Error when using RTEMS_MICROSECONDS_TO_TICKS
Richi Dubey
richidubey at gmail.com
Sun May 9 15:32:42 UTC 2021
Hi,
I am using the line:
rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000)); in my test
program to emulate a 6 seconds sleep. But when I deubg the program using
qemu, I do not see it waiting for 6 seconds; on debugging, there is a error
of a shared library file not found, which leads to the ticks being 0. Can
someone please help?
Debug log:
35 rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000));
(gdb) si
0x00101176 135 rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000));
(gdb)
0x00101178 135 rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000));
(gdb)
0x0010117c 135 rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000));
(gdb)
__udivsi3 () at
../../../../../../gnu-mirror-gcc-57b5da3/libgcc/config/arm/lib1funcs.S:1104
1104
../../../../../../gnu-mirror-gcc-57b5da3/libgcc/config/arm/lib1funcs.S: No
such file or directory.
(gdb)
1105 in
(gdb) ni
1106 in
(gdb)
1107 in
(gdb) si
1108 in
(gdb) ni
1109 in
(gdb)
1118 in
(gdb)
1119 in
(gdb)
1120 in
(gdb)
1121 in
(gdb)
0x00101180 in test () at
../../../testsuites/smptests/smpschededf05/init.c:135
(gdb) si
0x00101182 135 rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000));
(gdb)
0x00101184 135 rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(6000));
(gdb)
rtems_task_wake_after (ticks=16777216) at
../../../cpukit/rtems/src/taskwakeafter.c:30
30 {
(gdb)
0x00108b44 30 {
(gdb) ni
0x00108b46 30 {
(gdb)
0x00108b48 30 {
(gdb)
38 cpu_self = _Thread_Dispatch_disable();
(gdb)
0x00108b4e 38 cpu_self = _Thread_Dispatch_disable();
(gdb)
39 executing = _Per_CPU_Get_executing( cpu_self );
(gdb)
0x00108b52 39 executing = _Per_CPU_Get_executing( cpu_self );
(gdb)
0x00108b56 39 executing = _Per_CPU_Get_executing( cpu_self );
(gdb)
41 if ( ticks == 0 ) {
(gdb)
0x00108b5a 41 if ( ticks == 0 ) {
(gdb) p ticks
$1 = 0
(gdb)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210509/e2d04bc8/attachment-0001.html>
