[PATCH rtems-libbsd v2] ipsec-tools/pfkey: Fix socket leak
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon May 10 06:51:27 UTC 2021
Only change is a better description.
Am 10.05.21 um 08:50 schrieb Christian Mauderer:
> setkey uses pfkey_open to open a socket. But setkey doesn't close the
> socket.
> The libipsec functions are used only by user space applications (setkey
> and racoon). Adding the wrapper for socket makes sure that the opened
> socket is registered and closes if the application exits.
> Fixes #4404
> ipsec-tools/src/libipsec/pfkey.c | 7 +++++++
> 1 file changed, 7 insertions(+)
> diff --git a/ipsec-tools/src/libipsec/pfkey.c b/ipsec-tools/src/libipsec/pfkey.c
> index a621be12..385a21a9 100644
> --- a/ipsec-tools/src/libipsec/pfkey.c
> +++ b/ipsec-tools/src/libipsec/pfkey.c
> @@ -1,5 +1,12 @@
> #include <machine/rtems-bsd-user-space.h>
> +#ifdef __rtems__
> +/* Only need socket from rtems-bsd-program wrappers! */
> +int
> +rtems_bsd_program_socket(int domain, int type, int protocol);
> +#define socket(domain, type, protocol) \
> + rtems_bsd_program_socket(domain, type, protocol)
> +#endif /* __rtems__ */
> /* $NetBSD: pfkey.c,v 1.21.2.1 2011/11/14 13:25:06 tteras Exp $ */
> /* $KAME: pfkey.c,v 1.47 2003/10/02 19:52:12 itojun Exp $ */
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
