[PATCH rtems-net-legacy v2] bsp_drivers: Use os.path for compatibility with non Unix host
Tue May 4 07:00:48 UTC 2021
looks good to me
On Mon, May 3, 2021 at 4:37 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Is this Ok to push?
> On Mon, Apr 19, 2021 at 11:32 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > On Mon, Apr 19, 2021 at 11:30 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >  bsp_drivers.py | 22 +++++++++++-----------
> > >  1 file changed, 11 insertions(+), 11 deletions(-)
> > > diff --git a/bsp_drivers.py b/bsp_drivers.py
> > > index 3ca10c6..ec25c23 100644
> > > --- a/bsp_drivers.py
> > > +++ b/bsp_drivers.py
> > > @@ -36,18 +36,18 @@ def bsp_files(bld):
> > >      include_dirs = {}
> > >      include_files = []
> > > -    special_case_dirs = {'atsamv': './bsps/arm/atsam',
> > > -                         'lm32_evr': './bsps/lm32',
> > > -                         'lpc24xx_ea': './bsps/arm/shared/'}
> > > +    special_case_dirs = {'atsamv': os.path.expanduser('bsps/arm/atsam'),
> > > +                         'lm32_evr': os.path.expanduser('bsps/lm32'),
> > > +                         'lpc24xx_ea': os.path.expanduser('bsps/arm/shared/')}
> > >      special_case_sources = {'leon2':
> > > -                            ['./bsps/shared/grlib/net/network_interface_add.c',
> > > -                             './bsps/shared/grlib/net/greth.c'],
> > > +                            [os.path.expanduser('bsps/shared/grlib/net/network_interface_add.c'),
> > I would like to add that these lines are over 80 characters limit.
> > > +                             os.path.expanduser('bsps/shared/grlib/net/greth.c')],
> > >                              'leon3':
> > >                              'griscv':
> > > -                             './bsps/shared/grlib/net/greth.c']}
> > > +                             os.path.expanduser('bsps/shared/grlib/net/greth.c')]}
> > >      bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
> > > @@ -57,7 +57,7 @@ def bsp_files(bld):
> > >          include_dirs[bsp] = []
> > >          source_files[bsp] = []
> > >          if bsp not in special_case_dirs:
> > > -            source_dir = os.walk(os.path.join('./bsps', arch, bsp))
> > > +            source_dir = os.walk(os.path.join('bsps', arch, bsp))
> > >          else:
> > >              source_dir = os.walk(special_case_dirs[bsp])
> > >          for root, dirs, files in source_dir:
> > > @@ -70,5 +70,5 @@ def bsp_files(bld):
> > >                          include_dirs[bsp].append(root)
> > >              if bsp in special_case_sources:
> > >                  source_files[bsp].extend(special_case_sources[bsp])
> > > -        include_dirs[bsp].append(os.path.join('./bsps', arch, bsp, 'net'))
> > > +        include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
> > >      return (include_dirs, source_files)
> > > 2.26.2
