[PATCH] Removed references to legacy network config options in user/bld/index.rst as those options are no longer valid
Vijay Kumar Banerjee
vijay at rtems.org
Thu May 6 01:11:50 UTC 2021
Hi Harrison,
The patch looks good, just a little change is required. You'll notice
that we follow a pattern in our commit messages. First, write the name
of the file changed, then a short description of the change and then,
if applicable, a longer description in the commit message.
This message could be written as "user/bld/index.rst: short description here".
Thanks for working on updating the documentation.
Best regards,
Vijay
On Wed, May 5, 2021 at 3:23 PM Harrison Gerber <gerberhe11 at gmail.com> wrote:
> From: Harrison <hgerber at uccs.edu>
> user/bld/index.rst | 7 -------
> 1 file changed, 7 deletions(-)
> diff --git a/user/bld/index.rst b/user/bld/index.rst
> index ebedf5a..411b3a2 100644
> --- a/user/bld/index.rst
> +++ b/user/bld/index.rst
> @@ -309,10 +309,6 @@ in the configuration file.
> Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
> section of the configuration file.
> -``--enable-networking`` | ``--disable-networking``
> - Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
> - the configuration file.
> ``--enable-paravirt`` | ``--disable-paravirt``
> Set ``RTEMS_PARAVIRT`` to ``True`` or ``False`` in the BSP section of
> @@ -354,9 +350,6 @@ Please have a look at the following example configuration file.
> # --enable-multiprocessing
> RTEMS_MULTIPROCESSING = False
> - # --enable-networking
> - RTEMS_NETWORKING = True
> # --disable-paravirt
> RTEMS_PARAVIRT = False
> 2.25.1
> devel mailing list
> devel at rtems.org
