FVP_BaseR_Cortex-R52x1 not exist when testing arm/fvp_cortex_r52
Fri May 7 16:00:47 UTC 2021
On Fri, May 7, 2021, 10:13 AM Đức Anh <dauto98 at gmail.com> wrote:
> Dear all,
> I built arm/fvp_cortex_r52 on the master branch, commit a1679af3805. When
> I run rtems-test for this BSP, the program report
> that FVP_BaseR_Cortex-R52x1 does not exist. So that all the tests failed.
I don't see a configuration file (ini) for this bsp and RTEMS tester in
rtems-tools so that explains the tester error.
> How can I fix this problem? I followed all the build step (./waf
> configure, build, install)
I also don't see a readme or entry in the users guide for this bsp. That
should give some indication of how to run them.
Hopefully someone else will pop up it is more about this BSP.
> Best Regards,
> Duc Anh
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210507/a27a2ce8/attachment.html>
