[PATCH rtems-libbsd] ipsec-tools/pfkey: Fix socket leak
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri May 7 14:04:28 UTC 2021
It is a bit hard to see: The setkey programm uses the functions from
this library. In pfkey_open, a socket is opened and returned to setkey.
But setkey never closes it.
We already have wrappers around all of the "dangerous" functions that
allocated resources. The wrappers register the resource allocation. If
an application called with rtems_bsd_program_call_main_with_data_restore
exits, it will close or free the resources.
There are some other functions in the pfkey that don't work well with
that mechanism. Therefore I only added the one function that is
responsible for the socket leak.
Note that it is a bit of a hack but it works. I have planned to replace
the ipsec-tools with the tools from racoon2 soon to support newer
encryption protocols. So I think it's a reasonable intermediate solution.
Best regards
Christian
Am 07.05.21 um 15:56 schrieb Joel Sherrill:
> How does this fix a leak?
> On Fri, May 7, 2021 at 7:09 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Note that I would like to push this patch on 5-freebsd-12 as well as on
>     master.
>     Best regards
>     Christian
>     Am 07.05.21 um 14:08 schrieb Christian Mauderer:
>      > Fixes #4404
>      >   ipsec-tools/src/libipsec/pfkey.c | 7 +++++++
>      >   1 file changed, 7 insertions(+)
>      > diff --git a/ipsec-tools/src/libipsec/pfkey.c
>     b/ipsec-tools/src/libipsec/pfkey.c
>      > index a621be12..385a21a9 100644
>      > --- a/ipsec-tools/src/libipsec/pfkey.c
>      > +++ b/ipsec-tools/src/libipsec/pfkey.c
>      > @@ -1,5 +1,12 @@
>      >   #include <machine/rtems-bsd-user-space.h>
>      > +#ifdef __rtems__
>      > +/* Only need socket from rtems-bsd-program wrappers! */
>      > +int
>      > +rtems_bsd_program_socket(int domain, int type, int protocol);
>      > +#define socket(domain, type, protocol) \
>      > +    rtems_bsd_program_socket(domain, type, protocol)
>      > +#endif /* __rtems__ */
>      >   /*  $NetBSD: pfkey.c,v 1.21.2.1 2011/11/14 13:25:06 tteras Exp
>      >   /*  $KAME: pfkey.c,v 1.47 2003/10/02 19:52:12 itojun Exp $  */
>     embedded brains GmbH
>     Herr Christian MAUDERER
>     Dornierstr. 4
>     82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     phone: +49-89-18 94 741 - 18
>     fax:   +49-89-18 94 741 - 08
>     Registergericht: Amtsgericht München
>     Registernummer: HRB 157899
>     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>     Unsere Datenschutzerklärung finden Sie hier:
>     https://embedded-brains.de/datenschutzerklaerung/
>     <https://embedded-brains.de/datenschutzerklaerung/>
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
Dornierstr. 4
82178 Puchheim
Germany
