[PATCH rtems-libbsd] ipsec-tools/pfkey: Fix socket leak
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri May 7 14:54:26 UTC 2021
Hello Joel,
Am 07.05.21 um 16:45 schrieb Joel Sherrill:
> On Fri, May 7, 2021 at 9:04 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     It is a bit hard to see: The setkey programm uses the functions from
>     this library. In pfkey_open, a socket is opened and returned to setkey.
>     But setkey never closes it.
> This much I assumed from the words "socket" and "leak" :)
>     We already have wrappers around all of the "dangerous" functions that
>     allocated resources. The wrappers register the resource allocation. If
>     an application called with
>     rtems_bsd_program_call_main_with_data_restore
>     exits, it will close or free the resources.
> This makes sense. Is this documented?
Like a lot of libbsd: Not really. A rough description of the user-space
utility porting process is here:
https://git.rtems.org/rtems-libbsd/tree/CONTRIBUTING.md#n189
But that is basically a "do it exactly like it is written there" guide
than an explanation. The part that the rtems-bsd-program.h does all of
the magic with the wrappers and registering ressources is clearly
missing. If you know a good location where I should add a bit of
description for this, please let me know.
>     There are some other functions in the pfkey that don't work well with
>     that mechanism. Therefore I only added the one function that is
>     responsible for the socket leak.
> How about add some more to the commit message along the lines of
> what you explained here. It just isn't obvious how a change to a macro
> without words like free or deallocate in it fixes anything.
I'll do that (most likely) on Monday.
Best regards
Christian
>     Note that it is a bit of a hack but it works. I have planned to replace
>     the ipsec-tools with the tools from racoon2 soon to support newer
>     encryption protocols. So I think it's a reasonable intermediate
>     solution.
> OK.  One thing we have gotten better at is migrating to pick up better
> things.
> --joel
>     Best regards
>     Christian
>     Am 07.05.21 um 15:56 schrieb Joel Sherrill:
>      > How does this fix a leak?
>      > On Fri, May 7, 2021 at 7:09 AM Christian MAUDERER
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>      >     Note that I would like to push this patch on 5-freebsd-12 as
>     well as on
>      >     master.
>      >     Best regards
>      >     Christian
>      >     Am 07.05.21 um 14:08 schrieb Christian Mauderer:
>      >      > Fixes #4404
>      >      >   ipsec-tools/src/libipsec/pfkey.c | 7 +++++++
>      >      >   1 file changed, 7 insertions(+)
>      >      > diff --git a/ipsec-tools/src/libipsec/pfkey.c
>      >     b/ipsec-tools/src/libipsec/pfkey.c
>      >      > index a621be12..385a21a9 100644
>      >      > --- a/ipsec-tools/src/libipsec/pfkey.c
>      >      > +++ b/ipsec-tools/src/libipsec/pfkey.c
>      >      > @@ -1,5 +1,12 @@
>      >      >   #include <machine/rtems-bsd-user-space.h>
>      >      > +#ifdef __rtems__
>      >      > +/* Only need socket from rtems-bsd-program wrappers! */
>      >      > +int
>      >      > +rtems_bsd_program_socket(int domain, int type, int protocol);
>      >      > +#define socket(domain, type, protocol) \
>      >      > +    rtems_bsd_program_socket(domain, type, protocol)
>      >      > +#endif /* __rtems__ */
>      >      >   /*  $NetBSD: pfkey.c,v 1.21.2.1 2011/11/14 13:25:06
>     tteras Exp
>      >      >   /*  $KAME: pfkey.c,v 1.47 2003/10/02 19:52:12 itojun Exp
>      >     embedded brains GmbH
>      >     Herr Christian MAUDERER
>      >     Dornierstr. 4
>      >     82178 Puchheim
>      >     Germany
>      >     email: christian.mauderer at embedded-brains.de
>      >     phone: +49-89-18 94 741 - 18
>      >     fax:   +49-89-18 94 741 - 08
>      >     Registergericht: Amtsgericht München
>      >     Registernummer: HRB 157899
>      >     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen,
>     Thomas Dörfler
>      >     Unsere Datenschutzerklärung finden Sie hier:
>      > https://embedded-brains.de/datenschutzerklaerung/
>     <https://embedded-brains.de/datenschutzerklaerung/>
>     <https://embedded-brains.de/datenschutzerklaerung/>>
>      >     _______________________________________________
>      >     devel mailing list
>      > devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org
>     <mailto:devel at rtems.org>>
>      > http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
>     <http://lists.rtems.org/mailman/listinfo/devel>>
>     Dornierstr. 4
>     82178 Puchheim
>     Germany
>     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
Dornierstr. 4
82178 Puchheim
Germany
