[PATCH] bsps/raspberrypi/console: Fix default console device
Niteesh G. S. niteesh.gs at gmail.com
Thu May 6 14:48:18 UTC 2021
Hi Alan,
On Thu, May 6, 2021 at 6:12 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Hi Niteesh,
> I was hoping to try this out as soon as I get some time. No later than
> weekend. So if nobody else is able to check it out, I will be able to
> provide some feedback soon.
> I should be able to bring up the console on a RPi Zero W and RPi3, correct?
the consoles should work on Zero W and Pi3 by default. They only fail to
work when  CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
this option is used. This is because when that option is used it calls
console_initialize which checks if any boot options were present if none
were
given it defaults to pl011 which is the secondary UART in Zero w and Pi3 so
we get no output. This patch defaults to the primary UART instead of
pl011 depending on the board.
Also, this patch should be applied on RTEMS 5 since we started supporting
Pi3 and Zero w from RTEMS 5.
Thanks,
Niteesh.
> Thanks,
> Alan
> *From: *Niteesh G. S. <niteesh.gs at gmail.com>
> *Sent: *Thursday, May 6, 2021 4:29 AM
> *To: *Joel Sherrill <joel at rtems.org>; Christian Mauderer
> <christian.mauderer at embedded-brains.de>
> *Cc: *rtems-devel at rtems.org <devel at rtems.org>
> *Subject: *Re: [PATCH] bsps/raspberrypi/console: Fix default console
> device
> ping.
> On Sat, May 1, 2021 at 9:47 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> On Sat, May 1, 2021 at 8:31 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, May 1, 2021, 8:53 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> Just to provide more context,
> When the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER option is used
> and no --console option is provided, the console driver defaults to PL011.
> In raspberry pi 3 and other models whose primary UART is not PL011, we get
> no output.
> This patch fixes that by linking the primary UART to the console device.
> Thanks,
> Niteesh
> On Sat, May 1, 2021 at 7:05 PM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> When no console argument is given, the driver defaults to pl011
> this results in no output in case of Rpi3 whose primary uart is
> miniuart.
> This patch fixes that by defaulting to the primary uart when no
> console option is provided.
> Does the default need to vary by model?
> Yes, the primary UART is different across models.
> Rpi's have two UARTs PL011 and miniuart, on models which have Bluetooth
> the PL011 is used to talk to the Bluetooth and miniuart acts as the
> primary UART.
> Now we can change this by adding miniuart-bt to config.txt but the
> miniuart is
> based on the VPU core and requires to add another option which sets the
> core to
> a fixed freq.
>  bsps/arm/raspberrypi/console/console-config.c | 12 +++++++++---
>  1 file changed, 9 insertions(+), 3 deletions(-)
> diff --git a/bsps/arm/raspberrypi/console/console-config.c
> b/bsps/arm/raspberrypi/console/console-config.c
> index 6b8eb80aa4..bd3a8d34c2 100644
> --- a/bsps/arm/raspberrypi/console/console-config.c
> +++ b/bsps/arm/raspberrypi/console/console-config.c
> @@ -165,10 +165,16 @@ static void console_select( void )
>    }else {
> -     * If no command line option was given, default to PL011.
> +     * If no console option was given we default to the primary uarts.
> +     * The initialization of the uart's and BSP_output_char is already
> done
> +     * in the uart_probe function called before this. So now we can safely
> +     * compare BSP_output_char.
> -    BSP_output_char = output_char_pl011;
> -    link(PL011, CONSOLE_DEVICE_NAME);
> +    if (BSP_output_char == output_char_pl011) {
> +      link(PL011, CONSOLE_DEVICE_NAME);
> +    }else {
> +      link(MINIUART, CONSOLE_DEVICE_NAME);
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210506/856e5ced/attachment.html>
