[PATCH] Make zero size allocation result consistent
Gedare Bloom
gedare at rtems.org
Tue May 4 06:49:51 UTC 2021
ok. This could break applications in strange ways if they depended on
the old behavior. A clear note will be needed in release.
On Mon, May 3, 2021 at 1:21 AM Sebastian Huber
> The zero size allocations had no consistent behaviour in RTEMS. For
> example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
> retruned in p a unique pointer (or NULL if no memory is available). In
> POSIX, zero size memory allocations are implementation-defined
> behaviour. The implementation has two options:
> https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
> https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
> Linux and FreeBSD return a unique pointer for zero size memory
> allocations. Use this approch for RTEMS as well throughout the memory
> allocation directives
> Close #4390.
> cpukit/libcsupport/src/malloc.c | 6 --
> cpukit/libcsupport/src/malloc_deferred.c | 4 -
> cpukit/libcsupport/src/realloc.c | 8 +-
> testsuites/libtests/malloctest/init.c | 106 ++++++++++++++++++++---
> 4 files changed, 100 insertions(+), 24 deletions(-)
> diff --git a/cpukit/libcsupport/src/malloc.c b/cpukit/libcsupport/src/malloc.c
> index e61128bf8c..795254fbab 100644
> --- a/cpukit/libcsupport/src/malloc.c
> +++ b/cpukit/libcsupport/src/malloc.c
> @@ -30,12 +30,6 @@ void *malloc(
> void *return_this;
> - * Validate the parameters
> - if ( !size )
> - return (void *) 0;
> return_this = rtems_heap_allocate_aligned_with_boundary( size, 0, 0 );
> if ( !return_this ) {
> errno = ENOMEM;
> diff --git a/cpukit/libcsupport/src/malloc_deferred.c b/cpukit/libcsupport/src/malloc_deferred.c
> index b319d1213e..aab76406c7 100644
> --- a/cpukit/libcsupport/src/malloc_deferred.c
> +++ b/cpukit/libcsupport/src/malloc_deferred.c
> @@ -106,10 +106,6 @@ void *rtems_heap_allocate_aligned_with_boundary(
> void *rtems_malloc( size_t size )
> - if ( size == 0 ) {
> - return NULL;
> return rtems_heap_allocate_aligned_with_boundary( size, 0, 0 );
> #endif
> diff --git a/cpukit/libcsupport/src/realloc.c b/cpukit/libcsupport/src/realloc.c
> index 1d9ae45c5d..e28e3fbc33 100644
> --- a/cpukit/libcsupport/src/realloc.c
> +++ b/cpukit/libcsupport/src/realloc.c
> @@ -53,15 +53,15 @@ void *realloc( void *ptr, size_t size )
> uintptr_t old_size;
> uintptr_t avail_size;
> + if ( ptr == NULL ) {
> + return malloc( size );
> if ( size == 0 ) {
> free( ptr );
> return NULL;
> - if ( ptr == NULL ) {
> - return malloc( size );
> heap = RTEMS_Malloc_Heap;
> switch ( _Malloc_System_state() ) {
> diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
> index 4d0f421c02..c9dcb63b2c 100644
> --- a/testsuites/libtests/malloctest/init.c
> +++ b/testsuites/libtests/malloctest/init.c
> @@ -1153,7 +1153,10 @@ static void test_rtems_malloc(void)
> void *p;
> p = rtems_malloc(0);
> - rtems_test_assert(p == NULL);
> + rtems_test_assert(p != NULL);
> + RTEMS_OBFUSCATE_VARIABLE(p);
> + free(p);
> errno = 0;
> p = rtems_malloc(SIZE_MAX / 2);
> @@ -1163,6 +1166,7 @@ static void test_rtems_malloc(void)
> p = rtems_malloc(1);
> free(p);
> @@ -1172,13 +1176,22 @@ static void test_rtems_calloc(void)
> int *i;
> p = rtems_calloc(0, 0);
> + free(p);
> p = rtems_calloc(0, 1);
> + free(p);
> p = rtems_calloc(1, 0);
> + free(p);
> errno = 0;
> p = rtems_calloc(1, SIZE_MAX / 2);
> @@ -1202,6 +1215,8 @@ static void test_rtems_calloc(void)
> rtems_test_assert(i != NULL);
> rtems_test_assert(*i == 0);
> free(i);
> @@ -1301,6 +1316,82 @@ static void test_greedy_allocate(void)
> rtems_test_assert( p == NULL );
> +static void test_alloc_zero_size(void)
> + size_t size;
> + void *p;
> + int eno;
> + size = 0;
> + RTEMS_OBFUSCATE_VARIABLE( size );
> + p = malloc( size );
> + rtems_test_assert( p != NULL );
> + RTEMS_OBFUSCATE_VARIABLE( p );
> + free( p );
> + p = calloc( 1, size );
> + free( p );
> + p = rtems_malloc( size );
> + free( p );
> + p = rtems_calloc( 1, size );
> + free( p );
> + p = NULL;
> + eno = posix_memalign( &p, 32, size );
> + rtems_test_assert( eno == 0 );
> + free( p );
> + p = NULL;
> + eno = rtems_memalign( &p, 32, size );
> + free( p );
> + p = aligned_alloc( 32, size );
> + free( p );
> + p = realloc( NULL, size );
> + free( p );
> + p = reallocarray( NULL, 1, size );
> + free( p );
> rtems_task Init(
> rtems_task_argument argument
> @@ -1327,12 +1418,6 @@ rtems_task Init(
> rtems_test_assert( p1 == NULL );
> #pragma GCC diagnostic pop
> - * Verify error case where malloc of size 0.
> - p1 = malloc( 0 );
> - rtems_test_assert( p1 == NULL );
> test_heap_initialize();
> test_heap_block_allocate();
> test_heap_allocate();
> @@ -1351,6 +1436,7 @@ rtems_task Init(
> test_rtems_malloc();
> test_rtems_calloc();
> test_greedy_allocate();
> + test_alloc_zero_size();
> test_posix_memalign();
> 2.26.2
> devel mailing list
> devel at rtems.org
