GSoC - Code Formatting and Style Checking for RTEMS score
Joel Sherrill
joel at rtems.org
Thu May 6 19:05:01 UTC 2021
On Thu, May 6, 2021 at 12:47 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Ida and Gedare,
> On 06/05/2021 06:26, Gedare Bloom wrote:
> > hi Ida,
> > On Wed, May 5, 2021 at 3:21 PM Ida Delphine <idadelm at gmail.com> wrote:
> >> Hello everyone,
> >> Regarding this project (https://devel.rtems.org/ticket/3860) I went
> with clang-format as we all agreed. I have tested it on some "score" files
> and it made some changes which I don't think are very much in line with the
> RTEMS coding style. However, it wasn't really clear if we will chage the
> RTEMS coding style or try to make changes to clang-format to fit the style.
> >> Please will love to know the best option.
> > We will likely need to consider our choices carefully. If we can find
> > a suitably close style that is already well-supported by clang, and
> > get consensus from the maintainers on a change, then that might be the
> > best route forward.
> +1
> > I think the first thing to do is take the examples
> > that have been shown by Sebastian that are "close" but not quite
> > perfect, and identify the cases where they differ with RTEMS style in
> > order to present for discussion here. If consensus can't be reached to
> > change the style, then we would need to have a plan for how to improve
> > the existing tools for what we have.
> I also found the following tool quite useful to play with the clang
> style config:
> https://zed0.co.uk/clang-format-configurator/
> Maybe it can help a bit to find out what certain options mean.
> > However, I think there is interest in doing less work on the tool
> > side, and more work on how to integrate it into our workflows better.
> +1
I agree with all of this from the student perspective. But we will have
to come to some agreement on a machine producible format to
be able to use the integration. A report on what doesn't match would
give us something to chew on while Ida works the integration.
--joel
> >> Cheers,
> >> Ida.
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210506/83fb1cac/attachment.html>
