[PATCH 2/2] bsp: Use RTEMS_NOINIT for bsp_fdt_blob
Sebastian Huber
Mon May 10 17:40:32 UTC 2021
This makes it possible to copy a boot loader provided device tree to
bsp_fdt_blob before the BSS section is cleared to zero. The
disadvantage is that bsp_fdt_blob contains now uninitialized data.
bsps/shared/start/bsp-fdt.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/shared/start/bsp-fdt.c b/bsps/shared/start/bsp-fdt.c
index 50a485eb16..9cd46e5927 100644
--- a/bsps/shared/start/bsp-fdt.c
+++ b/bsps/shared/start/bsp-fdt.c
@@ -32,7 +32,7 @@ static const uint32_t
bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)] CPU_STRUCTURE_ALIGNMENT =
{ 0xdeadbeef };
#else
-static uint32_t
+RTEMS_NOINIT static uint32_t
bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)] CPU_STRUCTURE_ALIGNMENT;
#endif
2.26.2
