qemu version for source builder
Richi Dubey richidubey at gmail.com
Fri May 7 06:15:59 UTC 2021
Hi,
rdubey at hpc1:~/quick-start/src/rsb$
~/quick-start/rtems/6/bin/qemu-system-ppc64  -machine help
Supported machines are:
40p                  IBM RS/6000 7020 (40p)
bamboo               bamboo
g3beige              Heathrow based PowerMAC
mac99                Mac99 based PowerMAC
mpc8544ds            mpc8544ds
none                 empty machine
powernv10            IBM PowerNV (Non-Virtualized) POWER10
powernv8             IBM PowerNV (Non-Virtualized) POWER8
powernv              IBM PowerNV (Non-Virtualized) POWER9 (alias of
powernv9)
powernv9             IBM PowerNV (Non-Virtualized) POWER9
ppce500              generic paravirt e500 platform
pseries-2.1          pSeries Logical Partition (PAPR compliant)
pseries-2.10         pSeries Logical Partition (PAPR compliant)
pseries-2.11         pSeries Logical Partition (PAPR compliant)
pseries-2.12         pSeries Logical Partition (PAPR compliant)
pseries-2.12-sxxm    pSeries Logical Partition (PAPR compliant)
pseries-2.2          pSeries Logical Partition (PAPR compliant)
pseries-2.3          pSeries Logical Partition (PAPR compliant)
pseries-2.4          pSeries Logical Partition (PAPR compliant)
pseries-2.5          pSeries Logical Partition (PAPR compliant)
pseries-2.6          pSeries Logical Partition (PAPR compliant)
pseries-2.7          pSeries Logical Partition (PAPR compliant)
pseries-2.8          pSeries Logical Partition (PAPR compliant)
pseries-2.9          pSeries Logical Partition (PAPR compliant)
pseries-3.0          pSeries Logical Partition (PAPR compliant)
pseries-3.1          pSeries Logical Partition (PAPR compliant)
pseries-4.0          pSeries Logical Partition (PAPR compliant)
pseries-4.1          pSeries Logical Partition (PAPR compliant)
pseries-4.2          pSeries Logical Partition (PAPR compliant)
pseries-5.0          pSeries Logical Partition (PAPR compliant)
pseries-5.1          pSeries Logical Partition (PAPR compliant)
pseries              pSeries Logical Partition (PAPR compliant) (alias of
pseries-5.2)
pseries-5.2          pSeries Logical Partition (PAPR compliant) (default)
ref405ep             ref405ep
sam460ex             aCube Sam460ex
taihu                taihu
virtex-ml507         Xilinx Virtex ML507 reference design
I got this qemu by using the source builder with this command: "
./source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6
devel/qemu.bset"
 So, does this qemu not support e6500 cores (for the t2080rdb platform)?
I read in a recent discussion about choosing qemu version:
https://lists.rtems.org/pipermail/devel/2020-May/059645.html. I can't seem
to get any version of qemu except the no-version named one:
rdubey at hpc1:~/quick-start/src/rsb$ ./source-builder/sb-set-builder
--prefix=$HOME/quick-start/rtems/6 devel/qemu4.bset
RTEMS Source Builder - Set Builder, 6 (4e256fc4cb0d)
Build Set: devel/qemu4.bset
error: no build set file found: devel/qemu4.bset
Build Set: Time 0:00:00.000433
Build FAILED
--prefix=$HOME/quick-start/rtems/6 devel/qemu6.bset
Build Set: devel/qemu6.bset
error: no build set file found: devel/qemu6.bset
Build Set: Time 0:00:00.000442
Build FAILED
--prefix=$HOME/quick-start/rtems/6 devel/qemu5.bset
Build Set: devel/qemu5.bset
error: no build set file found: devel/qemu5.bset
Build Set: Time 0:00:00.000493
Build FAILED
--prefix=$HOME/quick-start/rtems/6 devel/qemu.bset
Build Set: devel/qemu.bset
Build Set: devel/autotools-internal.bset
config: devel/autoconf-2.69-1.cfg
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210507/e547704d/attachment.html>
