qemu-system-ppc64 does not work on powerpc/qoriq_e6500_64
Richi Dubey
richidubey at gmail.com
Sun May 9 04:02:38 UTC 2021
Hi,
I tried with both smp and sp tests:
rdubey at hpc1:~/quick-start$ ~/quick-start/rtems/6/bin/powerpc-rtems6-gdb
--command=~/quick-start/rtems/6/bin/ppc.gdb
~/quick-start/src/rtems/build/powerpc/qoriq_e6500_64/testsuites/smptests/smpschededf04.exe
GNU gdb (GDB) 10.1.90.20210409-git
Loading section .toc, size 0x60 lma 0x78bdc
Loading section .rtemsroset, size 0xa8 lma 0x78c3c
Loading section .data, size 0x800 lma 0x78ce4
Start address 0x0000000000004000, load size 480477
Transfer rate: 16757 KB/sec, 1945 bytes/write.
Id Target Id Frame
* 1 Thread 1.1 (CPU#0 [running]) bsp_section_start_begin () at
../../../bsps/powerpc/qoriq/start/start.S:55
2 Thread 1.2 (CPU#1 [halted ]) 0x00000000fffffffc in ?? ()
3 Thread 1.3 (CPU#2 [halted ]) 0x00000000fffffffc in ?? ()
4 Thread 1.4 (CPU#3 [halted ]) 0x00000000fffffffc in ?? ()
Transfer rate: 16179 KB/sec, 1945 bytes/write.
(gdb) c
Continuing.
Both of them hang after I run 'c'. On stepping:
Loading section .rtemsroset, size 0xb0 lma 0x7681c
Loading section .data, size 0x860 lma 0x768cc
Start address 0x0000000000004000, load size 471337
Transfer rate: 15872 KB/sec, 1955 bytes/write.
(gdb) ni
56 bl .Linitearly
(gdb)
bsp_section_start_begin () at ../../../bsps/powerpc/qoriq/start/start.S:153
153 mfspr r0, BOOKE_EPCR
(gdb)
154 oris r0, r0, BOOKE_EPCR_ICM >> 16
(gdb)
155 mtspr BOOKE_EPCR, r0
(gdb)
158 mfmsr r0
(gdb)
159 oris r0, r0, MSR_CM >> 16
(gdb)
160 mtmsr r0
(gdb)
161 isync
(gdb)
165 mfspr r0, BOOKE_TCR
(gdb)
166 LWI r4, BOOKE_TCR_DIE
(gdb)
0x0000000000004288 166 LWI r4, BOOKE_TCR_DIE
(gdb)
167 andc r0, r0, r4
(gdb)
168 mtspr BOOKE_TCR, r0
(gdb)
178 LWI r0, QORIQ_INITIAL_BUCSR
(gdb)
0x0000000000004298 178 LWI r0, QORIQ_INITIAL_BUCSR
(gdb)
179 mtspr FSL_EIS_BUCSR, r0
(gdb)
180 isync
(gdb)
185 LWI r0, QORIQ_INITIAL_HID0
(gdb)
0x00000000000042a8 185 LWI r0, QORIQ_INITIAL_HID0
(gdb)
186 mtspr HID0, r0
(gdb)
190 LA32 r2, .TOC.
(gdb)
0x00000000000042b4 190 LA32 r2, .TOC.
(gdb)
199 SET_SELF_CPU_CONTROL CPU_SELF, r5
(gdb)
0x00000000000042bc 199 SET_SELF_CPU_CONTROL CPU_SELF, r5
(gdb)
0x00000000000042c0 199 SET_SELF_CPU_CONTROL CPU_SELF, r5
(gdb)
0x00000000000042c4 199 SET_SELF_CPU_CONTROL CPU_SELF, r5
(gdb)
0x00000000000042c8 199 SET_SELF_CPU_CONTROL CPU_SELF, r5
(gdb)
0x0000000000000000 in ?? ()
(gdb)
(gdb)
(gdb)
(gdb)
(gdb)
Is there a way to solve this?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210509/0db7cbc7/attachment-0001.html>
