup( &ctx );
> +    return rv;
> +  rv = rtems_filesystem_utime_check_times( times, new_times);
> +  if( rv == -1 ) {
> +    return rv;
> +  rv = (*currentloc->mt_entry->ops->utimens_h)(
> +    currentloc,
> +    new_times
> +  return rv;
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index a3a9ee4..9639051 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -761,6 +761,8 @@ source:
>   - cpukit/libcsupport/src/unmount.c
>   - cpukit/libcsupport/src/utime.c
>   - cpukit/libcsupport/src/utimes.c
> +- cpukit/libcsupport/src/futimens.c
> +- cpukit/libcsupport/src/utimensat.c
>   - cpukit/libcsupport/src/utsname.c
>   - cpukit/libcsupport/src/vprintk.c
>   - cpukit/libcsupport/src/write.c
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
