qemu-system-ppc64 does not work on powerpc/qoriq_e6500_64
Karel Gardas karel.gardas at centrum.cz
Mon May 10 17:34:12 UTC 2021
On 5/10/21 2:26 PM, Richi Dubey wrote:
> Thanks, I'll check it out.
-bios `where you do have`/u-boot.e500.
Karel
> On Mon, May 10, 2021 at 10:19 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 09/05/2021 06:02, Richi Dubey wrote:
>     > 0x00000000000042c8 199 SET_SELF_CPU_CONTROL CPU_SELF, r5
>     > (gdb)
>     > 0x0000000000000000 in ?? ()
>     > (gdb)
>     > (gdb)
>     > (gdb)
>     > (gdb)
>     > (gdb)
>     > Is there a way to solve this?
>     This BSP assumes that it is booted via U-Boot. Maybe there is an option
>     in Qemu to simulate this. Otherwise you probably have to change the
>     startup sequence.
>     embedded brains GmbH
>     Herr Sebastian HUBER
>     Dornierstr. 4
>     82178 Puchheim
>     Germany
>     email: sebastian.huber at embedded-brains.de
>     phone: +49-89-18 94 741 - 16
>     fax:   +49-89-18 94 741 - 08
>     Registergericht: Amtsgericht München
>     Registernummer: HRB 157899
>     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>     Unsere Datenschutzerklärung finden Sie hier:
>     https://embedded-brains.de/datenschutzerklaerung/
>     <https://embedded-brains.de/datenschutzerklaerung/>
> devel mailing list
> devel at rtems.org
