[PATCH v4] rtems-debugger: Fixed 32bit pointers
Joel Sherrill
joel at rtems.org
Thu May 6 16:13:20 UTC 2021
On Wed, May 5, 2021 at 12:35 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, May 4, 2021 at 1:34 PM Stephen Clark <stephen.clark at oarcorp.com>
> wrote:
> > Using 32bit types like uint32_t for pointers creates issues on 64 bit
> > architectures like AArch64. Replaced occurrences of these with uintptr_t,
> > which will work for both 32 and 64 bit architectures. Added
> hex_decode_addr
> > function to rtems-debugger.
> > .../rtems/debugger/rtems-debugger-server.h | 5 ++++
> > cpukit/libdebugger/rtems-debugger-server.c | 30 +++++++++++++++----
> > cpukit/libdebugger/rtems-debugger-target.c | 2 +-
> > cpukit/libdebugger/rtems-debugger-target.h | 2 +-
> > 4 files changed, 32 insertions(+), 7 deletions(-)
> > diff --git a/cpukit/include/rtems/debugger/rtems-debugger-server.h
> b/cpukit/include/rtems/debugger/rtems-debugger-server.h
> > index 2189aac873..beff302641 100644
> > --- a/cpukit/include/rtems/debugger/rtems-debugger-server.h
> > +++ b/cpukit/include/rtems/debugger/rtems-debugger-server.h
> > @@ -50,6 +50,11 @@ extern "C" {
> > #define DB_UINT uint32_t
> > + * Data type for addresses. Here for 64bit support.
> > +#define DB_ADDR uintptr_t
> > * Debugger signals.
> > diff --git a/cpukit/libdebugger/rtems-debugger-server.c
> b/cpukit/libdebugger/rtems-debugger-server.c
> > index 975ec23a30..2ada418a79 100644
> > --- a/cpukit/libdebugger/rtems-debugger-server.c
> > +++ b/cpukit/libdebugger/rtems-debugger-server.c
> > @@ -154,6 +154,26 @@ hex_encode(int val)
> > return "0123456789abcdef"[val & 0xf];
> > +static inline DB_ADDR
> > +hex_decode_addr(const uint8_t* data)
> > + DB_ADDR ui = 0;
> > + size_t i;
> > + if (data[0] == '-') {
> > + if (data[1] == '1')
> > + ui = (DB_ADDR) -1;
> > + else {
> > + for (i = 0; i < (sizeof(ui) * 2); ++i) {
> > + int v = hex_decode(data[i]);
> > + if (v < 0)
> > + break;
> > + ui = (ui << 4) | v;
> > + return ui;
> This function body is identical to the following hex_decode_uint()
> except for the type of DB_ADDR. They could probably be merged. Is
> there a reason not to combine them and avoid the copy-paste?
DB_ADDR aka uintptr_t is just stated as being large enough to hold
an address. It is not listed in the set of types the C Standard makes
size guarantees about. See
http://www.open-std.org/jtc1/sc22/wg14/www/docs/n1256.pdf in
section 5.2.4.2.1 for the relationship between types that are guaranteed.
Notice that uintptr_t is just described in English when it shows up
in the standard and not in this list.
I don't think we can assume any specific integer type is equivalent to
uintptr_t.
It is a good example for function templates but they are not in C.
> > static inline DB_UINT
> > hex_decode_uint(const uint8_t* data)
> > @@ -1438,10 +1458,10 @@ remote_read_memory(uint8_t* buffer, int size)
> > if (comma == NULL)
> > remote_packet_out_str(r_E01);
> > else {
> > - DB_UINT addr;
> > + uintptr_t addr;
> > DB_UINT length;
> > int r;
> > - addr = hex_decode_uint(&buffer[1]);
> > + addr = hex_decode_addr(&buffer[1]);
> > length = hex_decode_uint((const uint8_t*) comma + 1);
> > remote_packet_out_reset();
> > r = rtems_debugger_target_start_memory_access();
> > @@ -1468,10 +1488,10 @@ remote_write_memory(uint8_t* buffer, int size)
> > comma = strchr((const char*) buffer, ',');
> > colon = strchr((const char*) buffer, ':');
> > if (comma != NULL && colon != NULL) {
> > - DB_UINT addr;
> > + uintptr_t addr;
> > DB_UINT length;
> > int r;
> > if (r == 0) {
> > @@ -1521,7 +1541,7 @@ remote_breakpoints(bool insert, uint8_t* buffer,
> int size)
> > uint32_t capabilities;
> > DB_UINT addr;
> > DB_UINT kind;
> > - addr = hex_decode_uint((const uint8_t*) comma1 + 1);
> > + addr = hex_decode_addr((const uint8_t*) comma1 + 1);
> > kind = hex_decode_uint((const uint8_t*)comma2 + 1);
> > capabilities = rtems_debugger_target_capabilities();
> > switch (buffer[1]) {
> > diff --git a/cpukit/libdebugger/rtems-debugger-target.c
> b/cpukit/libdebugger/rtems-debugger-target.c
> > index bf7579700d..34e4e84d2f 100644
> > --- a/cpukit/libdebugger/rtems-debugger-target.c
> > +++ b/cpukit/libdebugger/rtems-debugger-target.c
> > @@ -168,7 +168,7 @@ rtems_debugger_target_reg_table_size(void)
> > int
> > -rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr,
> DB_UINT kind)
> > +rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr,
> DB_UINT kind)
> why not use DB_ADDR?
That should be DB_ADDR unless there is another sweep to eliminate DB_ADDR.
But I wouldn't do that on this pass.
> > rtems_debugger_target* target = rtems_debugger->target;
> > rtems_debugger_target_swbreak* swbreaks;
> > diff --git a/cpukit/libdebugger/rtems-debugger-target.h
> b/cpukit/libdebugger/rtems-debugger-target.h
> > index f2abbe5fd3..db356e1f07 100644
> > --- a/cpukit/libdebugger/rtems-debugger-target.h
> > +++ b/cpukit/libdebugger/rtems-debugger-target.h
> > @@ -200,7 +200,7 @@ extern void
> rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
> > * Software breakpoints. These are also referred to as memory
> breakpoints.
> > extern int rtems_debugger_target_swbreak_control(bool insert,
> > - DB_UINT addr,
> > + uintptr_t addr,
> ditto
> > DB_UINT kind);
> > 2.27.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210506/d2403937/attachment-0001.html>
