About finding the bsp for qemu ( t2080rdb)
Richi Dubey richidubey at gmail.com
Tue May 4 15:17:46 UTC 2021
I understand, thank you for the detailed explanation.
I will try (if required all the bsps) and post here if something works :)
On Tue, May 4, 2021 at 11:11 AM Karel Gardas <karel.gardas at centrum.cz>
wrote:
> I've tried all variants IIRC of qoriq (e550/e5500/e6500) in qemu
> sometime ago (5.x development branch) and it booted but then was blocked
> on the serial port interaction and I really had no idea how to fix that.
> Debugger points out to the function where RTEMS asked serial port about
> a status and this was blocking forever. Look at this thread for more
> information: https://www.mail-archive.com/users@rtems.org/msg02543.html
> IMHO having qoriq bsp running in qemu would be better than qemuppc as
> qemuppc is IIRC about ppc750 which is quite old and is being replaced by
> qoriq variant last I checked. Speaking solely about BEA's RAD750 ->
> RAD5500 update here.
> So just compile bsp and try it in qemu and see for yourself, perhaps you
> will be more lucky and get that running well...
> Good luck!
> Karel
> On 5/4/21 7:33 AM, Richi Dubey wrote:
> > Hi?
> > On Fri, Apr 30, 2021 at 12:01 PM Richi Dubey <richidubey at gmail.com
> > <mailto:richidubey at gmail.com>> wrote:
> >     Hi,
> >     I looked at the docs
> https://docs.rtems.org/branches/master/user/bsps/bsps-powerpc.html#qemuppc
> >     and I want to build a bsp that I can test on qemu (it would be best
> >     if the bsp models qoriq t2080). The doc says that "qoriq_e6500_64
> >     (64-bit ISA) variants support the T-series chips such as T2080 and
> >     T4240." but right now I only want to test it on qemu, so should I
> >     build for the bsp qemuppc or should I use qoriq_e6500_64?
> >     Can someone please guide me?
> >     Thanks!
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210504/9e83c540/attachment.html>
